I am having problems debugging native apps on Genymotion emulators.
On debugging, the process will fail on starting the gdbserver with the error:
Failed to attach: GDB server could not be found on the device, /data/data/#PACKAGE_NAME#/lib/gdbserver. It must be included with the application…
This is due to the fact that the gdbserver file fails to be copied to the lib folder…
If I copy the file manually and set the appropriate permissions, then another error is displayed instead:
Failed to attach: Failed to start debug server on device: /data/data/#PACKAGE_NAME#/lib/gdbserver[2]: syntax error: '$(s4,4 (€€xæxæàðà€à€LLXQåtdpÈÙÈYÈY˜˜Råtdàðà€à€ åpâ 3ÿ/áåÿ/á@-é@ áåPã.
The same happens if I try to manually run the gdbserver through command line, so it’s not really a specific issue of the Nsight Tegra, mind you. I’m just wondering if anybody else has seen this issue.
Debugging works ok on real devices or on Android ADV.
