Replicator Composer with transparent objects
Hi, I am trying to use replicator composer with semi transparent objects e.g. the objects include some parts made of glass.
It works great for non transparent objects but the glass is not visible in the generated images. In Isaac Sim I need to enable “Enable Fractional Cutout Opacity” under Render Settings → Ray Tracing so see the objects. How do I do that in replicator composer?
Here is the original post where I got the solution for Isaac Sim: Opacity adjustment not working - #6 by samuel.blanchet.2
okay I found a workaround by manually setting:
CUTOUT_OPACITY = “/rtx/raytracing/fractionalCutoutOpacity”
carb.settings.get_settings().set(CUTOUT_OPACITY, True)
inside […].local/share/ov/pkg/isaac_sim-2022.2.1/tools/composer/src/main.py
If someone knows a better way, I am looking forward to it.
