RTX5080 isaac sim 4.5 ubuntu22.04 installed error on CUDA compute capability
Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
[√] 4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
[√] Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: RTX5080
  • Driver Version: 570.86.16
Topic Description
Detailed Description
the isaac sim can be loaded but the screen is quite abnormal, the screen is not clear and has many blurs pixels.
the below the isaacsim check png.
when I run the isaac sim it has warning that I think it is important to deep into the question.
[Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : GPU 1 (NVIDIA GeForce RTX 5080) with CUDA compute capability 12.0 is unsupported by this version of iray photoreal. Please look for an update with your software provider.
Error Messages
(If applicable, copy and paste any error messages you received)
Screenshots or Videos
(If applicable, add screenshots or links to videos that demonstrate the issue)
Additional Information
What I’ve Tried
I have tried to reload nvidia-driver 550 , but it failed to install the 550 driver.
Also, on windows system, the isaac sim can run properly.
Additional Context
I use the workstation installation and use seletor to run the isaac sim
Please try installing the latest driver version 570.124.04 using the .run installer. This version is the most recent production driver and may include fixes for your issue.
nothing changes after I updated the lastest driver, my GPU is 5090
We are currently investigating this issue. We will provide an update as soon as possible.
Any update on this? Same error on 5090 as well.
same error 5090, with the latest 570 driver
same error 5070 ti, with the latest 570 driver
I was deceived. I should have bought an RTX 40 series product. I regret it.
Same error on 5080, both on Ubuntu and on Windows 11
Any updates now? the same error with TRX 5080 and ubuntu 20.04
@VickNV : Is this update posted? When will it be released? We need this fix ASAP
Please review our latest updates:
Could you please check if this rendering issue persists in the Isaac Sim 5.0 developer preview?
It is available for access via the official Isaac Sim GitHub repository. Testing with this newer version will help us determine if the issue has been addressed in recent updates.
