Does Jetson Orin Nano ISP pipline support RAW8?
Is there any documentation I should refer to?
hello t.kato1,
it’s supported, however, may I also have more details for running with Raw8 sensors.
you may also refer to Orin TRM.
please also contact with Jetson Camera Partners, https://developer.nvidia.com/embedded/jetson-partner-supported-cameras?t-1_supported-jetson-products=Orin
Hi JerryChang,
Thank you for your prompt reply.
Our camera module products output in RAW8 format, so we wanted to know if Jetson Orin Nano ISP supports RAW8.
hello t.kato1,
you can only use the v4l2 standard IOCTL to fetch Raw8 buffers,
however, libargus (through ISP) doesn’t support with Raw8, and we don’t have plan to support Raw8.
Hi JerryChang,
I just want to make sure I understood you correctly.
So RAW8 cannot currently use an ISP?
yes. it’s not supported.
