I’m having problems installing OFED 4.7 on RHEL 7.7 (3.10.0-1062.9.1.el7.x86_64) using custom yum repositories generated with “/mlnx_add_kernel_support.sh -m .”. kmp support should be disabled. Apparently the generated meta package (mlnx-ofed-all-3.10.0-1062.9.1.el7.x86_64-4.7-1.0.0.1.rhel7.7.noarch.rpm or mlnx-ofed-all-3.10.0-1062.9.1.el7.x86_64-4.7-3.2.9.0.rhel7.7.noarch.rpm) is missing requirements for mlnx-ofa_kernel-modules, knem-modules and kernel-mft which used to be present in older OFED versions. As a result required kernel modules are not installed.
Could somebody provide help generating metapackges with disabled kmp support?
