Refresh rate not set correctly in 555.58.02 with HDMI
If I set my refresh rate to 144 hz (max refresh rate on my monitor), it gets set to 29 hz instead when using HDMI. Using DisplayPort it works correctly. All other refresh rates work fine also. modeset and fbdev are enabled. Using 550.90.07 works normally as well.
nvidia-bug-report.log.gz (443.5 KB)
Still happens on 560 drivers.
Update: setting nvidia_modeset.hdmi_deepcolor=0 in kernel params fixed this issue, although I can’t use 10-bit color now
