Seems to run - but nothing shows in the viewport. I’m following the tutorial, say for jetbot - that ‘seems’ to load, and the docker terminal is spitting out updates quickly. I would have thought I’d see a display in the viewport. Thoughts?
Running ubuntu 20.04, Titan X (Pascal) - is this supported? Isaac Sim running in docker - isaac-sim:2021.1.0 (launches fine, no errors.) Using web sockets from chrome as the client (fyi, figured out must run in full screen mode to get cursors to align!) From localhost I see my nucleus files, including Isaac. The “?” shows “2021.1.0” In the upper right of my client I note that CACHE: is off and LIVE SYNC: is off.
Here’s the docker output when I load jetbot.
2021-06-18 14:44:23 [167,015ms] [Info] [omni.livestream-websocket.plugin] Encode settings:
2021-06-18 14:44:23 [167,015ms] [Info] [omni.livestream-websocket.plugin] bitrate = 16777216
2021-06-18 14:44:23 [167,015ms] [Info] [omni.livestream-websocket.plugin] iframe_interval = 10
Refreshing context
2021-06-18 14:44:23 [167,034ms] [Info] [omni.isaac.motion_planning.plugin] onDetach MotionPlanning
2021-06-18 14:44:23 [167,034ms] [Info] [carb.settings.python] ISettings.get(…) was called on element that has no value (from python). Use set_default(…) before to set default value. (path = ‘ext/omni.kit.widget.stage/exclusion/types’)
2021-06-18 14:44:23 [167,050ms] [Info] [omni.isaac.dr.plugin] onDetach DR
2021-06-18 14:44:23 [167,126ms] [Info] [carb.settings.python] ISettings.get(…) was called on element that has no value (from python). Use set_default(…) before to set default value. (path = ‘ext/omni.kit.widget.stage/exclusion/types’)
2021-06-18 14:44:23 [167,126ms] [Warning] [carb.python] get_materials_from_stage error stage isn’t initalized
2021-06-18 14:44:23 [167,127ms] [Info] [omni.livestream-websocket.plugin] Encode settings:
2021-06-18 14:44:23 [167,127ms] [Info] [omni.livestream-websocket.plugin] bitrate = 16777216
2021-06-18 14:44:23 [167,127ms] [Info] [omni.livestream-websocket.plugin] iframe_interval = 10
2021-06-18 14:44:23 [167,140ms] [Info] [carb.settings.python] ISettings.get(…) was called on element that has no value (from python). Use set_default(…) before to set default value. (path = ‘ext/omni.kit.widget.stage/exclusion/types’)
2021-06-18 14:44:23 [167,176ms] [Info] [omni.isaac.dynamic_control.plugin] Acquired interface ‘omni::physx::IPhysx’, version 1.0
2021-06-18 14:44:23 [167,176ms] [Info] [omni.isaac.dynamic_control.plugin] Acquired interface ‘omni::physx::IPhysxSceneQuery’, version 1.0
2021-06-18 14:44:23 [167,178ms] [Info] [carb.graphics-vulkan.plugin] Active GPU: TITAN X (Pascal)
2021-06-18 14:44:23 [167,214ms] [Info] [omni.isaac.dr.plugin] onAttach DR
2021-06-18 14:44:23 [167,214ms] [Info] [omni.usd] refreshing the USD scene state
2021-06-18 14:44:23 [167,214ms] [Info] [carb.audio.context] the bus count would not be changLoading Jetbot Enviornment
ed => exiting
2021-06-18 14:44:23 [167,214ms] [Info] [carb.audio.context] the bus count would not be changed => exiting
2021-06-18 14:44:23 [167,214ms] [Info] [omni.usd] updated world unit scale {1.00 => 0.01}
2021-06-18 14:44:23 [167,214ms] [Info] [omni.usd] ResyncedPaths: /OmniverseKit_Persp
2021-06-18 14:44:23 [167,219ms] [Info] [omni.usd] ResyncedPaths: /OmniverseKit_Persp
2021-06-18 14:44:23 [167,220ms] [Info] [omni.usd] ResyncedPaths: /OmniverseKit_Front
2021-06-18 14:44:23 [167,225ms] [Info] [omni.usd] ResyncedPaths: /OmniverseKit_Front
2021-06-18 14:44:23 [167,225ms] [Info] [omni.usd] ResyncedPaths: /OmniverseKit_Top
2021-06-18 14:44:23 [167,230ms] [Info] [omni.usd] ResyncedPaths: /OmniverseKit_Top
2021-06-18 14:44:23 [167,230ms] [Info] [omni.usd] ResyncedPaths: /OmniverseKit_Right
2021-06-18 14:44:23 [167,236ms] [Info] [omni.usd] ResyncedPaths: /OmniverseKit_Right
2021-06-18 14:44:23 [167,242ms] [Info] [carb.python] Load prim spec tree rooted from /
2021-06-18 14:44:23 [167,242ms] [Info] [carb.python] Load sublayers of layer anon:0x7fe5800014a0:World1.usd.
2021-06-18 14:44:23 [167,243ms] [Info] [carb.python] Load sublayers of layer anon:0x7fe5800035a0:World1-session.usda.
2021-06-18 14:44:24 [167,302ms] [Info] [carb.settings.python] ISettings.get(…) was called on element that has no value (from python). Use set_default(…) before to set default value. (path = ‘/rtx/rendermode’)
2021-06-18 14:44:24 [167,304ms] [Info] [carb.python] [py stdout]: Loading Jetbot Enviornment
2021-06-18 14:44:24 [167,314ms] [Info] [omni.client.plugin] Main: provider_nucleus: Initialized Nucleus API v11.10-5044c985
2021-06-18 14:44:24 [167,314ms] [Info] [omni.client.plugin] Tick: provider_nucleus: Connecting to localhost:3009 as dockeruser using new authentication method
2021-06-18 14:44:24 [167,314ms] [Info] [omni.client.plugin] Tick: authentication: Discovery(localhost:3009): Searching for OmniAuth.idl.ts : Credentials at wss://localhost/omni/discovery
2021-06-18 14:44:24 [167,315ms] [Info] [omni.client.plugin] Tick: authentication: Discovery(wss://localhost/omni/discovery): Get future failed: Connection is terminated
2021-06-18 14:44:24 [167,315ms] [Warning] [omni.client.plugin] Tick: authentication: Could not connect to discovery service at “wss://localhost/omni/discovery”
2021-06-18 14:44:24 [167,315ms] [Info] [omni.client.plugin] Tick: authentication: Discovery(localhost:3009): Searching for OmniAuth.idl.ts : Credentials at ws://localhost:3333
2021-06-18 14:44:24 [167,318ms] [Info] [omni.client.plugin] Tick: authentication: Discovery(ws://localhost:3333): Found Credentials service using transport ‘sows’ {“host”: “127.0.0.1”, “port”: 3100}
2021-06-18 14:44:24 [167,469ms] [Info] [omni.client.plugin] Tick: authentication: Auth: Retrieved token for user “dockeruser”
2021-06-18 14:44:24 [167,471ms] [Info] [omni.client.plugin] Tick: provider_nucleus: Connected to localhost:3009 as dockeruser
2021-06-18 14:44:24 [167,471ms] [Info] [omni.client.plugin] Tick: provider_nucleus: Server localhost:3009 supports stat2, create with overwrite, checkpoints, copy with no transaction id
2021-06-18 14:44:24 [167,471ms] [Info] [omni.client.plugin] Tick: provider_nucleus: Server localhost:3009 is running version 110.3-4fd7d804
2021-06-18 14:44:24 [167,471ms] [Info] [omni.client.plugin] Tick: provider_nucleus: Server localhost:3009 supports checkpoints and they are enabled
2021-06-18 14:44:24 [168,219ms] [Info] [carb.python] Success: omniverse://localhost Server has /Isaac folder
2021-06-18 14:44:24 [168,220ms] [Info] [omni.usd] ResyncedPaths: /jetbot
2021-06-18 14:44:28 [171,939ms] [Info] [omni.usd] ResyncedPaths: /jetbot
2021-06-18 14:44:28 [171,939ms] [Info] [omni.usd] ResyncedPaths: /physics
2021-06-18 14:44:28 [171,939ms] [Info] [omni.usd] ResyncedPaths: /physics/scene
2021-06-18 14:44:28 [171,940ms] [Info] [omni.usd] ResyncedPaths: /physics/scene
2021-06-18 14:44:28 [171,941ms] [Info] [omni.usd] ResyncedPaths: /background
2021-06-18 14:44:29 [172,289ms] [Info] [omni.usd] ResyncedPaths: /background
2021-06-18 14:44:29 [172,311ms] [Info] [carb.python] Handle changed 4 prims for layer anon:0x7fe5800035a0:World1-session.usda.
2021-06-18 14:44:29 [172,311ms] [Info] [carb.python] Load prim spec tree rooted from /
2021-06-18 14:44:29 [172,311ms] [Info] [carb.python] Handle changed prims for layer anon:0x7fe5800035a0:World1-session.usda done.
2021-06-18 14:44:29 [172,311ms] [Info] [carb.python] Handle changed 4 prims for layer anon:0x7fe5800014a0:World1.usd.
2021-06-18 14:44:29 [172,312ms] [Info] [carb.python] Handle changed prims for layer anon:0x7fe5800014a0:World1.usd done.
2021-06-18 14:44:29 [172,317ms] [Warning] [gpu.foundation.plugin] Post processing operations requested for texture /tmp/carb.hy8lVp/Reference.40x40.png, but no renderer was initialized. Skipping post-processing ops
2021-06-18 14:44:29 [172,317ms] [Warning] [gpu.foundation.plugin] Post processing operations requested for texture /tmp/carb.hy8lVp/Prim.40x40.png, but no renderer was initialized. Skipping post-processing ops
2021-06-18 14:44:29 [172,318ms] [Warning] [omni.ext-live.plugin] Omniverse Cache is disabled! It can be turned on in Omniverse System Monitor.
2021-06-18 14:44:29 [172,318ms] [Info] [omni.livestream-websocket.plugin] Encode settings:
2021-06-18 14:44:29 [172,318ms] [Info] [omni.livestream-websocket.plugin] bitrate = 16777216
2021-06-18 14:44:29 [172,318ms] [Info] [omni.livestream-websocket.plugin] iframe_interval = 10
2021-06-18 14:44:29 [172,319ms] [Info] [omni.usd] ResyncedPaths: /jetbot/chassis/rgb_camera/jetbot_camera
2021-06-18 14:44:29 [172,319ms] [Info] [omni.usd] ResyncedPaths: /jetbot/chassis/rgb_camera/jetbot_camera/OmniverseKitViewportCameraMesh
2021-06-18 14:44:29 [172,320ms] [Info] [omni.usd] ResyncedPaths: /jetbot/chassis/rgb_camera/jetbot_camera/OmniverseKitViewportCameraMesh
2021-06-18 14:44:29 [172,325ms] [Info] [omni.livestream-websocket.plugin] Encode settings:
2021-06-18 14:44:29 [172,325ms] [Info] [omni.livestream-websocket.plugin] bitrate = 16777216
2021-06-18 14:44:29 [172,325ms] [Info] [omni.livestream-websocket.plugin] iframe_interval = 10
