How to use the Raspberry Pi HQ Camera (IMX477) on Jetpack 4.6
I have configured the CSI connector using Jetson-IO tool but I want to know how to run the camera (if possible) without the hardware modification as mentioned here
They have given the steps for J4.5 and I’m not sure if it would be the same when using J4.6
This is what I get at boot:
hello anshul_sood,
you’ve already done the configuration to detect IMX477, however, there’s probing issue while device registrations.
in order to verify both software/hardware status, the quickest way is using the previous release, i.e. JetPack-4.5, thanks
Would testing on J4.5 mean that I would have to remove the R8 resistor as mentioned on ridgegun website?
hello anshul_sood,
you should contact with sensor vendor for confirmation, thanks
You have to.
Testing with Jetson nano and Xavier NX, it works pretty well.
