Running ./sample_hello_world cudaErrorSystemDriverMismatch: system has unsupported display driver / cuda driver combination
Software Version
DRIVE OS 6.0.4 SDK
DRIVE OS 6.0.4 (rev. 1)
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.8.3.10426
other (1.8.4-10431)
Host Machine Version
other
I just installed DriveOS 6.0.4 rev.1 via SDK Manager and I tried running the ./sample_hello_world on my Linux host machine. I am getting the following output:
+++++++++++++++:/usr/local/driveworks/bin$ ./sample_hello_world
Welcome to Driveworks SDK
[13-10-2022 16:26:06] Platform: Detected Generic x86 Platform
[13-10-2022 16:26:06] TimeSource: monotonic epoch time offset is 1665671077039348
[13-10-2022 16:26:06] Adding variable DW_Base:DW_Version
[13-10-2022 16:26:06] Addded variable DW_Base:DW_Version
[13-10-2022 16:26:07] Driveworks exception thrown: Platform: cannot acquire CUDA context. Error cudaErrorSystemDriverMismatch: system has unsupported display driver / cuda driver combination
Cannot init SDK
Any ideas?
Edit: to give more input
Before the installation I was checking my driver version with nvidia-smi, and I was using the nvidia-driver-515.
After the installation via sdkmanager-1.8.4-10431, i could not check my driver-version via nvidia-smi and in the additional drivers GUI menu, it said i would use a manually installed driver.
Hi @christopher.tuch
Please try if rebooting your host system helps with this.
Also, don’t you run the program successfully in the other topic?
Yes i did run it successful, but i had an cuda unknown error, so i decided to try and reinstall it with SDK Manager all again. I just booted and it didn’t change, i guess it is something with the nvidia driver, as I described in the EDIT section in the first post. How can I check which driver is in use, when nvidia-smi is not working?
Ok, i got it working: The issue was due to an incomplete setup of my nvidia driver, as my system has secure boot on.
I had to set a key in the MOK Manager which I had to set after a driver installation. Now the sample_hello_world runs with the same output as in the linked thread ./sample_hello_world on host machine fails: Could not find ./recources.resources.pak
I still can’t run certain other samples due to Error CudaErrorUnknown: unknow Error. Should i make a new topic? As I can’t find a working fix on the internet.
Thanks for sharing. also, saw your created another topic (Running precompiled Sample: "sample_camera_replay" results in Error: Error cudaErrorUnknown: unknown error).
