Hi, I need some help in regards to some documentation for the Jetson Nano. I was informed today by electrical engineers that there is an SD card version and an EMMC version (I believe this is the production version). I only found one thermal design guide available for download - is this based on the EMMC version? Also, are there 2 different 3D CAD models? If so, can I be directed to the EMMC version?
Hi, there are no two 3D models. If you had looked into the thermal design guide, you should have found it is for eMMC version. SD card version module is on early devkit and for development only. What custom design should follow is the docs in DLC which are for production module only.
