We have built robots with Isaac SDK 2021 and simulated them with Isaac Sim 2021.2.1 and REB (robot engine bridge). This is all working natively on 12th gen core i9 LInux PCs with Ubuntu 20.04.06 and RTX3060 with driver 535.
Now we have a new 14th gen core i9 PC with Ubuntu 24.04.1 and RTX4080 with driver 550.120, which runs Isaac Sim 4.2 natively but it is really only for ROS developers, not Isaac SDK developers.
So in order to run Isaac Sim 2021 we did the container installation and transferred the Isaac Sim assets. Isaac Sim 2021 running from container starts up and shows thumbnails for the various assets and demos but the screen stays blank when trying to render anything.
Here’ are some of the messages from inside the Docker:
| Driver Version: 550.120 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 4080 | Yes: 0 | | 16376 MB | 10de | 0 |
| | | | | | 2704 | b952c9b1.. |
| OS: Linux o9, Version: 6.8.0-50-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101011 (1.21.1.11)
| Processor: Intel(R) Core(TM) i9-14900K | Cores: Unknown | Logical: 32
| Total Memory (MB): 64067 | Free Memory: 59562
| Total Page/Swap (MB): 8191 | Free Page/Swap: 8191
2024-12-10 22:47:45 [504ms] [Warning] [gpu.foundation.plugin] Different GPUs have different availalbe VRAM. The texture streaming system will be limited to the lower VRAM number
[0.658s] [ext: omni.kit.test-0.0.0] startup
[0.698s] [ext: omni.ui-2.5.3] startup
and then lots of messages like this:
[1.052s] [ext: omni.kit.window.viewport-0.0.0] startup
2024-12-10 22:47:46 [1,054ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/SparseMemCopy.compute.hlsl'.
2024-12-10 22:47:46 [1,054ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/SparseMemCopy.compute.hlsl
2024-12-10 22:47:46 [1,054ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
and this:
[2.943s] [ext: omni.isaac.sim-2021.2.1] startup
[2.943s] app started
2024-12-10 22:47:48 [2,916ms] [Warning] [omni.usd] No hydra engine was found with name rtx running at tickrate -1
2024-12-10 22:47:48 [2,916ms] [Warning] [omni.usd] Failed to create Hydra Engine for viewport!
2024-12-10 22:47:48 [2,917ms] [Warning] [gpu.foundation.plugin] Post processing operations requested for texture /tmp/carb.Z1PFhR/filter.28x28.png, but no renderer was initialized. Skipping post-processing ops
There is only one GPU in the system and the on-board integrated graphics card is disabled.
What do those error messages mean ? We tried using an RTX3060 instead of the 4080, didn’t make a difference. Deleting all caches or even deleting the whole docker image and fresh setup with 3060 didn’t make a difference.
