Public key error while flashing jetson agx orin
Hi
I am trying to flash my jetson agx orin dev kit 32 GB but I am getting public key error during the process. I am attaching log files for your reference kindly find the attached document.
SDKM_logs_JetPack_5.1_(rev._1)_Linux_for_Jetson_AGX_Orin_modules_2023-03-28_12-31-32.zip (82.6 KB)
Hi alok5844,
There is error in your host apt repositories.
In the log, we could see following messages:
12:31:50.864 - error: E: The repository ‘https://packagecloud.io/AtomEditor/atom/any any InRelease’ is not signed.
12:31:50.864 - info: Event: undefined - error is: E: The repository ‘https://packagecloud.io/AtomEditor/atom/any any InRelease’ is not signed.
12:31:50.864 - error: N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
12:31:50.864 - info: Event: undefined - error is: N: Updating from such a repository can’t be done securely, and is therefore disabled by default.
12:31:50.864 - error: N: See apt-secure(8) manpage for repository creation and user configuration details.
12:31:50.864 - info: Event: undefined - error is: N: See apt-secure(8) manpage for repository creation and user configuration details.
12:31:50.869 - info:
12:31:50.877 - error: command error code: 100
12:31:50.877 - info: Event: - error code is: 1100
12:31:50.877 - error: command terminated with error
12:31:50.879 - error: Install pre check Access to APT repository and ability to install Debian packages with it. verify failed.
12:31:50.880 - info: Precheck is complete: PREREQUISITE_APT_HOST, Duration: 00:00:13
12:31:50.880 - info: Event: Precheck action ended: PREREQUISITE_APT_HOST - 0 - Access to APT repository and ability to install Debian packages with it. - failed
12:31:50.884 - error: Access to APT repository and ability to install Debian packages with it.: Apt repository check failure (1. sudo -S apt-get update && sudo -S apt-get check; 2. dpkg --audit).
Please manually fix the apt repository error first, make sure the following commands pass. Then reinstall with SDK Manager.
  • sudo -S apt-get update && sudo -S apt-get check
  • dpkg --audit
Hi @EdwardZhou
Thanks, I will try and get back to you.
Hi @EdwardZhou
I tried to run, But facing this error(attached below for your reference). Can you please help me ?
Hi alok5844,
These are environment issues and need to be googled to see how to fix each of them one by one.
