I have installed Centos 7 on my notebook. The notebook comes with a NVIDIA GTX 1060 graphicscard. I am using the NVIDIA driver 367.44. The problem is that the maximum color depth I get is 16 bit. I have configured 24 bits, but it does not work.
Here are some technical data:
uname -a
Linux localhost.localdomain 3.10.0-514.26.2.el7.x86_64 #1 SMP Tue Jul 4 15:04:05 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
lspci -vv
VGA compatible controller: NVIDIA Corporation GP106M [GeForce GTX 1060] (rev a1) (prog-if 00 [VGA controller])
Subsystem: CLEVO/KAPOK Computer Device 6a02
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
Latency: 0
Interrupt: pin A routed to IRQ 122
Region 0: Memory at db000000 (32-bit, non-prefetchable)
Region 1: Memory at 90000000 (64-bit, prefetchable)
Region 3: Memory at a0000000 (64-bit, prefetchable)
Region 5: I/O ports at e000
[virtual] Expansion ROM at dc000000 [disabled]
Capabilities: <access denied>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
rpm -qa
yum-plugin-nvidia-1.0.2-1.el7.elrepo.noarch
nvidia-x11-drv-367xx-367.57-4.el7.elrepo.x86_64
kmod-nvidia-367xx-367.57-4.el7.elrepo.x86_64
nvidia-detect-367.44-1.el7.elrepo.x86_64
I have also tried the original driver from nvidia “NVIDIA-Linux-x86_64-367.44.run”
xrandr --verbose
xrandr --verbose
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1be
Timestamp: 72463
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
CscMatrix: 65536 0 0 0 0 0 0 0 0 0 65536 0
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorType: HDMI
ConnectorNumber: 2
_ConnectorLocation: 2
DP-0 connected primary 1920x1080+0+0 (0x1c0) normal (normal left inverted right x axis y axis) 344mm x 194mm
Identifier: 0x1bf
Timestamp: 72463
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 0 1 2 3
filter:
Backlight: 100
range: (0, 100)
EDID:
00ffffffffffff0030e46f0400000000
0018010495221378eadc95a35855a026
0d505400000001010101010101010101
0101010101012e3680a070381f403020
350058c21000001a522b80a070381f40
3020350058c21000001a000000fe0033
38373459803135365746360a00000000
000041319e001000000a010a20200092
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: DisplayPort
supported: DisplayPort
ConnectorType: Panel
ConnectorNumber: 3
_ConnectorLocation: 3
1920x1080 (0x1c0) 138.700MHz +HSync -VSync *current +preferred
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 66.68KHz
v: height 1080 start 1083 end 1088 total 1111 clock 60.02Hz
1920x1080 (0x1c1) 110.900MHz +HSync -VSync
h: width 1920 start 1968 end 2000 total 2080 skew 0 clock 53.32KHz
v: height 1080 start 1083 end 1088 total 1111 clock 47.99Hz
DP-1 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1c2
Timestamp: 72463
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorType: DisplayPort
ConnectorNumber: 4
_ConnectorLocation: 4
DP-2 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1c3
Timestamp: 72463
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 4
DP-3 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1c4
Timestamp: 72463
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
ConnectorNumber: 5
_ConnectorLocation: 5
DP-4 disconnected (normal left inverted right x axis y axis)
Identifier: 0x1c5
Timestamp: 72463
Subpixel: unknown
Clones:
CRTCs: 0 1 2 3
filter:
BorderDimensions: 4
supported: 4
Border: 0 0 0 0
range: (0, 65535)
SignalFormat: TMDS
supported: TMDS
ConnectorNumber: 5
/etc/X11/xorg.conf
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 367.57 (buildmeister@swio-display-x64-rhel04-13) Mon Oct 3 21:41:11 PDT 2016
# /etc/X11/nvidia-xorg.conf provided by http://elrepo.org
Section "ServerLayout"
Identifier "Default Layout"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "InputDevice"
# generated from default
Identifier "Keyboard0"
Driver "kbd"
EndSection
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "LGD"
HorizSync 53.0 - 66.0
VertRefresh 47.0 - 60.0
EndSection
Section "Device"
Identifier "Videocard0"
Driver "nvidia"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 1060"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Videocard0"
Monitor "Monitor0"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-1"
Option "metamodes" "1920x1080_60 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
/var/log/nvidia-installer.log
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Wed Sep 6 08:46:42 2017
installer version: 367.44
PATH: /sbin:/bin:/usr/sbin:/usr/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 8 CPUs online; setting concurrency level to 8.
-> License accepted.
-> Installing NVIDIA driver version 367.44.
-> There appears to already be a driver installed on your system (version: 367.44). As part of installing this driver (version: 367.44), the existing driver will be uninstalled. Are you sure you want to continue? (Answer: Continue installation)
-> Performing CC sanity check with CC="/bin/cc".
-> Kernel source path: '/lib/modules/3.10.0-514.26.2.el7.x86_64/source'
-> Kernel output path: '/lib/modules/3.10.0-514.26.2.el7.x86_64/build'
-> Performing rivafb check.
-> Performing nvidiafb check.
-> Performing Xen check.
-> Performing PREEMPT_RT check.
-> Cleaning kernel module build directory.
executing: 'cd ./kernel; /bin/make -k -j8 clean NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/3.10.0-514.26.2.el7.x86_64/source" SYSOUT="/lib/modules/3.10.0-514.26.2.el7.x86_64/build"'...
rm -f -r conftest
/bin/make "CC=cc" KBUILD_OUTPUT=/lib/modules/3.10.0-514.26.2.el7.x86_64/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-514.26.2.el7.x86_64/source M=/tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-514.26.2.el7.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-514.26.2.el7.x86_64/build NV_KERNEL_MODULES="nvidia nvidia-uvm nvidia-modeset nvidia-drm" INSTALL_MOD_DIR=kernel/drivers/video clean
make[1]: Entering directory `/usr/src/kernels/3.10.0-514.26.2.el7.x86_64'
/bin/make -C /lib/modules/3.10.0-514.26.2.el7.x86_64/build \
KBUILD_SRC=/usr/src/kernels/3.10.0-514.26.2.el7.x86_64 \
KBUILD_EXTMOD="/tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel" -f /usr/src/kernels/3.10.0-514.26.2.el7.x86_64/Makefile \
clean
make[1]: Leaving directory `/usr/src/kernels/3.10.0-514.26.2.el7.x86_64'
-> Building kernel modules
executing: 'cd ./kernel; /bin/make -k -j8 NV_EXCLUDE_KERNEL_MODULES="" SYSSRC="/lib/modules/3.10.0-514.26.2.el7.x86_64/source" SYSOUT="/lib/modules/3.10.0-514.26.2.el7.x86_64/build"'...
/bin/make "CC=cc" KBUILD_OUTPUT=/lib/modules/3.10.0-514.26.2.el7.x86_64/build KBUILD_VERBOSE= -C /lib/modules/3.10.0-514.26.2.el7.x86_64/source M=/tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel ARCH=x86_64 NV_KERNEL_SOURCES=/lib/modules/3.10.0-514.26.2.el7.x86_64/source NV_KERNEL_OUTPUT=/lib/modules/3.10.0-514.26.2.el7.x86_64/build NV_KERNEL_MODULES="nvidia nvidia-uvm nvidia-modeset nvidia-drm" INSTALL_MOD_DIR=kernel/drivers/video modules
modules
SYMLINK /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nv-modeset-kernel.o
SYMLINK /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-kernel.o
CONFTEST: INIT_WORK
CONFTEST: remap_pfn_range
CONFTEST: follow_pfn
CONFTEST: vmap
CONFTEST: set_pages_uc
CONFTEST: set_memory_uc
CONFTEST: set_memory_array_uc
CONFTEST: change_page_attr
CONFTEST: pci_get_class
CONFTEST: pci_choose_state
CONFTEST: vm_insert_page
CONFTEST: acpi_device_id
CONFTEST: console_lock
CONFTEST: acquire_console_sem
CONFTEST: kmem_cache_create
CONFTEST: on_each_cpu
CONFTEST: smp_call_function
CONFTEST: acpi_evaluate_integer
CONFTEST: ioremap_cache
CONFTEST: ioremap_wc
CONFTEST: acpi_walk_namespace
CONFTEST: pci_domain_nr
CONFTEST: pci_dma_mapping_error
CONFTEST: sg_alloc_table
CONFTEST: sg_init_table
CONFTEST: pci_get_domain_bus_and_slot
CONFTEST: get_num_physpages
CONFTEST: efi_enabled
CONFTEST: proc_create_data
CONFTEST: pde_data
CONFTEST: proc_remove
CONFTEST: pm_vt_switch_required
CONFTEST: drm_driver_has_set_busid
CONFTEST: xen_ioemu_inject_msi
CONFTEST: phys_to_dma
CONFTEST: get_dma_ops
CONFTEST: write_cr4
CONFTEST: of_parse_phandle
CONFTEST: for_each_online_node
CONFTEST: node_end_pfn
CONFTEST: pci_bus_address
CONFTEST: request_threaded_irq
CONFTEST: remap_page_range
CONFTEST: address_space_init_once
CONFTEST: kbasename
CONFTEST: fatal_signal_pending
CONFTEST: list_cut_position
CONFTEST: vzalloc
CONFTEST: wait_on_bit_lock_argument_count
CONFTEST: bitmap_clear
CONFTEST: usleep_range
CONFTEST: radix_tree_empty
CONFTEST: drm_dev_unref
CONFTEST: drm_reinit_primary_mode_group
CONFTEST: drm_atomic_set_mode_for_crtc
CONFTEST: drm_atomic_clean_old_fb
CONFTEST: get_user_pages_remote
CONFTEST: drm_gem_object_lookup
CONFTEST: i2c_adapter
CONFTEST: pm_message_t
CONFTEST: irq_handler_t
CONFTEST: acpi_device_ops
CONFTEST: acpi_op_remove
CONFTEST: outer_flush_all
CONFTEST: proc_dir_entry
CONFTEST: scatterlist
CONFTEST: sg_table
CONFTEST: file_operations
CONFTEST: vm_operations_struct
CONFTEST: atomic_long_type
CONFTEST: pci_save_state
CONFTEST: file_inode
CONFTEST: task_struct
CONFTEST: kuid_t
CONFTEST: dma_ops
CONFTEST: dma_map_ops
CONFTEST: noncoherent_swiotlb_dma_ops
CONFTEST: fault_flags
CONFTEST: atomic64_type
CONFTEST: backing_dev_info
CONFTEST: kernel_write
CONFTEST: strnstr
CONFTEST: iterate_dir
CONFTEST: kstrtoull
CONFTEST: mm_context_t
CONFTEST: drm_bus_present
CONFTEST: drm_bus_has_bus_type
CONFTEST: drm_bus_has_get_irq
CONFTEST: drm_bus_has_get_name
CONFTEST: drm_driver_has_legacy_dev_list
CONFTEST: drm_crtc_state_has_connectors_changed
CONFTEST: drm_init_functions_have_name_arg
CONFTEST: drm_mode_connector_list_update_has_merge_type_bits_arg
CONFTEST: drm_helper_mode_fill_fb_struct_has_const_mode_cmd_arg
CONFTEST: dom0_kernel_present
CONFTEST: drm_available
CONFTEST: nvidia_grid_build
CONFTEST: drm_atomic_available
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-drv.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-utils.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-crtc.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-encoder.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-connector.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-gem.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-fb.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-modeset.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-mmap.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nvidia-drm-linux.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm/nv-pci-table.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nvidia-modeset-linux.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_utils.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_linux.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_stubs.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_kepler.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_maxwell.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_migration_pascal.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_mgmt.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nvstatus.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nv-kthread-q.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/nv-kthread-q-selftest.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_common_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_directed_tests.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_channel_basic_sanity_tests.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_events.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_kernel_counters.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_debug_session.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_gpu_ops_tests.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_page_cache.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite_api.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite_prefetch.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_lite_region_tracking.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_mmu_mgmt_pascal.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_mmu_mgmt.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_mmu_mgmt_stubs.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_full_fault_buffer.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm_full_fault_buffer_pascal.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/mmu_fmt.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/gmmu_fmt.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_tools.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_global.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_gpu.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_procfs.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_va_space.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_gpu_semaphore.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_mem.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_rm_mem.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_channel.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_lock.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_hal.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_tree.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_allocator.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_va_range.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_va_block.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_group.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_gpu_page_fault.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_events.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_module.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_mmu.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pte_batch.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_tlb_batch.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_push.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pushbuffer.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_thread_context.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_tracker.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kepler.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kepler_ce.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kepler_host.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kepler_mmu.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_maxwell.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_maxwell_host.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal_ce.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal_host.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal_mmu.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pascal_fault_buffer.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_policy.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_utils.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kvmalloc.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pmm_gpu.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_migrate.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_map_external.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_user_channel.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_hmm.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_heuristics.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_thrashing.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_prefetch.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_test_rng.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_tree_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_allocator_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_gpu_semaphore_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_mem_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_rm_mem_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_page_tree_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_tracker_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_push_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_channel_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_ce_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_lock_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_utils_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_kvmalloc_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_pmm_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_events_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_perf_module_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_get_rm_ptes_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_fault_buffer_flush_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_mmu_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_peer_identity_mappings_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_va_block_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm/uvm8_range_group_tree_test.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-frontend.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-instance.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-acpi.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-chrdev.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-cray.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-dma.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-gvi.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-i2c.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mempool.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mmap.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-p2p.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-procfs.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-usermap.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vm.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vtophys.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-interface.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-pci.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-registry.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-usermap.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-modeset-interface.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pci-table.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv_uvm_interface.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_linux.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_pci.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ebridge_linux.o
CC [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ibmnpu_linux.o
ld -r -o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nv-modeset-interface.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset/nvidia-modeset-linux.o
LD [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia.o
LD [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm.o
LD [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset.o
ld -r -o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-interface.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-frontend.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-instance.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-acpi.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-chrdev.o /tmp/selfgz1754/NVI
DIA-Linux-x86_64-367.44/kernel/nvidia/nv-cray.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-dma.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-gvi.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-i2c.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mempool.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-mmap.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-p2p.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pat.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-procfs.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-usermap.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vm.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-vtophys.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-interface.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-mlock.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-pci.o /tmp/selfgz1754/NVIDIA-Linux-
x86_64-367.44/kernel/nvidia/os-registry.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/os-usermap.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-modeset-interface.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv-pci-table.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nv_uvm_interface.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_linux.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/nvlink_pci.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ebridge_linux.o /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia/ibmnpu_linux.o
LD [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm.o
Building modules, stage 2.
MODPOST 4 modules
CC /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm.mod.o
CC /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset.mod.o
CC /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm.mod.o
CC /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia.mod.o
LD [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-modeset.ko
LD [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-drm.ko
LD [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia-uvm.ko
LD [M] /tmp/selfgz1754/NVIDIA-Linux-x86_64-367.44/kernel/nvidia.ko
-> done.
-> Kernel module compilation complete.
-> Kernel messages:
[ 223.791024] scsi host4: usb-storage 1-1:1.0
[ 223.791155] usbcore: registered new interface driver usb-storage
[ 223.797668] usbcore: registered new interface driver uas
[ 224.793065] scsi 4:0:0:0: Direct-Access Generic Flash Disk 8.07 PQ: 0 ANSI: 4
[ 224.793262] sd 4:0:0:0: Attached scsi generic sg1 type 0
[ 224.794053] sd 4:0:0:0: [sdb] 32768000 512-byte logical blocks: (16.7 GB/15.6 GiB)
[ 224.794712] sd 4:0:0:0: [sdb] Write Protect is off
[ 224.794715] sd 4:0:0:0: [sdb] Mode Sense: 23 00 00 00
[ 224.795416] sd 4:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 224.798932] sdb: sdb1
[ 224.801167] sd 4:0:0:0: [sdb] Attached SCSI removable disk
[ 262.543833] nvidia-modeset: Freed GPU:0 (GPU-c3c683f5-6d2c-61b4-4de2-737fb792d45f) @ PCI:0000:01:00.0
[ 346.848976] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 346.854114] nvidia-modeset: Unloading
[ 346.859013] nvidia-nvlink: Unregistered the Nvlink Core, major device number 246
[ 385.640974] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=none,decodes=none:owns=io+mem
[ 385.641047] nvidia-nvlink: Nvlink Core is being initialized, major device number 246
[ 385.641058] NVRM: loading NVIDIA UNIX x86_64 Kernel Module 367.44 Wed Aug 17 22:24:07 PDT 2016
[ 385.648267] nvidia-uvm: Loaded the UVM driver in 8 mode, major device number 245
[ 385.649842] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms 367.44 Wed Aug 17 21:54:40 PDT 2016
[ 385.651992] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[ 385.653843] [drm] [nvidia-drm] [GPU ID 0x00000100] Unloading driver
[ 385.655856] nvidia-modeset: Unloading
[ 385.658089] nvidia-uvm: Unloaded the UVM driver in 8 mode
[ 385.659902] nvidia-nvlink: Unregistered the Nvlink Core, major device number 246
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA's 32-bit compatibility libraries? (Answer: No)
-> Will install GLVND GLX client libraries.
-> Uninstalling the previous installation with /bin/nvidia-uninstall.
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: '/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh'...
Checking for libglvnd installation.
Checking libGLdispatch...
Can't load library libGLdispatch.so.0: libGLdispatch.so.0: cannot open shared object file: No such file or directory
Will install libglvnd libraries.
-> Searching for conflicting files:
-> done.
-> Installing 'NVIDIA Accelerated Graphics Driver for Linux-x86_64' (367.44):
executing: '/sbin/ldconfig'...
executing: '/sbin/depmod -a '...
-> done.
-> Driver file installation is complete.
-> Running post-install sanity check:
-> done.
-> Post-install sanity check passed.
-> Running runtime sanity check:
-> done.
-> Runtime sanity check passed.
-> Would you like to run the nvidia-xconfig utility to automatically update your X configuration file so that the NVIDIA X driver will be used when you restart X? Any pre-existing X configuration file will be backed up. (Answer: No)
-> Installation of the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version: 367.44) is now complete. Please update XF86Config or xorg.conf file as appropriate; see the file /usr/share/doc/NVIDIA_GLX-1.0/README.txt for details.
Thanks in advance for your help
Kind regards.
