I wanted to try the Raspberry Pi HQ camera module on my Jetson Nano Development Kit.
I run Jetpack 4.6.2. After configuring the CSI ports using the command:
$ sudo /opt/nvidia/jetson-io/jetson-io.py
The camera will show the following output when booted:
[ 1.782507] imx477 7-001a: tegracam sensor driver:imx477_v2.0.6
[ 2.082957] imx477 7-001a: imx477_board_setup: error during i2c read probe (-121)
[ 2.090526] imx477 7-001a: board setup failed
[ 2.095026] imx477: probe of 7-001a failed with error -121
[ 2.095559] imx477 8-001a: tegracam sensor driver:imx477_v2.0.6
[ 2.395946] imx477 8-001a: imx477_board_setup: error during i2c read probe (-121)
[ 2.403504] imx477 8-001a: board setup failed
[ 2.407966] imx477: probe of 8-001a failed with error -121
I also found these drivers but they only work for jetpack 4.4.* and 4.5: Raspberry Pi HQ camera IMX477 Linux driver for Jetson - RidgeRun Developer Wiki
But they state ‘a resistor labeled as R8 must be removed’ due to required voltage.
When I remove the resistor will this work or do I still need to install other drivers?
Thanks in advance!
