Unable to set PWM to low frequency
Hi, Nv’s experts:
I encountered some issues during PWM debugging on Jetson thor
Hardware: Custom board
Jetson linux versoin: Jetson_Linux_R38.2.1_aarch64
issue:
  • When I set the frequency to 500Hz, PWM can work normally and the oscilloscope can display waveforms normally.
  • When I set the frequency to 200Hz, the PWM seems to have been successfully set, but the oscilloscope cannot display the waveform.
I tried several different frequencies, and it doesn’t work properly below 480Hz.
Can you give some suggessions.
Some debugging information:
root@upai-pro03:/sys/kernel/debug/bpmp/debug/clk/pwm9# cat possible_parents
pllp_out0 osc
root@upai-pro03:/sys/kernel/debug/bpmp/debug/clk/pwm9# cat parent
osc
root@upai-pro03:/sys/kernel/debug/bpmp/debug/clk/pwm9# cat rate
27000000
root@upai-pro03:/home/nvidia# cd /sys/class/pwm/pwmchip3/
root@upai-pro03:/sys/class/pwm/pwmchip3# echo 0 > export
root@upai-pro03:/sys/class/pwm/pwmchip3# cd pwm0/
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 2000000 > period
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 1000000 > duty_cycle
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 1 > enable
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# busybox devmem 0x810c610000
0x008000D2
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 0 > enable
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 5000000 > period
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 2500000 > duty_cycle
0x0080020E
Hi WellsX,
Could you configure the rate as following to check if it could help?
# echo 10000000 > /sys/kernel/debug/bpmp/debug/clk/pwm9/rate
# cat /sys/kernel/debug/bpmp/debug/clk/pwm9/rate
# echo 0 > export
# cd /sys/class/pwm/pwmchip3/pwm0
# echo 1 > enable
I tried according to your steps, but unfortunately the result is still the same as before. , there is still no waveform on the oscilloscope when the pwm frequency is configured at 200Hz.
At the same time, I further tested that the lowest effective frequency in the current situation is 412Hz.
Log as follows:
root@upai-pro03:/sys/kernel/debug/bpmp/debug/clk/pwm9# cat /sys/kernel/debug/pwm
0: platform/c6a0000.pwm, 1 PWM device
 pwm-0   (pwm-fan             ): requested enabled period: 40000 ns duty: 20549 ns polarity: normal usage_power
1: platform/810c5e0000.pwm, 1 PWM device
 pwm-0   ((null)              ): period: 0 ns duty: 0 ns polarity: normal
2: platform/810c5f0000.pwm, 1 PWM device
3: platform/810c600000.pwm, 1 PWM device
 pwm-0   ((null)              ): period: 1000000 ns duty: 500000 ns polarity: normal
4: platform/810c610000.pwm, 1 PWM device
5: platform/810c620000.pwm, 1 PWM device
6: platform/810c5c0000.tachometer, 1 PWM device
root@upai-pro03:/sys/kernel/debug/bpmp/debug/clk/pwm9# echo 10000000 > ./rate
10800000
root@upai-pro03:/sys/kernel/debug/bpmp/debug/clk/pwm9# cd /sys/class/pwm/pwmchip4
root@upai-pro03:/sys/class/pwm/pwmchip4# ls
device  export  npwm  power  subsystem  uevent  unexport
root@upai-pro03:/sys/class/pwm/pwmchip4# echo 0 > export
device  export  npwm  power  pwm0  subsystem  uevent  unexport
root@upai-pro03:/sys/class/pwm/pwmchip4# cd pwm0/
root@upai-pro03:/sys/class/pwm/pwmchip4/pwm0# echo 5000000 > period
root@upai-pro03:/sys/class/pwm/pwmchip4/pwm0# echo 2500000 > duty_cycle
root@upai-pro03:/sys/class/pwm/pwmchip4/pwm0# echo 1 > enable
root@upai-pro03:/sys/class/pwm/pwmchip4/pwm0# busybox devmem 0x810c610000
0x0080020E
Why it is pwmchip3 from original post but it is pwmchip4 in your latest reply?
May I know what’s the exact PWM interface your are verifying?
Do you want to use 0x810c610000.pwm?
Please share the result of ls -l /sys/class/pwm on your board.
The reason why pwnchip changed from 3 to 4 is because I added a new PWM node(addr:810c600000) in dts. Now i deleted it again, it reverted to pwnchip3. I’m sure that the test steps are correct.
Yes, i want to use 810c610000.pwm, and the result of ls -l /sys/class/pwm is:
nvidia@upai-pro03:~$ ls -l /sys/class/pwm
total 0
lrwxrwxrwx 1 root root 0 Jul  2 14:04 pwmchip0 -> ../../devices/platform/bus@0/c6a0000.pwm/pwm/pwmchip0
lrwxrwxrwx 1 root root 0 Jul  2 14:04 pwmchip1 -> ../../devices/platform/bus@0/810c5e0000.pwm/pwm/pwmchip1
lrwxrwxrwx 1 root root 0 Jul  2 14:04 pwmchip2 -> ../../devices/platform/bus@0/810c5f0000.pwm/pwm/pwmchip2
lrwxrwxrwx 1 root root 0 Jul  2 14:04 pwmchip3 -> ../../devices/platform/bus@0/810c610000.pwm/pwm/pwmchip3
lrwxrwxrwx 1 root root 0 Jul  2 14:04 pwmchip4 -> ../../devices/platform/bus@0/810c620000.pwm/pwm/pwmchip4
lrwxrwxrwx 1 root root 0 Jul  2 14:04 pwmchip5 -> ../../devices/platform/bus@0/810c5c0000.tachometer/pwm/pwmchip5
Okay, can you share the result of rate, parent, possible_parents, period, duty_cycle and enable after you run the following commands for 810c610000.pwm?
And also measure the signal from scope.
As you can generate 500Hz PWM, could you generate other rate like 400Hz and 300Hz?
Please refer to the test log below:
Set to 200Hz,no waveform output on the scope:
root@upai-pro03:/sys/class/pwm/pwmchip3# ls -l /sys/class/pwm
total 0
lrwxrwxrwx 1 root root 0 Dec 15 10:07 pwmchip5 -> ../../devices/platform/bus@0/810c5c0000.tachometer/pwm/pwmchip5
root@upai-pro03:/sys/class/pwm/pwmchip3# echo 10000000 > /sys/kernel/debug/bpmp/debug/clk/pwm9/rate
root@upai-pro03:/sys/class/pwm/pwmchip3# cat /sys/kernel/debug/bpmp/debug/clk/pwm9/rate
10800000
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# cat /sys/kernel/debug/bpmp/debug/clk/pwm9/rate
10800000
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# cat /sys/kernel/debug/bpmp/debug/clk/pwm9/parent
osc
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# cat /sys/kernel/debug/bpmp/debug/clk/pwm9/possible_parents
pllp_out0 osc
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# ls
capture  duty_cycle  enable  period  polarity  power  uevent
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# cat period
5000000
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# cat duty_cycle
2500000
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# cat enable
1
bash: echo: write error: Invalid argument
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# cd ..
root@upai-pro03:/sys/class/pwm/pwmchip3# echo 0 > unexport
When I set a frequency below 412Hz, the period cannot be set again, i must reboot the target, and retest follow the steps.
Set to 500Hz/412Hz/400Hz, 500Hz and 412Hz have output,400Hz does not have output on the scope:
total 0
lrwxrwxrwx 1 root root 0 Dec 15 10:11 pwmchip5 -> ../../devices/platform/bus@0/810c5c0000.tachometer/pwm/pwmchip5
10800000
10800000
osc
pllp_out0 osc
2000000
1000000
1
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 2427184 > period
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 1213592 > duty_cycle
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 2500000 > period
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 1250000 > duty_cycle
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 200000 > period
The set frequency does not match the actual measured frequency. I guess it is related to the clock source being changed, because 27000000/10800000=500/200=2.5
What do you mean about the “clock source being changed”?
The following rate has been configured to 10.8MHz?
10800000
It seems you are using osc as parent clock.
Have you tried using pllp_out0 instead?
The previous test actually showed that when the parent clock is reconfigured, the actual output frequency of PWM can also be changed. For example, I changed the parent clock to 600000. and I actually wanted a 10Hz PWM wave, I needed to set the period to 2222222 because 27000000/600000=450/10=45, and the result is that I can obtain a 10Hz waveform on the scope.
In this case, I can obtain the frequency I want, but the actual configuration does not match the obtained one, and manual calculation is required. I want to know how to make the configuration value the same as the obtained value. Additionally, how to automatically configure the parents clock when the system is powered on.
I will try pllp_out0 as parent clock next.
Do you mean that you can get 10Hz waveform?
If so, why you can not get 200Hz?
How did you get 27000000 here?
Is it the default rate(i.e. /sys/kernel/debug/bpmp/debug/clk/pwm9/rate) before you modify it manually?
Yes, the 27000000 is the default value of /sys/kernel/debug/bpmp/debug/clk/pwm9/rate, and If I use the default 27000000, I cannot obtain a 200Hz waveform. But now I can obtain an output of 200Hz waveform by changing the value of Rate.
Also, I want to know about the two questions mentioned earlier:
  1. How to automatically configure the parents clock when the system is powered on.
  2. How to make the configured frequency consistent with the actual frequency displayed on Scope.
It can be configured through BPMP-DTB which will be loaded during boot up.
Please share the BPMP-DTB used in your case.
I have to check this with internal team.
Please share the commands you run to output 200Hz PWM and also the signal from scope.
The commands:
root@upai-pro03:/sys/class/pwm/pwmchip3# echo 600000 > /sys/kernel/debug/bpmp/debug/clk/pwm9/rate
600000
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 111112 > period
root@upai-pro03:/sys/class/pwm/pwmchip3/pwm0# echo 55556 > duty_cycle
Hi, is there any further good news?
Please also provide bpmp-dtb used in your case.
If you don’t know the exact file, you can simply check the flash log and search for bpfdtbfile.
The attachment is the BPMP-DTB file.
upai-pro03-bpmp-3834-0008-4071-xxxx.txt (16.8 KB)
Please simply write a custom service and script to configure it during boot up.
e.g.
/etc/systemd/system/setup_pwm9.service:
[Unit]
Description=Setup PWM9 clock at boot
After=multi-user.target
[Service]
Type=oneshot
ExecStart=/usr/local/sbin/setup_pwm9.sh
[Install]
WantedBy=multi-user.target
setup_pwm9.sh:
#!/bin/bash
set -e
echo 0 > export
cd pwm0
echo 1      > enable
