Please provide the following info (tick the boxes after creating this topic): Software Version
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.10816
other
Host Machine Version
other
I have a Drive AGX Orin DevKit hardware that I installed Drive OS 6.04 on it along with cuda-11.4 and driveworks-5.6 by the SDK manager
I cannot find sample_radar_replay anywhere on the target ( I checked all the bin folders /bin; /usr/local/driveworks/bin;/usr/local/bin). isnt it supposed to be present and executable on the target?
The sample_radar_replay is present on the host ( my x86_64 laptop) at /usr/local/driveworks/bin. but when I try to use it , I got an error
./sample_radar_replay: error while loading shared libraries: libEGL.so: cannot open shared object file: No such file or directory.
I have a recorded file that I want to replay. It is not clear to me if the sample_radar_replay can be executed on the target or not? If so, should we cross-compile it in the host and then copy and execute it on the target?
Dear @behrooz1,
If you need to cross compile the sample to run on target.
But for replaying the recorded data, you may not need to use target. To run DW samples on host, Ampere based GPU is recommended.
on my target board. but it looks like these .deb file are available on NVONLINE portal , which I dont have credentials for. My developer account credentials dosent work for NVONLINE.
would you please point me to where I can get these .deb files for Driveworks 5.6?
