Replayer tool lidar errors
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hello, i need help with running the replayer tool. Im trying to visualize recordings from two lidars which where taken with the recorder tool. The replayer tool starts it shows the window with the vehicle, but no pointcloud are visualized (screenshot). The recorded data is fine when i run it with sample_lidar_replay. The sample goes into segmentation fault after a few seconds of running and it prints a lot of warnings something about LidarAccumulator.cpp which im not sure where it is located or even if it is public.
Im running the tool with this command:
__NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia __NV_PRIME_RENDER_OFFLOAD_PROVIDER=NVIDIA-G0 /usr/local/driveworks/tools/replayer/replayer --rig=/home/gabrhelik/nvidia/rig_2lidar_recorded.json
before the replayer i had to put these command because my OpenGL context is on the integrated GPU and it would not work without them.
In the rig i define a vehicle for just the purpose of running the tool. So the values are random.
Error String
gabrhelik@gabrhelik-HP:/usr/local/driveworks/tools/replayer$ __NV_PRIME_RENDER_OFFLOAD=1 __GLX_VENDOR_LIBRARY_NAME=nvidia __NV_PRIME_RENDER_OFFLOAD_PROVIDER=NVIDIA-G0 /usr/local/driveworks/tools/replayer/replayer --rig=/home/gabrhelik/nvidia/rig_2lidar_recorded.json
ProgramArguments: Missing argument ‘dwTracePath’ requested
Replayer: [INFO]: Initialize replayer tool…
Arguments:
–camera=
–can=
–can0dbc=
–can1dbc=
–can2dbc=
–can3dbc=
–candbc=
–gps=
–imu=
–lidar=
–motion-compensation=0
–offscreen=0
–profiling=1
–radar=
–rig=/home/gabrhelik/nvidia/rig_2lidar_recorded.json
–rig-sensor-filter=OS2
–timestamp=
–ultrasonic=
[2025-10-17T16:45:14.271414Z][INFO][tid:0][Platform.cpp:125][NO_TAG] Platform: Detected Generic x86 Platform
[2025-10-17T16:45:14.271448Z][DEBUG][tid:0][TimePOSIX.cpp:63][NO_TAG] TimeSource: monotonic epoch time offset is 1760715800885947
[2025-10-17T16:45:14.274440Z][VERBOSE][tid:0][CVarManager.hpp:618][NO_TAG] Adding variable DW_Base:DW_Version
[2025-10-17T16:45:14.274459Z][VERBOSE][tid:0][CVarManager.hpp:700][NO_TAG] Added variable DW_Base:DW_Version
[2025-10-17T16:45:14.274492Z][VERBOSE][tid:0][Platform.cpp:516][NO_TAG] Platform: number of GPU devices detected 1
[2025-10-17T16:45:14.275020Z][VERBOSE][tid:0][Platform.cpp:359][NO_TAG] Platform: currently selected GPU device 0, Resource Data Dir: trt_08_05_10_03, Arch: tu1xx-discrete
[2025-10-17T16:45:14.275027Z][INFO][tid:0][Platform.cpp:310][NO_TAG] Platform: currently selected GPU device discrete ID 0
[2025-10-17T16:45:14.275701Z][DEBUG][tid:0][Context.cpp:443][NO_TAG] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘./resources’: VirtualFileSystem: Failed to mount ‘./resources/resources.pak’
[2025-10-17T16:45:14.275732Z][DEBUG][tid:0][Context.cpp:443][NO_TAG] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.10/tools/replayer/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.10/tools/replayer/data/resources.pak’
[2025-10-17T16:45:14.275742Z][VERBOSE][tid:0][Context.cpp:375][NO_TAG] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/tools/replayer/../../data
[2025-10-17T16:45:14.275756Z][DEBUG][tid:0][Context.cpp:443][NO_TAG] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.10/tools/replayer/../../data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.10/tools/replayer/../../data/resources.pak’
[2025-10-17T16:45:14.275763Z][VERBOSE][tid:0][Context.cpp:375][NO_TAG] Context::findDataRootInPathWalk data/DATA_ROOT found at: /usr/local/driveworks-5.10/data
[2025-10-17T16:45:14.275775Z][DEBUG][tid:0][Context.cpp:443][NO_TAG] Context::mountResourceCandidateDataPath resource FAILED to mount from ‘/usr/local/driveworks-5.10/data’: VirtualFileSystem: Failed to mount ‘/usr/local/driveworks-5.10/data/resources.pak’
[2025-10-17T16:45:14.275786Z][WARN][tid:0][Context.cpp:412][NO_TAG] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/tools/replayer/../../targets/x86_64-Linux/lib/libdw_base.so.5.10
[2025-10-17T16:45:14.275798Z][WARN][tid:0][Context.cpp:412][NO_TAG] Context::findResourcesPackageInPathWalk: Could not find ./resources/resources.pak in upto 7 parent directories from /usr/local/driveworks-5.10/targets/x86_64-Linux/lib/libdw_base.so.5.10
[2025-10-17T16:45:14.275802Z][DEBUG][tid:0][Context.cpp:501][NO_TAG] SDK: No resources(.pak) mounted, some modules will not function properly
[2025-10-17T16:45:14.368771Z][DEBUG][tid:0][TimePOSIX.cpp:63][NO_TAG] TimeSource: monotonic epoch time offset is 1760715800885947
[2025-10-17T16:45:14.368938Z][INFO][tid:0][Context.cpp:216][NO_TAG] Initialize DriveWorks SDK v5.10.87
[2025-10-17T16:45:14.368946Z][INFO][tid:0][Context.cpp:222][NO_TAG] Release build with GNU 9.3.0 from buildbrain-branch-0-g9a5b4670e12
[2025-10-17T16:45:14.370376Z][DEBUG][tid:0][VisualizationContext.cpp:76][NO_TAG] Initialize DriveWorks VisualizationSDK v5.10.87
[2025-10-17T16:45:14.370395Z][DEBUG][tid:0][GL.cpp:82][NO_TAG] Initialize DriveWorksGL SDK v5.10.87
[2025-10-17T16:45:14.370405Z][DEBUG][tid:0][GL.cpp:94][NO_TAG] GL-SDK: initialize OpenGL
Replayer: [INFO]: Rig overlay directory does not exist: /storage/driveworks/data/vehicle_cfg
Replayer: [INFO]: Loading from rig file ‘/home/gabrhelik/nvidia/rig_2lidar_recorded.json’,
[2025-10-17T16:45:14.427773Z][INFO][tid:0][DatabaseOverlayer.cpp:321][NO_TAG] rig::DatabaseOverlayer: Failed to open a file ‘/tmp/car_vin’ - file likely does not exist - skipping overlay
[2025-10-17T16:45:14.428983Z][INFO][tid:0][DatabaseOverlayer.cpp:321][NO_TAG] rig::DatabaseOverlayer: Failed to open a file ‘/tmp/car_vin’ - file likely does not exist - skipping overlay
[2025-10-17T16:45:14.430091Z][DEBUG][tid:0][DataSpeed.cpp:212][NO_TAG] DataSpeed: constructed
[2025-10-17T16:45:14.430798Z][DEBUG][tid:0][SensorFactory.cpp:182][NO_TAG] SensorFactory::createSensor() → lidar.virtual, device=CUSTOM_EX,hres=1024,decoder-path=/home/gabrhelik/Downloads/NVIDIA-DriveWorks_plugin_v5.10/ouster-driveworks-dist-5.10-x86-arm64/x86/lib/libouster_lidar_plugin_x86.so,data_dir=/home/gabrhelik/nvidia/rec/data/ouster,session_id=run11,file=/home/gabrhelik/nvidia/rec/data/rec/static_dw_2025_10_12_11_18/lidar_OS2.bin,spin-type=ZERO-CROSSING
[2025-10-17T16:45:14.515121Z][WARN][tid:0][LidarAccumulator.cpp:845][NO_TAG] [17-10-2025 18:45:14] [2025-10-17T16:45:14.515144Z][WARN][tid:0][LidarAccumulator.cpp:845][NO_TAG] LidarAccumulator: empty packet, consider using ZERO-CROSSING as a spin boundary. Otherwise a spin boundary might drift.
[2025-10-17T16:45:14.515226Z][WARN][tid:0][LidarAccumulator.cpp:845][NO_TAG] [17-10-2025 18:45:14] [2025-10-17T16:45:14.515232Z][WARN][tid:0][LidarAccumulator.cpp:845][NO_TAG] LidarAccumulator: empty packet, consider using ZERO-CROSSING as a spin boundary. Otherwise a spin boundary might drift.
[2025-10-17T16:46:22.929735Z][WARN][tid:0][LidarAccumulator.cpp:845][NO_TAG] [17-10-2025 18:46:22] [2025-10-17T16:46:22.929742Z][WARN][tid:0][LidarAccumulator.cpp:845][NO_TAG] LidarAccumulator: empty packet, consider using ZERO-CROSSING as a spin boundary. Otherwise a spin boundary might drift.
[2025-10-17T16:46:22.930650Z][WARN][tid:0][LidarAccumulator.cpp:845][NO_TAG] [17-10-2025 18:46:22] [2025-10-17T16:46:22.930666Z][WARN][tid:0][LidarAccumulator.cpp:845][NO_TAG] LidarAccumulator: empty packet, consider using ZERO-CROSSING as a spin boundary. Otherwise a spin boundary might drift.
Logs
Rig File:
“rig”: {
“recorder_storage_map”: {
“lidar:OS0”: “0”,
“lidar:OS2”: “0”
“recorder_storage_paths”: [
“/mnt/persistent/data/rec”
“sensors”: [
“name”: “lidar:OS2”,
“nominalSensor2Rig_FLU”: {
“roll-pitch-yaw”: [0.0, 0.0, 0.0],
“t”: [0.0, 0.0, 0.0]
“parameter”: “device=CUSTOM_EX,hres=1024,decoder-path=/home/gabrhelik/Downloads/NVIDIA-DriveWorks_plugin_v5.10/ouster-driveworks-dist-5.10-x86-arm64/x86/lib/libouster_lidar_plugin_x86.so,data_dir=/home/gabrhelik/nvidia/rec/data/ouster,session_id=run11,file=/home/gabrhelik/nvidia/rec/data/rec/static_dw_2025_10_12_11_18/lidar_OS2.bin,spin-type=ZERO-CROSSING”,
“properties”: null,
“protocol”: “lidar.virtual”
“name”: “lidar:OS0”,
“roll-pitch-yaw”: [0.0, -0.0, 0.463647609],
“t”: [0.0, -0.3, -0.15]
“parameter”: “device=CUSTOM_EX,hres=1024,decoder-path=/home/gabrhelik/Downloads/NVIDIA-DriveWorks_plugin_v5.10/ouster-driveworks-dist-5.10-x86-arm64/x86/lib/libouster_lidar_plugin_x86.so,data_dir=/home/gabrhelik/nvidia/rec/data/ouster,session_id=run12,file=/home/gabrhelik/nvidia/rec/data/rec/static_dw_2025_10_12_11_18/lidar_OS0.bin,spin-type=ZERO-CROSSING”,
“properties”: null,
“vehicle”: {
“valid”: true,
“value”: {
“body”: {
“length”: 4.5,
“width”: 1.8,
“widthWithoutMirrors”: 1.75,
“height”: 1.5,
“boundingBoxPosition”: [0.0, 0.0, 0.75],
“centerOfMass”: [0.0, 0.0, 0.5],
“inertia”: [1000.0, 1000.0, 1000.0],
“mass”: 1500.0
“axleFront”: {
“position”: 1.2,
“track”: 1.55,
“wheelRadiusLeft”: 0.33,
“wheelRadiusRight”: 0.33,
“corneringStiffness”: 50000.0
“axleRear”: {
“position”: 0,
“track”: 1.55,
“actuation”: {
“torqueLUT”: {
“throttlePedalInput”: “0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0”,
“throttleSpeedInput”: “0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0”,
“throttleTorqueOutput”: [
“brakePedalInput”:
“0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0,0.0, 0.0, 0.0”,
“brakeTorqueOutput”:
“effectiveMass”: 1500.0,
“throttleActuatorTimeConstant”: 0.05,
“throttleActuatorTimeDelay”: 0.01,
“brakeActuatorTimeConstant”: 0.1,
“brakeActuatorTimeDelay”: 0.01,
“driveByWireTimeConstant”: 0.05,
“driveByWireTimeDelay”: 0.01,
“driveByWireNaturalFrequency”: 1.0,
“driveByWireDampingRatio”: 0.7,
“isDriveByWireSecondOrder”: false,
“maxSteeringWheelAngle”: 540.0,
“steeringWheelToSteeringMap”: [0.0, 0.033, 0.0, 0.0, 0.0, 0.0]
“hasCabin”: false,
“numTrailers”: 0
“vehicleio”:
“version”: 8
Please paste the complete application log here. If there are multiple logs, please use multiple text box
Dear @ales.gabrhelik1 ,
Is there any dependency on DRIVE OS version? If not, can you check using DRIVE OS 6.0.10 release?
Dear @SivaRamaKrishnaNV .
well there is no dependency for this current setup, but my cameras (Sekonix SF3325), which i intend to use later, have a driver only for 6.0.6 DriveOS. Also i forgot to mention im trying this on my host machine not on the AGX Orin. So i would welcome a solution for version 6.0.6. Also i can provide the recording if it is needed.
Is same rig file used to record the data using recorded tool. Make sure the sensor parameter matches. Did you use replayer tool and sample_record on target? Also, can you also give a try(record and replay) with DOS 6.0.10 to confirm if the issue is noticed only on 6.0.6.
Any update can be provided for this issue?
Hence, we are closing this topic. Please file a new topic incase of any issue.
