Problems with display/booting
I am using a Dell G3223Q monitor for display (yes I have flashed the sd card). When I turn on the orin nano and the monitor, I get a big NVIDIA icon on display for like 5 seconds and then the nano fan stops spinning and the monitor says “Scanning for Output” and “No DP Signal from your device”. I tried pressing f11 on my keyboard and it took me to a boot menu. I select “UEFI SD Device” and the same thing happens: "L4TLauncher: Attempting Recovery Boot
EPT stub: Booting Linux Kernel…
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUXEFI_INITRD_MEDIA_GUID device path
EFI stub:
and it closes and says, “No DP Signal from your device”
Is there anything I can do to fix this?
DevKit or custom board?
What L4T version do you use?
Re-flashing with SDK Manager is always the first thing you should try.
yeah I’m trying that right now, but I’m also having a problem. On step 2, when I try to download and install the 2 files, I get a message saying “There is not enough space on required partitions (1GB usage threshold on is needed). Need additional 1021 MB on /cow. Do you want to continue installation anyway?” I entered df -h in terminal to check /cow, and it has no available space apparently. Is there anyway I can change where the files will be downloaded or increase the space in /cow?
Do it here:
https://docs.nvidia.com/sdk-manager/install-with-sdkm-jetson/index.html
Ok I just tried that and now it says the same thing but with 28639 MB. any way to change the directory from /cow or something?
I don’t really get your point.
Put your screenshot here.
and yes i changed the location
So you press change and select another disk that has enough space.
Anything you don’t get?
Selecting another folder under /home is meaningless because they all live in the same partition…
ok thx I think i figured everything out now its loading
