Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 20.04
Topic Description
Detailed Description
I am encountering issues when trying to spawn and destroy a robot (prim) during simulation, specifically related to the ArticulationView. When a prim is destroyed, the associated ArticulationView is still being referenced, causing errors and bugs. My goal is to dynamically spawn and destroy a prim during the simulation without needing to reset it.
Steps to Reproduce
- Download and unzip this test.zip (9.1 MB).
- Run
path/to/isaac-sim-4.2.0/python.sh test.py. - The error occurs at line 45 in
test.py.
Error Messages
[9.807s] Running simulation...
[10.272s] Initializing ArticulationView /tiago_dual/tiago_dual_articulation_view for /tiago_dual/tiago_dual
[10.273s] Added ArticulationView /tiago_dual/tiago_dual_articulation_view
[10.277s] Initializing ArticulationView /dlr_kitchen/root_joint_articulation_view for /dlr_kitchen/root_joint
[10.277s] Added ArticulationView /dlr_kitchen/root_joint_articulation_view
[10.281s] Initializing ArticulationView /panda/root_joint_articulation_view for /panda/root_joint
[10.282s] Added ArticulationView /panda/root_joint_articulation_view
[10.433s] Test 1 complete
2024-10-24 11:07:41 [10,373ms] [Warning] [omni.physx.tensors.plugin] prim '/tiago_dual/tiago_dual' was deleted while being used by a link in a tensor view class. The physics.tensors simulationView was invalidated.
[10.444s] Removed ArticulationView /tiago_dual/tiago_dual_articulation_view
[10.453s] Removed ArticulationView /dlr_kitchen/root_joint_articulation_view
[10.479s] Removed ArticulationView /panda/root_joint_articulation_view
2024-10-24 11:07:41 [10,431ms] [Warning] [omni.usd] Coding Error: in _Get at line 3003 of /builds/omniverse/usd-ci/USD/pxr/usdImaging/usdImaging/delegate.cpp -- Failed verification: ' prim '
[10.560s] Test 2 complete
[11.012s] Initializing ArticulationView /panda/root_joint_articulation_view for /panda/root_joint
File "/home/giangnguyen/Downloads/test/test.py", line 79, in <module>
step_simulation(with_panda=True)
File "/home/giangnguyen/Downloads/test/test.py", line 65, in step_simulation
set_articulation_views()
File "/home/giangnguyen/Downloads/test/test.py", line 45, in set_articulation_views
articulation_view.initialize(world.physics_sim_view)
File "/home/giangnguyen/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/articulations/articulation_view.py", line 384, in initialize
default_actions = self.get_applied_actions(clone=True)
File "/home/giangnguyen/.local/share/ov/pkg/isaac-sim-4.2.0/exts/omni.isaac.core/omni/isaac/core/articulations/articulation_view.py", line 1687, in get_applied_actions
joint_positions = self._physics_view.get_dof_position_targets()
File "/home/giangnguyen/.local/share/ov/pkg/isaac-sim-4.2.0/extsPhysics/omni.physics.tensors/omni/physics/tensors/impl/api.py", line 521, in get_dof_position_targets
raise Exception("Failed to get DOF position targets from backend")
Exception: Failed to get DOF position targets from backend
2024-10-24 11:07:41 [10,967ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2024-10-24 11:07:41 [10,967ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Core' for removal
2024-10-24 11:07:42 [11,040ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
Screenshots or Videos
Additional Information
What I’ve Tried
I have tried explicitly setting the articulation_view to None and deleting it using del articulation_view, but the issue still occurs. Additionally, using add and remove_object from world.scene doesn’t seem to make much difference in the behavior. Whether these methods are used or not, the code functions the same, with the only benefit being that I can use the scene as a container for storing data.
