Register a camera device and iso bandwidth %uKB is not available Boot Error
Hello All,
I tried to update imx219 Driver module to L4T R32.2 in my customize Evaluation Board,But Boot now fails with this error:
iso bandwidth %uKB is not available, client
and reboot it later any secend…
it Works OK with the older JetPack 3 releases!!
my DTS module file is:
tegra186-my-camera-config-a00.dtsi
/* camera control gpio definitions */
	host1x {
		vi@15700000 {
			num-channels = <1>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					vi_in0: endpoint {
						port-index = <2>;
						bus-width = <2>;
						remote-endpoint = <&imx219_csi_out0>;
		nvcsi@150c0000 {
			num-channels = <1>;
			channel@0 {
				reg = <0>;
				ports {
					#size-cells = <0>;
					port@0 {
						reg = <0>;
						imx219_csi_in0: endpoint@0 {
							port-index = <2>;
							bus-width = <2>;
							remote-endpoint = <&imx219_phy_out0>;
					port@1 {
						reg = <1>;
						imx219_csi_out0: endpoint@1 {
							remote-endpoint = <&vi_in0>;
	i2c@3180000 {
		imx219_c@10 {
					devnode = "video0";
					compatible = "nvidia,imx219";
					reg = <0x10>;
					physical_w = "5.095";
					physical_h = "4.930";
					sensor_model ="imx219";
					dovdd-supply = <&en_vdd_cam>;
					avdd-reg = "vana";
					dvdd-reg = "vdig";
					iovdd-reg = "dovdd";
			mode0 { /* IMX219_MODE_3264x2464_21FPS */
					mclk_khz = "24000";
					num_lanes = "2";
					tegra_sinterface = "serial_c";
					phy_mode = "DPHY";
					discontinuous_clk = "yes";
					dpcm_enable = "false";
					cil_settletime = "0";
					active_w = "3264";
					active_h = "2464";
					pixel_t = "bayer_rggb";
					readout_orientation = "90";
					line_length = "3448";
					inherent_gain = "1";
					mclk_multiplier = "9.33";
					pix_clk_hz = "182400000";
					gain_factor = "16";
					framerate_factor = "1000000";
					exposure_factor = "1000000";
					min_gain_val = "16"; /* 1.00x */
					max_gain_val = "170"; /* 10.66x */
					step_gain_val = "1";
					default_gain = "16"; /* 1.00x */
					min_hdr_ratio = "1";
					max_hdr_ratio = "1";
					min_framerate = "2000000"; /* 2.0 fps */
					max_framerate = "21000000"; /* 21.0 fps */
					step_framerate = "1";
					default_framerate = "21000000"; /* 21.0 fps */
					min_exp_time = "13"; /* us */
					max_exp_time = "683709"; /* us */
					step_exp_time = "1";
					default_exp_time = "2495"; /* us */
					embedded_metadata_height = "2";
				mode1 { /* IMX219_MODE_3264x1848_28FPS */
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "3264";
					active_h = "1848";
					gain_factor = "16";
					max_framerate = "28000000"; /* 28.0 fps */
					default_framerate = "28000000"; /* 28.0 fps */
				mode2 { /* IMX219_MODE_1920x1080_30FPS */
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "1920";
					active_h = "1080";
					gain_factor = "16";
					max_framerate = "30000000"; /* 30.0 fps */
					default_framerate = "30000000"; /* 30.0 fps */
				mode3 { /* IMX219_MODE_1280x720_60FPS */
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "1280";
					active_h = "720";
					gain_factor = "16";
					max_framerate = "60000000"; /* 60.0 fps */
					default_framerate = "60000000"; /* 60.0 fps */
				mode4 { /* IMX219_MODE_1280x720_120FPS */
					mclk_khz = "24000";
					num_lanes = "2";
					phy_mode = "DPHY";
					active_w = "1280";
					active_h = "720";
					pix_clk_hz = "169600000";
					gain_factor = "16";
					max_framerate = "120000000"; /* 120.0 fps */
					default_framerate = "120000000"; /* 120.0 fps */
					ports {
						#size-cells = <0>;
						port@0 {
							reg = <0>;
							imx219_phy_out0: endpoint {
								port-index = <2>;
								bus-width = <2>;
								remote-endpoint = <&imx219_csi_in0>;
	tegra-camera-platform {
		compatible = "nvidia, tegra-camera-platform";
		* Physical settings to calculate max ISO BW
		* num_csi_lanes = <>;
		* Total number of CSI lanes when all cameras are active
		* max_lane_speed = <>;
		* Max lane speed in Kbit/s
		* min_bits_per_pixel = <>;
		* Min bits per pixel
		* vi_peak_byte_per_pixel = <>;
		* Max byte per pixel for the VI ISO case
		* vi_bw_margin_pct = <>;
		* Vi bandwidth margin in percentage
		* max_pixel_rate = <>;
		* Max pixel rate in Kpixel/s for the ISP ISO case
		* isp_peak_byte_per_pixel = <>;
		* Max byte per pixel for the ISP ISO case
		* isp_bw_margin_pct = <>;
		* Isp bandwidth margin in percentage
		num_csi_lanes = <2>;
		max_lane_speed = <1500000>;
		min_bits_per_pixel = <10>;
		vi_peak_byte_per_pixel = <2>;
		vi_bw_margin_pct = <25>;
		isp_peak_byte_per_pixel = <5>;
		isp_bw_margin_pct = <25>;
		 * The general guideline for naming badge_info contains 3 parts, and is as follows,
		 * The first part is the camera_board_id for the module; if the module is in a FFD
		 * platform, then use the platform name for this part.
		 * The second part contains the position of the module, ex. “rear” or “front”.
		 * The third part contains the last 6 characters of a part number which is found
		 * in the module's specsheet from the vender.
		modules {
			module0 {
				badge = "e3326_front_P5V27C";
				position = "rear";
				orientation = "1";
				drivernode0 {
					pcl_id = "v4l2_sensor";
					devname = "imx219 2-0010";
					proc-device-tree = "/proc/device-tree/i2c@3180000/imx219_c@10";
and my DTS plarform file:
#include <t18x-common-modules/tegra186-my-camera-config-a00.dtsi>
#include "dt-bindings/clock/tegra186-clock.h"
#include <dt-bindings/gpio/tegra186-gpio.h>
#include <dt-bindings/pinctrl/pinctrl-tegra.h>
#define CAM0_RST_L	TEGRA_MAIN_GPIO(R, 5)
#define CAM0_PWDN	TEGRA_MAIN_GPIO(R, 0)
	i2c@3180000 {
		imx219_c@10 {
			/* Define any required hw resources needed by driver */
			/* ie. clocks, io pins, power sources */
			/* mclk-index indicates the index of the */
			/* mclk-name with in the clock-names array */
					clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH1>;
					clock-names = "extperiph1";
					mclk = "extperiph1";
					 reset-gpios = <&tegra_main_gpio CAM0_RST_L GPIO_ACTIVE_LOW>;
					pwdn-gpios = <&tegra_main_gpio CAM0_PWDN GPIO_ACTIVE_HIGH>;
					vana-supply = <&en_vdd_cam_hv_2v8>;
					vdig-supply = <&en_vdd_sys>;
					vif-supply = <&en_vdd_cam>;
	gpio@2200000 {
		camera-control-output-high {
			gpio-hog;
			output-high;
			gpios = <CAM0_RST_L 0>;
			label = "cam0-rst";
i find this message in pre_t19x_iso_plat_register function:
kernel/nvidia/drivers/platform/tegra/mc/isomgr-pre_t19x.c
how can i disable this error??
hello hhami.2040,
according to JetPack Archive, JetPack-3.3 was based-on l4t-r28.2.1 release, which used kernel-4.4.
you might note that JetPack BSP linux kernel has updated to version 4.9 since l4t-r31.x
hence,
please refer to Camera Sensor Drivers Porting Guide to have necessary driver updates.
thanks
