Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.1.8928
other
Host Machine Version
native Ubuntu 18.04
other
some time ago we wrote a custom Radar sensor plugin and it’s working fine with the radar replay sample.
But when trying to record data from our radar there are errors.
I debugged with the sample_record application and saw, that
status = dwSensorSerializer_serializeDataAsync(data, size, serializer);
throws the exception when inserting data from our plugin.
Here’s the complete output:
[09-12-2021 09:47:40] Platform: Detected Generic x86 Platform
[09-12-2021 09:47:40] TimeSource: monotonic epoch time offset is 1639042230718887
[09-12-2021 09:47:40] Platform: number of GPU devices detected 1
[09-12-2021 09:47:40] Platform: currently selected GPU device discrete ID 0
[09-12-2021 09:47:40] SDK: Resources mounted from /usr/local/driveworks/data/
[09-12-2021 09:47:40] Initialize DriveWorks SDK v2.2.3136
[09-12-2021 09:47:40] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
[09-12-2021 09:47:40] SensorFactory::createSensor() -> radar.custom, decoding=false,decoder-path=/home/nvidia/dw_samples/build/src/sensors/plugins/radar_plugin_ars408/libradar_plugin_ars408.so,dbc-path=/home/nvidia/dw_samples/fast_config/dbc-and-can/ARS408/dbc/ars408.dbc,device=can-radar,can-protocol=can.socket
createSensor: Return type configuration not specified, setting default (cluster)
[09-12-2021 09:47:40] SensorFactory::createSensor() -> can.socket, device=can-radar
[09-12-2021 09:47:40] CANSocket: Cannot get current state of hardware time stamping: ioctl(SIOCGHWTSTAMP, can-radar) -> No such file or directory
[09-12-2021 09:47:40] CANSocket: software based timestamps will be used for can-radar
CAN DBC parsed results:
numMessages: 16
numSignals: 136
numSignalsExtendedValueType: 0
numIgnoredMessages: 0
numInvalidMessages: 0
numInvalidSignals: 0
numInvalidSignalsExtendedValueType: 0
[09-12-2021 09:47:40] CANSocket: ioctl(SIOCSHWTSTAMP, can-radar) failed -> No such file or directory. Cannot enable HW timestamps, try with root user.
[09-12-2021 09:47:40] CANSocket: use SW based timestamps for can-radar
[09-12-2021 09:47:40] CANSocket: started can-radar
[09-12-2021 09:47:43] Driveworks exception thrown: DW_INVALID_ARGUMENT: SensorSerializerByte: error updating seek table
There seems to be a problem with the data for the recorder, but again, it’s working fine in the radar replay sample.
One strange thing though:
During development of the plugin I had to work around a “wrong” size of data returned in pushData:
dwStatus pushData(const uint8_t* data, const size_t size, size_t* lenPushed)
//FIXME: Size from the framework is always 12 bytes bigger than it should be.
// We just subtract 12 and it is working. Find out how this is supposed
// to be done.
m_buffer.enqueue(data, size-12);
*lenPushed = size;
return DW_SUCCESS;
After this “fix”, the whole plugin started to work properly with the replay sample. I could imagine, that this could be the cause of the recording problem. However, I don’t know how to fix it.
For reference, here’s my readRawData()method:
dwStatus readRawData(const uint8_t** data, size_t* size, dwTime_t* timestamp, dwTime_t /*timeout_us*/)
dwCANMessage result;
dwStatus status = DW_SUCCESS;
status = dwSensorCAN_readMessage(&result, 1000, m_ars_408Radar);
if (status != DW_SUCCESS)
return status;
dwTime_t now{};
status = dwContext_getCurrentTime(&now, m_ctx);
std::cerr << "readRawData: error getting timestamp" << std::endl;
return DW_SAL_SENSOR_ERROR;
radarMessage* message = nullptr;
bool ok = m_slot.get(message);
if (!ok)
std::cerr << "readRawData: Read raw data, slot not empty\n";
return DW_BUFFER_FULL;
message->timestamp = now;
message->payload_size = sizeof(dwCANMessage);
message->payload = result;
*data = reinterpret_cast<uint8_t*>(message);
*size = sizeof(radarMessage);
*timestamp = now;
return DW_SUCCESS;
The radarMessage is defined as follows:
/// Encapsulated radar CAN message with header.
#pragma pack(push, 1) // Makes sure you have consistent structure packings.
typedef struct
uint32_t payload_size;
dwTime_t timestamp;
dwCANMessage payload;
} radarMessage;
#pragma pack(pop)
I tried some things with packing etc, but couldn’t find out where the 12 bytes came from.
Are the two things related? What am I doing wrong?
Thanks in advance.
EDIT: I changed the recording sample to subtract also the 12 bytes… So the twelve byte problem should also solve the recording problem…
