I download sdkmanager_1.1.0-6343_amd64.deb,and install it to flash XavierNX system,I delete JetPack_4.4_DP_Linux_DP_JETSON_XAVIER_NX/Linux_for_Tegra folder after flash finished.And then I run sdkmanager to flash NX system again,I got error as bellow:
14:03:23 INFO : Flash Jetson Xavier NX : sudo ./flash.sh jetson-xavier-nx-devkit-emmc mmcblk0p1
14:03:23 ERROR : Flash Jetson Xavier NX : sudo: ./flash.sh: command not found
14:03:23 ERROR : Flash Jetson Xavier NX : [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FLASH_XAVIER_NX_WITH_OS_IMAGE_COMP.sh; [error]: exit status 1
I can understand this ERROR info, flash.sh and all the files onder Linux_for_Tegra folder is deleted.
But Jetson OS image status always show “OS image ready” on SDKmanager, what should I do to re-make the OS image?
