I have 2 mains problems.
I use my jetson nano via VNC.
When I used a keyboard on the Jetson I didn’t have any problems but now via VNC the keyboard is in QWERTY but my keyboard is in AZERTY.
On the Jetson Nano my keyboard is in FR but I still have my keyboard in QWERTY.
I try to change this in the settings, it didn’t worked,
“sudo dpkg-reconfigure keyboard-configuration” doesn’t work.
“sudo loadkeys fr” doesn’t work.
“setxkbmap fr” doesn’t work.
Is anyone had the same problem?
Also via VNC I can’t change my resolution so the window is really small to work with.
I tried to use “xrandr” and setting the reolustion higher (for example 1440x1080) but the console says that it’s not a resolution available. But When I connect the Jetson to a display it is possible to go up to 1920x1080.
Does someone know how to change the resolution on the Jetson Nano?
Yes I followed this.
I did the instructions on the readme on the jetson nano but it was not enough : VNC didn’t work, and there was a bug, in the paramaters of Ubuntu it was impossible to go in the parameters for remote desktop.
Actually I wanted to connect via xdrp so I installed xdrp on the jetson nano and I tried to connect with my laptop via windows 10 remote desktop, I enter the IP address, a new windows with xorg is proposed, I enter the name of the jetson and the password, I can see the Nvidia logo for few seconds then the window is shutting itself.
That’s why I used vnc.
I followed your link and I modified xorg.conf but now the jetson wont start, I get this (cf photo)
