Tegra_Linux_Sample-Root-Filesystem_R32.7.4_aarch64 seems to already have exist user
After install my Xavier board from Linux_for_Tegra
Entering next command sudo ./flash.sh jetson-agx-xavier-devkit mmcblk0p1.
During the first boot the board boots with already exist user and I am not able to login.
with message
Ubuntu 18.04.6 LTS localhost.localdomain ttyTCU0
localhost login: [   20.254913] Bridge firewalling registered
localhost login: nvidia
Password:
From my own experience with different L4T I always had to configure the user manually on first boot.
Whats went wrong?
Some how after a new untar evreything was ok whats went wrong?
It could be your previous rootfs has some user set already but you forgot.
For example, ran l4t_create_default_user.sh already.
I’m assuming this is the exact opposite of what the question sounds like.
If you are reading any documents which say that there is a default login, then the documents are years out of date. There is no default login. Many years back (during L4T R28.x? maybe as early as R24.x) California added a law about shipping computers with default name/password, and so this had to be changed to first boot setup.
You should be able to run this command on the host PC if you want a default password and name (one you’ve created). Just run this once and all flashes from then on have that name/pass:
sudo ./tools/l4t_create_default_user.sh
