Good evening. I connected REALSENSE to JETSON nano. When I checked the operation with RealSense-Viewer, D435 and T265 worked. (However, T265 was unstable). D435i did not recognize either. Have you got the same symptoms with D435i?
You currently need to patch the kernel for this camera to work.
Full instructions with scripts to run are here…
Thank you very much. I’ll try. It turned out that it doesn’t move without applying a patch.
