Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.6.1.8175
1.6.0.8170
other
Host Machine Version
native Ubuntu 18.04
other
This is a continuation of the following topic:
I’ve set up all I need and the first header send by CarMaker was received by DriveWorks with a content noting, that CarMaker is connected as a data transmitter. However, the length variable is greater zero (=64 bytes) only in the functions _dwRadarDecoder_validatePacket and _dwRadarDecoder_synchronize, in _dwRadarDecoder_decodePacket length is always zero.
I would like to confirm the received data and process it in _dwRadarDecoder_decodePacket, but I don’t know how it’s developed in the background to forward the buffer and length values from _dwRadarDecoder_validatePacket or _dwRadarDecoder_synchronize to _dwRadarDecoder_decodePacket?
Following code is currently implemented (see comments for details - especially for _dwRadarDecoder_decodePacket):
#include <dw/sensors/plugins/radar/RadarDecoder.h>
#include <dw/sensors/plugins/radar/RadarPlugin.h>
#include <iostream>
dwStatus _dwRadarDecoder_initialize () {
// Indicator, which function gets executed:
std::cout << "1" << std::endl;
return DW_SUCCESS;
dwStatus _dwRadarDecoder_release() {
std::cout << "2" << std::endl;
return DW_SUCCESS;
dwStatus _dwRadarDecoder_decodePacket (
dwRadarScan * output,
const uint8_t * buffer,
const size_t length,
const dwRadarScanType scanType )
(void) output;
(void) scanType;
// For unknown reasons "buffer" is always empty declared by "length" equal to zero for every loop?
std::cout << "Buffer: " << *buffer << " - Length: " << length << std::endl;
std::cout << "3" << std::endl;
// When length is greater than zero, output the buffer content to screen
// and abort the application before filling out the shell with new lines.
// In this way I want to see if it ever happens that length is greater than
// zero, which indicates that data is existing to be decoded.
if (length > 0)
for (size_t i = 0; i < length; i++)
std::cout << buffer[i];
std::cout << std::endl;
abort();
return DW_SUCCESS;
// Setting up all constants and properties of the sensor.
// Only detections will be received, hence no other data is required to be set up.
dwStatus _dwRadarDecoder_getConstants(_dwRadarDecoder_constants * constants)
constants->properties.supportedScanTypes[DW_RADAR_RETURN_TYPE_DETECTION][DW_RADAR_RANGE_LONG] = 1;
constants->properties.maxReturnsPerScan[DW_RADAR_RETURN_TYPE_DETECTION][DW_RADAR_RANGE_LONG] = 2000;
constants->properties.scansPerSecond=1;
constants->properties.isDecodingOn=1;
constants->properties.numScanTypes=1;
constants->properties.packetsPerScan = 1;
constants->properties.inputPacketsPerSecond = 0;
constants->headerSize = 64;
constants->maxPayloadSize = 2048;
constants->vehicleStateSize = 0;
constants->mountSize = 0;
std::cout << "4" << std::endl;
return DW_SUCCESS;
dwStatus _dwRadarDecoder_synchronize (
size_t * remaining)
(void) buffer; // Currently not used
// Set remaining data to zero, when first message of 64 bytes is received.
// Is this required to provide the data to the "_dwRadarDecoder_decodePacket(...)" function?
// This will be correctly set when the first message is received from CarMaker
if (length == 64) {
*remaining = 0;
std::cout << "5" << std::endl;
return DW_SUCCESS;
dwStatus _dwRadarDecoder_validatePacket (
const uint8_t* buffer,
dwRadarScanType* scanType)
(void) length; // Currently not used
// Required, otherwise segmentation fault.
scanType->range = DW_RADAR_RANGE_LONG;
scanType->returnType = DW_RADAR_RETURN_TYPE_DETECTION;
std::cout << "6" << std::endl;
return DW_SUCCESS;
bool _dwRadarDecoder_isScanComplete (
dwRadarScanType scanType,
const uint8_t ** buffer,
size_t * length,
size_t numPackets
(void) scanType; // Currently not used
// Tried to set up the numPackets in the hope that
// _dwRadarDecoder_decodePacket(...) will be provided with data.
// Had no effect.
numPackets = 1;
std::cout << "7" << std::endl;
return true;
dwStatus _dwRadarDecoder_encodeVehicleState (
uint8_t * buffer,
const size_t maxOutputSize,
const dwRadarVehicleState * packet
(void) maxOutputSize; // Currently not used
(void) packet; // Currently not used
std::cout << "8" << std::endl;
return DW_SUCCESS;
dwStatus _dwRadarDecoder_encodeMountPosition (
uint8_t * buffer,
const dwRadarMountPosition * packet
std::cout << "9" << std::endl;
return DW_SUCCESS;
When exactly will the data located in buffer with the buffer length indicator “length” be forwarded to the _dwRadarDecoder_decodePacket function? What are the requirements?
I’m trying to understand the concept and structure of the decoder step by step, since the documentation doesn’t explain this in detail.
