HI
PWM 30hz can not be set.
When to do in JETPACK 4.2
echo 0 | sudo tee -a /sys/class/pwm/pwmchip0/unexport
echo 0 | sudo tee -a /sys/class/pwm/pwmchip0/export > /dev/null; sleep 0.5
#SETTING 30Hz
echo 33333333 | sudo tee -a /sys/class/pwm/pwmchip0/pwm0/period > /dev/null; sleep 0.1
tee: /sys/class/pwm/pwmchip0/pwm0/period: Invalid argument
echo 6666666 | sudo tee -a /sys/class/pwm/pwmchip0/pwm0/duty_cycle > /dev/null; sleep 0.1
echo 1 | sudo tee -a /sys/class/pwm/pwmchip0/pwm0/enable > /dev/null
PWM does not work
But
When to do in JETPACK 3.2
#SETTING 30Hz
PWM operation
Regards.
