Hi OV team folks,
I import a .SBSAR file to Composer. It correctly display however the parameter can not be changed. It always shows the error below. Any suggestions? It works well in other software such as Painter or Blender.
2024-07-06 14:08:25 [Warning] [omni.usd] Warning: in writeDict at line 84 of C:\Users\bbarran\project\omniverse\kit-extensions\usd-sbsar-plugin\source\extensions\omni.usd.fileformat.sbsar\plugins\dictencoder.cpp – Unsupported dict value oil_distribution_offset: GfVec2f
2024-07-06 14:08:30 [Warning] [omni.usd] Warning: in writeDict at line 84 of C:\Users\bbarran\project\omniverse\kit-extensions\usd-sbsar-plugin\source\extensions\omni.usd.fileformat.sbsar\plugins\dictencoder.cpp – Unsupported dict value oil_distribution_offset: GfVec2f
2024-07-06 14:08:31 [Error] [omni.ui.python] ErrorException:
2024-07-06 14:08:31 [Error] [omni.ui.python] Error in ‘pxrInternal_v0_22__pxrReserved__::DictEncoder::readDict’ at line 96 in file C:\Users\bbarran\project\omniverse\kit-extensions\usd-sbsar-plugin\source\extensions\omni.usd.fileformat.sbsar\plugins\dictencoder.cpp : ‘Failed to parse json data’
2024-07-06 14:08:31 [Error] [omni.ui.python] At:
2024-07-06 14:08:31 [Error] [omni.ui.python] c:/users/asus/appdata/local/ov/pkg/create-2023.2.5/extscache/omni.kit.property.sbsar-105.0.5/omni/kit/property/sbsar/properties.py(130): _sbsar_end_edit
2024-07-06 14:08:31 [Error] [omni.ui.python] c:/users/asus/appdata/local/ov/pkg/create-2023.2.5/extscache/omni.kit.property.sbsar-105.0.5/omni/kit/property/sbsar/properties.py(180): end_edit
2024-07-06 14:08:31 [Warning] [omni.usd] Warning: in writeDict at line 84 of C:\Users\bbarran\project\omniverse\kit-extensions\usd-sbsar-plugin\source\extensions\omni.usd.fileformat.sbsar\plugins\dictencoder.cpp – Unsupported dict value oil_distribution_offset: GfVec2f
Rosy
