I got the error when I try to Flash Jetson OS(JetPack_4.2.1_Linux_GA_P3310), my environment is:
- SDK Manager 0.9.14.4954
- HOST Ubuntu 16.04 LTS
I deleted all SDK manager download files before, and then started from scratch, I wonder if it has any impact.
The terminal log:
10:22:34 INFO : Flash Jetson TX2 : current working directory is /home/work/nvidia/nvidia_sdk/JetPack_4.2.1_Linux_GA_P3310/Linux_for_Tegra
10:22:34 INFO : Flash Jetson TX2 : exec_command: sudo ./flash.sh jetson-tx2 mmcblk0p1
10:22:34 ERROR : Flash Jetson TX2 : sudo: ./flash.sh: command not found
10:22:34 INFO : Flash Jetson TX2 : exit status 1
10:22:34 INFO : Flash Jetson TX2 : [ Component Install Finished with Error ]
10:22:34 INFO : Flash Jetson TX2 : [ 32.00 KB used. Disk Avail: 57.54 GB ]
10:22:34 INFO : Flash Jetson TX2 : [ NV_L4T_FLASH_TX2_WITH_OS_IMAGE_COMP Install took 1s ]
10:22:34 ERROR : Flash Jetson TX2 : Run commands failed at step Install: command sudo ./flash.sh jetson-tx2 mmcblk0p1 finished with error
10:22:34 ERROR : Flash Jetson TX2 : command terminated with error
