I reduce the focal length to become a wide-angle camera. Great. However, the bottom of the image is black.
Can I set the clipping range for the camera?
In the Sim UI for the camera Prim I can set the clipping range (Property) to decrease the clipping range so this doesn’t happen.
ahaidu
February 6, 2023, 10:41am
3
Hi there,
can you provide more details on how you run into the issue? I have tested and it seems to work fine for my side. See the uploaded image changing the focal length and then the clipping range:
Sorry, my fault completely for not inserting the “Replicator Composer” element into this question.
I am aware of clipping range in the UI - I can see the confusion.
The question is whether I can control clipping range from “Replicator Composer” yaml instructions.
p
