Running simulation without modifying the opened USD
Isaac Sim Version
4.0.0
Operating System
Windows 10
GPU Information
  • Model: RTX 4090
  • Driver Version:
Hello, I am using Omniverse to scatter some objects and generate synthetic data. The scattering of the objects makes omniverse really slow. if I scatter 10 + objects, a step would be like 5 seconds. so I’ll get to the write() function once every ~5 seconds. This is supper slow. I was recently at an omniverse bootstrap at the Nvida offices. I understand that this is partially because the simulation is actually modifying the USD file and that there is a way (using Fabric) to make the simulation not write to the USD file.
Can any one help me understand/implement this?
Thank you
Could you please check if How can I raise the frame rate of physics simulations? - #2 by AlesBorovicka is useful?
Hi @VickNV
is there a way to not modify a USD if in play mode? for example, say i have a usd with a plane and an extention that on play scatters a prim on the plane. Is there a way to run this simulation without modifying the USD file with the plane?
Thank you
I see the documention here: https://docs.omniverse.nvidia.com/extensions/latest/ext_physics/simulation-control/physics-settings.html#physx-short-flatcache-also-known-as-fabric
which does talk about the ability to run the simulation without writing to the USD file.
a few issues with this documentation:
How can I get this window? I couldnt find it.
I cannot find this extention in Isaac Sim 4.0.0
I did find this:
But it seems that this only applies to physics components in the scene? Meaning that, rigidbodies and joints modifications wont be written to the USD data.
But is there a way to not write back to the USD any data? I dont have any physics in my stage, just
thousands of scattered meshes. I believe i’ll be able to speed up my simulation if i dont write back to the usd file every step.
yes you can disable write back to USD from physics.
You should enable omni.physx.fabric extension or click on the “eye” icon → show by type → physics → simulation settings:
Disabling the Update to USD in the physics settings will prevent to write some initialization data to USD skipping USD writes completely.
Hope that helps, regards,
Ales
Hi @AlesBorovicka , Im my post I am asking if there is a a way to not write back any data to the USD file.
I dont have any physics in my scene. I simply scatter many (None rigidbody) prims.
Please, is there a way to not write back any data to the USD?
Yes, that is possible, you can use USDRT from python or Fabric directly from C++ and write to Fabric, our runtime data representation.
Note that if you need the data rendered you will need FSD (Fabric Scene Delegate) to be enabled (enable in settings → rendering).
Regards,
Ales
