Running Multiple samples using single camera
Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[~] NVIDIA DRIVE™ Software 10.0 (Linux)
other DRIVE OS version
other
Target Operating System
[~] Linux
QNX
other
Hardware Platform
[~] NVIDIA DRIVE™ AGX Xavier DevKit (E3550)
other
SDK Manager Version
1.9.1.10844
[~] other
Host Machine Version
[~] native Ubuntu 18.04
other
Hi all,
I am using Nvidia Drive AGX with one camera ar0231-rccb-bae-sf3324 which is connected to channel A.
I want to run ./sample_drivenet & ./sample_light_classifier together using a Single camera.
When I run them individually it is working fine but when I run both at once I could notice the one which I run first is getting executed but the other one doesn’t.
I get the following error:
Driveworks exception thrown: DW_SAL_CANNOT_CREATE_SENSOR: CameraGMSL: cannot connect to camera.
Is it possible to run Multiple different samples using input from a single camera.
Kindly clarify.
Dear @s-s.radeshwar,
On same Tegra it is not possible to share single camera by two processes. But You may use --slave=1 on Tegra B to access camera data from Tegra A.
Thanks for the clarification @SivaRamaKrishnaNV
