I am trying to use the Raspberry Pi v2.1 Camera Module with the J90LC Carrier Board and Jetson TX1.
Initially I was using the L4T 28.2 but as per recommendation from Auvidea I started using L4T 24.2.1 so that I could install the appropriate firmware (V2.3) for TX1.
I have added the following instructions to my /etc/rc.local to execute them at startup:
echo 148 > /sys/class/gpio/export
echo out > /sys/class/gpio/gpio148/direction
echo 1 > /sys/class/gpio/gpio148/value
echo 0 > /sys/class/gpio/gpio148/value
After this, I can see that gpio148 is already exported when I start the TX1 on the J90LC.
Below is the output of the command: sudo i2cdetect -y -r 2
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: 50 – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
As I understand, if everything is fine now, I should be able to see a video device when I run the command: ls -l /dev/video*
But I cannot see any device yet for me to open a gstreamer pipeline and capture images/videos.
Am I missing something?
Do I need to install something else on the Jetson?
Thanks and regards,
Ritvik
