Remove default user created by Linux_for_Tegra/tools/l4t_create_default_user.sh
Hi all,
I’ve created a default user with the the script “Linux_for_Tegra/tools/l4t_create_default_user.sh” before flashing.
Now I would like to change the default user for upcoming boards. How could I remove the old default user?
Thanks,
CH
The quickest way to remove the default user is to delete the Linux_for_Tegra/rootfs/ directory and then reinitialize a clean root filesystem by running the following command as developer guide show:
sudo tar xpf ${SAMPLE_FS_PACKAGE} -C Linux_for_Tegra/rootfs/
Do we have other ways instead of cut and start over?
We’ve also done other customizations and it is not always feasibile by just simply delete the whole directory and reinitialize
What is your command to create the default user? Please provide for review
Do you setup auto login or other argument?
Our custom carrier board is headless, thus we need to use “l4t_create_default_user.sh” to create a default user to bypass the login steps during flashing
Please try below commands to remove user.
$ sudo mount --bind /dev <path_to_Linux_for_Tegra>/rootfs/dev
$ sudo mount --bind /proc <path_to_Linux_for_Tegra>/rootfs/proc
$ sudo mount --bind /sys <path_to_Linux_for_Tegra>/rootfs/sys
$ sudo chroot <path_to_Linux_for_Tegra>/rootfs
(inside of chroot)$ userdel -r <username>
(inside of chroot)$ exit
$ sudo umount <path_to_Linux_for_Tegra>/rootfs/dev
$ sudo umount <path_to_Linux_for_Tegra>/rootfs/proc
$ sudo umount <path_to_Linux_for_Tegra>/rootfs/sys
Since you’ve enabled auto-login, please remove the related settings manually.
These commands are executed on host machine before flashing? Or execute on Orin NX after flashing?
It’s working. Please help to close the case.
Thanks for your support.
CH
Thank you for your feedback.
Please make the solution ✅ so we could close the topics.
