I have attached a realsense camera to franka hand. I used the realsesne asset from Isaac Assets. When I look at the camera feed, the output is very much zoomed-in. In the attached image, you can see that the camera facing downwards is at a considerable distance from the box and should ideally capture a wide area of the box. However, it only captures the screw.
I think the zoom phenomenon is due to incorrect parameter units. Nevertheless
, I would highly appreciate if you could help me.
