I run sample_lane_detection and sample_drivenet among driveworks samples in drive px2 with gmsl camera.
The camera type is ar0231-rccb-bae-sf3324 and it is two.
I connected the camera to the 0,1 index of A group and successfully executed sample_drivenetNcamera and sample_camera_multiple_gmsl.
However, it was not possible to execute sample_lane_detection and sample_drivenet with each camera.
The command is:
-./sample_lane_detection --input-type = camera --camera-index = 0
-./sample_drivenet --input-type = camera --camera-index = 1
Error is as follows.
nvidia@tegra-ubuntu:/usr/local/driveworks/bin$ ./sample_drivenet --input-type=camera --camera-index=1
[18-3-2020 20:9:10] Initialize DriveWorks SDK v1.2.400
[18-3-2020 20:9:10] Release build with GNU 4.9.4 from v1.2.0-rc11-0-ga7f5475 against Vibrante PDK v5.0.10.3
[18-3-2020 20:9:10] Platform: Detected Drive PX2 - Tegra A
[18-3-2020 20:9:10] TimeSource: monotonic epoch time offset is 1584529615544665
[18-3-2020 20:9:10] TimeSource: PTP ioctl returned error. Synchronized time will not be available.
[18-3-2020 20:9:10] TimeSource: Could not detect valid PTP time source at ‘eth0’. Fallback to CLOCK_MONOTONIC.
[18-3-2020 20:9:10] Platform: number of GPU devices detected 2
[18-3-2020 20:9:10] Platform: currently selected GPU device discrete ID 0
[18-3-2020 20:9:10] SDK: Resources mounted from …/./data/resources
[18-3-2020 20:9:10] SDK: Create NvMediaDevice
[18-3-2020 20:9:10] SDK: Create NvMediaIPPManager
[18-3-2020 20:9:10] SDK: use EGL display as provided
[18-3-2020 20:9:10] SensorFactory::createSensor() → camera.gmsl, camera-type=ar0231-rccb-bae-sf3324,csi-port=a,slave=0,serialize=false,output-format=raw,camera-count=4,camera-mask=0010
[18-3-2020 20:9:10] CameraGMSL: required FPS = 30, resolution = 1920x1208
iscRootDevOpen: can’t open /dev/isc-mgr.7.a - Device or resource busy
NvMediaISCRootDeviceCreate: Unable to open root device
nvmedia: ERROR: Init: Failed to create NvMedia ISC root device
[18-3-2020 20:9:10] Driveworks exception thrown: DW_SAL_CANNOT_CREATE_SENSOR: CameraGMSL: cannot connect to camera
terminate called after throwing an instance of ‘std::runtime_error’
what(): [2020-03-18 20:09:10] DW Error DW_SAL_CANNOT_CREATE_SENSOR executing DW function:
dwSAL_createSensor(&m_sensor, params, m_sal)
at /builds/driveav/dw/sdk/samples/framework/SimpleCamera.cpp:51
Aborted (core dumped)
The same error occurs when changing the camera index.
However, if the camera is connected to A group 0 index and B group 0 index, it works well.
I refer to 5.x_Linux_DPX_SDK , 2 cameras are connected to A group 0 and 1 index. (A group 0,1,2,3 order)
I would like to know in what order to connect the camera to drive px2.
