Is your host machine a VM? What ubuntu version it is?
It’s not a VM. Ubuntu 18.04
Do you have other ubuntu host and type C usb cable that can test?
Or do you have any other jetson device to try to flash with this host? No needs to be Orin. Even jetson nano or nx are ok.
I have tried with a different usb-c cable with no luck. I can try with a different ubuntu host
Tried with 2 different Ubuntu hosts and 2 different Orins, all of them are failing with this error:
08:25:20 ERROR: Flash Jetson AGX Orin - flash: --- Error: Reading board information failed.
08:25:20 INFO: Flash Jetson AGX Orin - flash: [ Component Install Finished with Error ]
08:25:20 ERROR: Flash Jetson AGX Orin - flash: command terminated with error
08:25:20 SUMMARY: DateTime Target Setup - target: Depends on failed component
Could you take a photo of where you connect the type C usb?
Also, could you use the serial console on your micro usb port and open it with /dev/ttyACM0 with baud rate 115200 on your host ? Power on your board and see if any log gets printed.
Btw, please always share full log. Do not just only capture few lines. They are not very helpful.
USB-c:
Serial console log from power on:
��80)
[0000.438] I> RAM_CODE 0x4000401
[0000.442] I> Task: Save mem-bct info (0x50011d59)
[0000.447] I> Task: SDRAM params override (0x50010c79)
[0000.451] I> Task: Carveout allocate (0x50011da5)
[0000.456] I> RCM blob carveout will not be allocated
[0000.461] I> ECC region[0]: Start:0x0, End:0x0
[0000.465] I> ECC region[1]: Start:0x0, End:0x0
[0000.469] I> ECC region[2]: Start:0x0, End:0x0
[0000.474] I> ECC region[3]: Start:0x0, End:0x0
[0000.478] I> ECC region[4]: Start:0x0, End:0x0
[0000.482] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.488] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.493] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.497] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.502] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.509] I> allocated(CO:51) base:0x80000000 size:0x8000000 align: 0x200000
[0000.516] I> allocated(CO:44) base:0xd6000000 size:0x2a000000 align: 0x100000
[0000.523] I> allocated(CO:31) base:0xce000000 size:0x8000000 align: 0x100000
[0000.530] I> allocated(CO:39) base:0xc8000000 size:0x6000000 align: 0x200000
[0000.536] I> allocated(CO:20) base:0xc6000000 size:0x2000000 align: 0x2000000
[0000.543] I> allocated(CO:24) base:0xc4000000 size:0x2000000 align: 0x2000000
[0000.550] I> allocated(CO:28) base:0xc2000000 size:0x2000000 align: 0x2000000
[0000.557] I> allocated(CO:29) base:0xc0000000 size:0x2000000 align: 0x2000000
[0000.564] I> allocated(CO:41) base:0xbf000000 size:0x1000000 align: 0x100000
[0000.571] I> allocated(CO:43) base:0xbe000000 size:0x1000000 align: 0x200000
[0000.578] I> allocated(CO:02) base:0xbd800000 size:0x800000 align: 0x800000
[0000.585] I> allocated(CO:03) base:0xbd000000 size:0x800000 align: 0x800000
[0000.592] I> allocated(CO:06) base:0xbc800000 size:0x800000 align: 0x800000
[0000.599] I> allocated(CO:10) base:0xbc000000 size:0x800000 align: 0x800000
���ń�ą�������DŽ��D㍄��e�D����愤���Åb憆Ƈ��Dæŧ�儤Ħ��焄���Ć��E����愤���e�烧D����愤���ÄD��������ÄD����愄��E����愄�D������ b
EFI stub: Using DTB from confEDIA_GUID device path
EFI stub: Exiting boot services and insta[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.65-tegra (buildbrain@mobile-u64-5414-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.02
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Jetson-Small Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x8548b1898 SMBIOS=0xbabc0000 SMBIOS 3.0=0x853260000 MEMATTR=0x852ec5018 ESRT=0x85319bf18 RNG=0x85435ff18 MEM
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x000000085319bf18 to 0x000000085319bf50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000086b800000, sinux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node fsi-carveout, compatible id nvidia,fsi-carveout
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000088000000-0x00000000b9ccffff]
[ 0.000000] node 0: [mem 0x00000000ba800000-0x00000000ba9affff]
[ 0.000000] node 0: [mem 0x00000000babb0000-0x00000000babcffff]
[ 0.000000] node 0: [mem 0x00000000babd0000-0x00000000babfffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000c3ffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000084fffffff]
[ 0.000000] node 0: [mem 0x0000000850000000-0x0000000851faffff]
[ 0.000000] node 0: [mem 0x0000000851fb0000-0x0000000852cf0fff]
[ 0.000000] node 0: [mem 0x0000000852cf1000-0x0000000852e52fff]
[ 0.000000] node 0: [mem 0x0000000852e53000-0x0000000852e8ffff]
[ 0.000000] node 0: [mem 0x0000000852e90000-0x0000000852eaffff]
[ 0.000000] node 0: [mem 0x0000000852eb0000-0x000000085316ffff]
[ 0.000000] node 0: [mem 0x0000000853170000-0x000000085318ffff]
[ 0.000000] node 0: [mem 0x0000000853190000-0x00000008531fffff]
[ 0.000000] node 0: [mem 0x0000000853200000-0x000000085320ffff]
[ 0.000000] node 0: [mem 0x0000000853210000-0x000000085325ffff]
[ 0.000000] node 0: [mem 0x0000000853260000-0x000000085326ffff]
[ 0.000000] node 0: [mem 0x0000000853270000-0x0000000853ceffff]
[ 0.000000] node 0: [mem 0x0000000853cf0000-0x0000000853f1ffff]
[ 0.000000] node 0: [mem 0x0000000853f20000-0x0000000853fdffff]
[ 0.000000] node 0: [mem 0x0000000853fe0000-0x000000085411ffff]
[ 0.000000] node 0: [mem 0x0000000854120000-0x000000085418ffff]
[ 0.000000] node 0: [mem 0x0000000854190000-0x000000085424ffff]
[ 0.000000] node 0: [mem 0x0000000854250000-0x000000085425ffff]
[ 0.000000] node 0: [mem 0x0000000854260000-0x00000008542fffff]
[ 0.000000] node 0: [mem 0x0000000854300000-0x000000085434ffff]
[ 0.000000] node 0: [mem 0x0000000854350000-0x000000085435ffff]
[ 0.000000] node 0: [mem 0x0000000854360000-0x00000008543affff]
[ 0.000000] node 0: [mem 0x00000008543b0000-0x000000085456ffff]
[ 0.000000] node 0: [mem 0x0000000854570000-0x000000085457ffff]
[ 0.000000] node 0: [mem 0x0000000854580000-0x000000085465ffff]
[ 0.000000] node 0: [mem 0x0000000854660000-0x00000008546dffff]
[ 0.000000] node 0: [mem 0x00000008546e0000-0x000000085477ffff]
[ 0.000000] node 0: [mem 0x0000000854780000-0x000000085485ffff]
[ 0.000000] node 0: [mem 0x0000000854860000-0x00000008548affff]
[ 0.000000] node 0: [mem 0x00000008548b0000-0x000000085493ffff]
[ 0.000000] node 0: [mem 0x0000000854940000-0x000000085498ffff]
[ 0.000000] node 0: [mem 0x0000000854990000-0x00000008549affff]
[ 0.000000] node 0: [mem 0x00000008549b0000-0x0000000854a4ffff]
[ 0.000000] node 0: [mem 0x0000000854a50000-0x0000000854aaffff]
[ 0.000000] node 0: [mem 0x0000000854ab0000-0x0000000854b9ffff]
[ 0.000000] node 0: [mem 0x0000000854ba0000-0x000000085537ffff]
[ 0.000000] node 0: [mem 0x0000000855380000-0x000000085555ffff]
[ 0.000000] node 0: [mem 0x0000000855560000-0x000000087b8bffff]
[ 0.000000] node 0: [mem 0x000000087b8c0000-0x000000087b90ffff]
[ 0.000000] node 0: [mem 0x000000087b910000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0, zone DMA: 304 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 80 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 31 pages/cpu s90008 r8192 d28776 u126976
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7983060
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=tty
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000a9cd0000-0x00000000b9cd0000] (256MB)
[ 0.000000] Memory: 31083300K/32439104K available (18496K kernel code, 3214K rwdata, 7092K rodata, 3968K init, 1070K bss, 1093660K re)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x4f4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000591] Console: colour dummy device 80x25
[ 0.000800] printk: console [tty0] enabled
[ 0.000838] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000848] pid_max: default: 32768 minimum: 301
[ 0.000903] LSM: Security Framework initializing
[ 0.000968] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.001015] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002701] rcu: Hierarchical SRCU implementation.
[ 0.002793] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003231] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/ps
[ 0.003238] DTB Build time: May 16 2022 21:09:35
[ 0.004354] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.004471] Remapping and enabling EFI services.
[ 0.005633] smp: Bringing up secondary CPUs ...
[ 0.006022] Detected PIPT I-cache on CPU1
[ 0.006052] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.006086] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006445] Detected PIPT I-cache on CPU2
[ 0.006455] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006468] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006784] Detected PIPT I-cache on CPU3
[ 0.006792] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006806] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.009129] Detected PIPT I-cache on CPU4
[ 0.009150] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.009178] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.009543] Detected PIPT I-cache on CPU5
[ 0.009552] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.009566] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.009896] Detected PIPT I-cache on CPU6
[ 0.009905] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.009919] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.010266] Detected PIPT I-cache on CPU7
[ 0.010275] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.010289] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.012624] Detected PIPT I-cache on CPU8
[ 0.012648] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.012675] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.013041] Detected PIPT I-cache on CPU9
[ 0.013051] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.013065] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.013412] Detected PIPT I-cache on CPU10
[ 0.013422] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.013436] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.013772] Detected PIPT I-cache on CPU11
[ 0.013782] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.013797] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.013849] smp: Brought up 1 node, 12 CPUs
[ 0.013914] SMP: Total of 12 processors activated.
[ 0.013918] CPU features: detected: Privileged Access Never
[ 0.013920] CPU features: detected: LSE atomic instructions
[ 0.013923] CPU features: detected: User Access Override
[ 0.013925] CPU features: detected: 32-bit EL0 Support
[ 0.013929] CPU features: detected: Common not Private translations
[ 0.013931] CPU features: detected: RAS Extension Support
[ 0.013934] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.013937] CPU features: detected: CRC32 instructions
[ 0.013940] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.047839] CPU: All CPU(s) started at EL2
[ 0.050099] devtmpfs: initialized
[ 0.059346] Registered cp15_barrier emulation handler
[ 0.059358] Registered setend emulation handler
[ 0.059363] KASLR enabled
[ 0.059444] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.059457] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.060925] pinctrl core: initialized pinctrl subsystem
[ 0.061365] SMBIOS 3.0.0 present.
[ 0.061372] DMI: /, BIOS r34.1-975eef6 05/16/2022
[ 0.061612] NET: Registered protocol family 16
[ 0.062504] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.062710] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.062912] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.062971] audit: initializing netlink subsys (disabled)
[ 0.063059] audit: type=2000 audit(0.060:1): state=initialized audit_enabled=0 res=1
[ 0.063678] printk: console [ramoops-1] enabled
[ 0.063685] pstore: Registered ramoops as persistent store backend
[ 0.063691] ramoops: using 0x200000@0xba9b0000, ecc: 0
[ 0.063849] thermal_sys: Registered thermal governor 'step_wise'
[ 0.063851] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.063857] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.065441] cpuidle: using governor menu
[ 0.065556] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.065661] ASID allocator initialised with 65536 entries
[ 0.065801] Serial: AMBA PL011 UART driver
[ 0.067204] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.067230] Tegra reboot handler registered.
[ 0.067304] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/ps
[ 0.067313] DTB Build time: May 16 2022 21:09:35
[ 0.081431] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c10000
[ 0.081451] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c20000
[ 0.081460] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c30000
[ 0.081471] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c40000
[ 0.081479] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c50000
[ 0.081487] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2b80000
[ 0.081495] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2b90000
[ 0.081503] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2ba0000
[ 0.081512] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2bb0000
[ 0.081520] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1700000
[ 0.081528] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1710000
[ 0.081536] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1720000
[ 0.081544] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1730000
[ 0.081552] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1740000
[ 0.081559] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1750000
[ 0.081567] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1760000
[ 0.081575] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1770000
[ 0.081587] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.081605] mc-err: mcerr ops are set to t23x
[ 0.081882] tegra23x-cbb 13a00000.cbb-en: secure_irq = 21
[ 0.081929] tegra23x-cbb c600000.aon-en: secure_irq = 22
[ 0.081966] tegra23x-cbb de00000.dce-en: secure_irq = 23
[ 0.081999] tegra23x-cbb be00000.rce-en: secure_irq = 24
[ 0.082033] tegra23x-cbb b600000.sce-en: secure_irq = 25
[ 0.085683] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.085692] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.085697] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.085702] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.087044] ACPI: Interpreter disabled.
[ 0.088064] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 0.088216] vbusA-cvb: supplied by vdd-5v-sys
[ 0.088326] vbusB-cvb: supplied by vdd-5v-sys
[ 0.088437] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 0.088525] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 0.088821] iommu: Default domain type: Translated
[ 0.088859] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.089001] SCSI subsystem initialized
[ 0.089064] usbcore: registered new interface driver usbfs
[ 0.089078] usbcore: registered new interface driver hub
[ 0.089095] usbcore: registered new device driver usb
[ 0.089283] mc: Linux media interface: v0.10
[ 0.089294] videodev: Linux video capture interface: v2.00
[ 0.089437] pps_core: LinuxPPS API ver. 1 registered
[ 0.089444] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.089452] PTP clock support registered
[ 0.089650] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.089672] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.090960] Registered efivars operations
[ 0.091354] FPGA manager framework
[ 0.091457] Advanced Linux Sound Architecture Driver Initialized.
[ 0.091692] Bluetooth: Core ver 2.22
[ 0.091708] NET: Registered protocol family 31
[ 0.091714] Bluetooth: HCI device and connection manager initialized
[ 0.091724] Bluetooth: HCI socket layer initialized
[ 0.091730] Bluetooth: L2CAP socket layer initialized
[ 0.091740] Bluetooth: SCO socket layer initialized
[ 0.092384] camchar: rtcpu character device driver loaded
[ 0.092641] clocksource: Switched to clocksource arch_sys_counter
[ 0.250663] VFS: Disk quotas dquot_6.6.0
[ 0.250710] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.250828] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.251064] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x00000000bf000000,16777216
[ 0.251075] pnp: PnP ACPI: disabled
[ 0.251083] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 0.251098] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000d6000000,704643072
[ 0.251107] nvmap_page_pool_init: Total RAM pages: 7836361
[ 0.251113] nvmap_page_pool_init: nvmap page pool size: 979545 pages (3826 MB)
[ 0.251206] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.251293] misc nvmap: created heap vpr base 0x00000000d6000000 size (688128KiB)
[ 0.252751] la/ptsa driver initialized.
[ 0.252800] NET: Registered protocol family 2
[ 0.252993] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.254756] misc nvmap: created heap fsi base 0x00000000bf000000 size (16384KiB)
[ 0.255076] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.255121] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.255343] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.255773] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.255844] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.255901] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.256027] NET: Registered protocol family 1
[ 0.256243] RPC: Registered named UNIX socket transport module.
[ 0.256255] RPC: Registered udp transport module.
[ 0.256260] RPC: Registered tcp transport module.
[ 0.256264] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.256277] PCI: CLS 0 bytes, default 64
[ 0.256374] Trying to unpack rootfs image as initramfs...
[ 0.365522] Freeing initrd memory: 8196K
[ 0.367470] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.367679] kvm [1]: IPA Size Limit: 48 bits
[ 0.367843] kvm [1]: VHE mode initialized successfully
[ 0.368384] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.369779] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.369972] NFS: Registering the id_resolver key type
[ 0.369992] Key type id_resolver registered
[ 0.369997] Key type id_legacy registered
[ 0.370024] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.370034] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.370048] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.381183] NET: Registered protocol family 38
[ 0.381207] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 0.381254] io scheduler mq-deadline registered
[ 0.381260] io scheduler kyber registered
[ 0.384721] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.384747] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.384763] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.384778] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.387010] tegra_dc_assign_hw_data: no matching compatible node
[ 0.387018] tegradccommon module_init failed
[ 0.387024] tegradc module_init failed
[ 0.387237] EINJ: ACPI disabled.
[ 0.388499] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.388509] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 0.388514] tegra-pmc: ### PMC reset level: L0
[ 0.388520] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.389549] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.393952] random: fast init done
[ 0.394686] printk: console [ttyTCU0] enabled
[ 2.221040] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.226942] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.231486] arm-smmu 12000000.iommu: stage 1 translation
[ 2.236830] arm-smmu 12000000.iommu: stage 2 translation
[ 2.242343] arm-smmu 12000000.iommu: nested translation
[ 2.247499] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.254675] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 2.262942] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.267710] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.274270] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.281413] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.287310] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.292034] arm-smmu 10000000.iommu: stage 1 translation
[ 2.297548] arm-smmu 10000000.iommu: stage 2 translation
[ 2.302971] arm-smmu 10000000.iommu: nested translation
[ 2.308397] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.315572] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 2.323916] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.328784] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.335345] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.342263] arm-smmu 8000000.iommu: probing hardware configuration...
[ 2.348473] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.353195] arm-smmu 8000000.iommu: stage 1 translation
[ 2.358709] arm-smmu 8000000.iommu: stage 2 translation
[ 2.364132] arm-smmu 8000000.iommu: nested translation
[ 2.369297] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.376471] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.384802] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.389684] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.396245] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.403375] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.412561] tegra_profiler: version: 1.146, samples/io: 49/28
[ 2.416449] tegra_profiler: auth: init
[ 2.421264] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 2.426820] libphy: Fixed MDIO Bus: probed
[ 2.430196] tun: Universal TUN/TAP device driver, 1.6
[ 2.435796] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.442536] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.448062] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.452859] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.458820] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.464234] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.470073] PPP generic driver version 2.4.2
[ 2.474432] PPP BSD Compression module registered
[ 2.479117] PPP Deflate Compression module registered
[ 2.484375] PPP MPPE Compression module registered
[ 2.489190] usbcore: registered new interface driver r8152
[ 2.494515] usbcore: registered new interface driver asix
[ 2.499943] usbcore: registered new interface driver ax88179_178a
[ 2.506063] usbcore: registered new interface driver cdc_ether
[ 2.512015] usbcore: registered new interface driver net1080
[ 2.517616] usbcore: registered new interface driver cdc_subset
[ 2.523651] usbcore: registered new interface driver zaurus
[ 2.529342] usbcore: registered new interface driver cdc_ncm
[ 2.535027] usbcore: registered new interface driver aqc111
[ 2.540547] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.546755] ohci-pci: OHCI PCI platform driver
[ 2.551049] ohci-platform: OHCI generic platform driver
[ 2.556371] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 2.562214] usbcore: registered new interface driver uas
[ 2.567328] usbcore: registered new interface driver usb-storage
[ 2.573294] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 2.579136] mousedev: PS/2 mouse device common for all mice
[ 2.584476] usbcore: registered new interface driver xpad
[ 2.591711] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.595270] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:19 UTC (19)
[ 2.603019] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.609250] i2c /dev entries driver
[ 2.612822] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 2.618397] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 2.623796] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 2.629210] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 2.634547] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 2.640056] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 2.645493] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 2.650821] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 2.657929] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.664439] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.673530] device-mapper: uevent: version 1.0.3
[ 2.677368] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.686622] sdhci: Secure Digital Host Controller Interface driver
[ 2.692085] sdhci: Copyright(c) Pierre Ossman
[ 2.696546] Synopsys Designware Multimedia Card Interface Driver
[ 2.702655] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.708491] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 2.708702] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 2.719955] pstore: ignoring unexpected backend 'efi'
[ 2.725775] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.733056] tegra-bpmp bpmp: firmware: 43f75b5aad2b8e1992e4-f0425a554b3
��debugfs initialized
��[ 4.475541] hid: raw HID events driver (C) Jiri Kosina
[ 4.476101] usbcore: registered new interface driver usbhid
[ 4.476263] usbhid: USB HID core driver
[ 4.476605] tegra-dce d800000.dce: Adding to iommu group 6
[ 4.477955] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 4.479003] dce: dce_wait_boot_complete:100 dce is ready to receive bootstrap commands
[ 4.479091] tegra234-aon c000000.aon: Adding to iommu group 7
[ 4.480364] c000000.aon:hsp: probed
[ 4.480612] tegra234-aon c000000.aon: init done
[ 4.480963] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 4.481386] tegra23x-psc e860000.psc: ext_cfg base:(____ptrval____)
[ 4.481562] tegra23x-psc e860000.psc: init done
[ 4.481825] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 4.481881] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 4.482300] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [0]. Ignored...
[ 4.482545] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 4.482565] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 4.482863] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 4.493693] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 4.498498] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [1] ...
[ 4.498501] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [1]. Ignored...
[ 4.498510] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [1]. Ignored...
[ 4.507282] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 4.515642] dce: dce_admin_setup_clients_ipc:456 Get queue info failed for [2]
[ 4.524351] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 4.532626] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 4.543726] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 4.550735] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [3] ...
[ 4.550737] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [3]. Ignored...
[ 4.550748] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [3]. Ignored...
[ 4.562099] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff0
[ 4.570679] dce: dce_worker:209 DCE_BOOT_DONE
[ 4.581565] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x0
[ 4.600888] random: crng init done
[ 4.606926] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 4.651447] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (115)
[ 4.658024] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 4.669588] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=ab261c6cb44ef92b00c3f83a96d5951f9ccd0c06
[ 4.678792] t19x_cache tegra-cache: probed
[ 4.681273] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 4.701527] nvpmodel: initialized successfully
[ 4.701920] tegra_hv: get_hvd: not initialized yet
[ 4.702062] user_ivc_mempool: hypervisor not present
[ 4.702773] usbcore: registered new interface driver snd-usb-audio
[ 4.708103] u32 classifier
[ 4.710417] input device check on
[ 4.714092] Actions configured
[ 4.717546] Initializing XFRM netlink socket
[ 4.722157] NET: Registered protocol family 10
[ 4.727751] Segment Routing with IPv6
[ 4.729892] NET: Registered protocol family 17
[ 4.734146] NET: Registered protocol family 15
[ 4.738633] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you.
[ 4.752217] Bluetooth: RFCOMM socket layer initialized
[ 4.756644] Bluetooth: RFCOMM ver 1.11
[ 4.760561] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.766424] Bluetooth: HIDP socket layer initialized
[ 4.772313] 9pnet: Installing 9P2000 support
[ 4.775839] Key type dns_resolver registered
[ 4.780954] registered taskstats version 1
[ 4.784576] pstore: Using crash dump compression: deflate
[ 4.789881] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 4.801221] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 4.802735] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 4.813450] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 4.815124] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 4.825660] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 4.847018] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 4.848218] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 4.848612] host1x 13e40000.host1x: Adding to iommu group 13
[ 5.856601] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 5.867822] host1x 13e40000.host1x: initialized
[ 5.868281] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 5.868802] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 5.870348] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 5.870745] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 5.872294] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 5.872708] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 5.874249] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 5.874662] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 5.876198] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 5.876601] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.878153] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 5.878597] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.889857] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 5.896448] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.907893] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 5.914439] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.925927] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 5.932474] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 5.943927] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 5.950497] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 5.961974] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 5.968527] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 5.979997] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 5.986574] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 5.998016] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 6.004577] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 6.016048] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 6.022623] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 6.034064] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 6.040614] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 6.052088] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 6.058653] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 6.070131] falcon 15340000.vic: Adding to iommu group 30
[ 6.081457] falcon 15340000.vic: initialized
[ 6.081796] falcon 15380000.nvjpg: Adding to iommu group 31
[ 6.088679] falcon 15380000.nvjpg: initialized
[ 6.088902] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 6.099051] falcon 15540000.nvjpg1: initialized
[ 6.099488] falcon 154c0000.nvenc: Adding to iommu group 33
[ 6.112298] falcon 154c0000.nvenc: initialized
[ 6.112513] falcon 15a50000.ofa: Adding to iommu group 34
[ 6.119617] falcon 15a50000.ofa: initialized
[ 6.119844] nvdec 15480000.nvdec: Adding to iommu group 35
[ 6.135865] nvdec 15480000.nvdec: initialized
[ 6.136078] tsec 15500000.tsec: Adding to iommu group 36
[ 6.143582] tsec 15500000.tsec: initialized
[ 6.145840] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 6.152023] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 6.158248] gpio-394 (camera-control-output-low): hogged as output/low
[ 6.158892] gpio-397 (camera-control-output-low): hogged as output/low
[ 6.165379] gpio-487 (camera-control-output-low): hogged as output/low
[ 6.171582] gpio-486 (camera-control-output-low): hogged as output/low
[ 6.178961] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 6.185035] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 6.191119] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 6.197394] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 6.202894] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 6.208545] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 6.215849] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 6.222192] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 6.230546] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 6.237218] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 6.243483] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 6.251121] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 6.258227] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 6.267308] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 6.273522] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: grid-of-semaphores not supported
[ 6.281627] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 6.290913] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 6.297405] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: grid-of-semaphores not supported
[ 6.305862] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 6.315514] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 6.321726] scare-pigeon 13e40000.host1x:isp-thi@14b00000: grid-of-semaphores not supported
[ 6.330224] pva 16000000.pva0: Adding to iommu group 40
[ 6.354233] pva 16000000.pva0: initialized
[ 6.361163] nvdla 15880000.nvdla0: Adding to iommu group 41
[ 6.370187] nvdla 15880000.nvdla0: initialized
[ 6.371824] nvdla 158c0000.nvdla1: Adding to iommu group 42
[ 6.379712] nvdla 158c0000.nvdla1: initialized
[ 6.381389] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 6.381612] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 6.382004] serial-tegra 3100000.serial: Adding to iommu group 3
[ 6.382533] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 6.388298] serial-tegra 3130000.serial: Adding to iommu group 3
[ 6.393963] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 6.426041] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 6.426386] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.426606] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 6.427648] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 6.434363] tegra-xusb 3610000.xhci: irq 232, io mem 0x03610000
[ 6.440472] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 6.448601] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.455774] usb usb1: Product: xHCI Host Controller
[ 6.460761] usb usb1: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 6.466797] usb usb1: SerialNumber: 3610000.xhci
[ 6.471896] hub 1-0:1.0: USB hub found
[ 6.475306] hub 1-0:1.0: 4 ports detected
[ 6.479490] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 6.484742] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 6.492355] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 6.499764] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 6.507966] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 6.515185] usb usb2: Product: xHCI Host Controller
[ 6.520173] usb usb2: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 6.526121] usb usb2: SerialNumber: 3610000.xhci
[ 6.531445] hub 2-0:1.0: USB hub found
[ 6.534723] hub 2-0:1.0: 4 ports detected
[ 6.540070] bwmgr API not supported
[ 6.540076] tegra-xusb 3610000.xhci: can't register EMC bwmgr (-22)
[ 6.572600] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 6.575223] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 2010000 KHz, changing to: 2035200 KHz
[ 6.578387] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 6.584273] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 6.586373] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 6.588303] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 6.592307] mmc0: CQHCI version 5.10
[ 6.602230] irq: IRQ290: trimming hierarchy from :pmc@c360000
[ 6.602862] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 6.608316] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 290
[ 6.616948] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 6.619515] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 6.639433] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 6.707607] mmc0: Command Queue Engine enabled
[ 6.707729] mmc0: periodic cache flush enabled
[ 6.707849] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.708455] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 6.708761] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 6.712085] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 6.736769] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 6.752637] tegra194-pcie 14100000.pcie: Link up
[ 6.754639] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.754847] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.755014] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 6.755305] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 6.755618] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 6.755874] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 6.756157] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 6.759525] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 6.759813] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 6.760113] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.763017] pci 0001:01:00.0: supports D1 D2
[ 6.766570] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 6.776542] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 6.780657] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.786961] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.794723] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.800801] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.806032] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.812333] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 6.819691] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 6.828217] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 6.836685] pcieport 0001:00:00.0: Adding to iommu group 10
[ 6.842244] pcieport 0001:00:00.0: PME: Signaling with IRQ 50
[ 6.848132] pcieport 0001:00:00.0: AER: enabled with IRQ 50
[ 6.854291] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.861085] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 6.866509] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 6.875160] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 6.883647] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 6.889015] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 6.900359] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.907531] usb 1-3: Product: Bluetooth Radio
[ 6.911818] usb 1-3: Manufacturer: Realtek
[ 6.916017] usb 1-3: SerialNumber: 00e04c000001
[ 6.996765] tegra194-pcie 14160000.pcie: Link up
[ 6.997222] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.997398] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.997541] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 6.997795] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 6.998075] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 6.998299] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 6.998542] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 7.001700] pci 0004:01:00.0: [144d:a80a] type 00 class 0x010802
[ 7.001954] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 7.005911] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 7.006096] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 7.006338] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 7.009558] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 7.013704] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 7.016825] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.032775] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 7.041593] pcieport 0004:00:00.0: Adding to iommu group 11
[ 7.047342] pcieport 0004:00:00.0: PME: Signaling with IRQ 52
[ 7.053340] pcieport 0004:00:00.0: AER: enabled with IRQ 52
[ 7.058955] nvme 0004:01:00.0: Adding to iommu group 11
[ 7.060652] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 7.064232] nvme nvme0: pci function 0004:01:00.0
[ 7.072123] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.077020] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 7.077402] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 7.077476] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 7.077629] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 7.077700] vdd-dp: supplied by vdd-3v3-sys
[ 7.077783] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 7.078013] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 7.079624] tegra194-isp5 14800000.isp: initialized
[ 7.081675] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 7.081742] (NULL device *): fops function table already registered
[ 7.082475] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 7.082946] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 7.083601] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 7.084019] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 7.084020] usb 2-3: Manufacturer: Generic
[ 7.092022] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 290
[ 7.094695] hub 2-3:1.0: USB hub found
[ 7.096918] hub 2-3:1.0: 4 ports detected
[ 7.100111] nvme nvme0: Shutdown timeout set to 10 seconds
[ 7.105545] nvme nvme0: 12/0/0 default/read/poll queues
[ 7.176640] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 7.189668] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 7.201461] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 7.210024] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 7.218508] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 7.365944] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 7.366174] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 7.366373] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 7.366498] usb 1-4: Manufacturer: Generic
[ 7.368509] hub 1-4:1.0: USB hub found
[ 7.369864] hub 1-4:1.0: 4 ports detected
[ 8.166366] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 8.333987] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 8.334216] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 8.334410] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 8.334559] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 8.334832] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.335125] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 8.335372] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 8.335647] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 8.341555] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 8.341702] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 8.342128] pcieport 0005:00:00.0: Adding to iommu group 12
[ 8.342435] pcieport 0005:00:00.0: PME: Signaling with IRQ 54
[ 8.342969] pcieport 0005:00:00.0: AER: enabled with IRQ 54
[ 8.343414] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 8.343666] pci 0005:00:00.0: Removing from iommu group 12
[ 8.343831] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 8.349862] nvethernet 6810000.ethernet: Adding to iommu group 43
[ 8.355113] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 8.362828] nvethernet 6810000.ethernet: failed to read MDIO address
[ 8.369373] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 8.376202] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 8.383940] nvethernet 6810000.ethernet: failed to get phy reset gpio error: -2
[ 8.395242] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:78:99:9e
[ 8.399143] nvethernet 6810000.ethernet: Macsec not enabled
[ 8.404106] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 8.416025] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 8.419737] irq: IRQ305: trimming hierarchy from :pmc@c360000
[ 8.425055] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[ 8.432486] irq: IRQ307: trimming hierarchy from :pmc@c360000
[ 8.438100] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 8.445280] tegra-se-nvhost 15810000.se: Adding to iommu group 44
[ 8.451736] tegra-se-nvhost 15810000.se: initialized
[ 8.463043] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 8.463299] tegra-se-nvhost 15820000.se: Adding to iommu group 45
[ 8.469033] tegra-se-nvhost 15820000.se: initialized
[ 8.475434] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 8.479538] tegra-se-nvhost 15840000.se: Adding to iommu group 46
[ 8.486152] tegra-se-nvhost 15840000.se: initialized
[ 8.494270] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 8.497402] tegra_actmon d230000.actmon: in actmon_register()...
[ 8.503092] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 8.508981] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 8.516486] hvc_sysfs: hypervisor is not present
[ 8.552391] ALSA device list:
[ 8.552483] No soundcards found.
[ 8.553133] Freeing unused kernel memory: 3968K
[ 8.553299] Run /init as init process
[ 8.563478] Root device found: mmcblk0p1
[ 8.564042] Found dev node: /dev/mmcblk0p1
[ 8.823394] EXT4-fs (mmcblk0p1): recovery complete
[ 8.824174] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.825314] Rootfs mounted over mmcblk0p1
[ 8.834223] Switching from initrd to actual rootfs
[ 8.935011] systemd[1]: System time before build time, advancing clock.
[ 8.966328] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP)
[ 8.967406] systemd[1]: Detected architecture arm64.
[ 8.991885] systemd[1]: Set hostname to <devkit-orin01>.
[ 9.167806] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firew.
[ 9.168182] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 9.169231] systemd[1]: Created slice system-modprobe.slice.
[ 9.169820] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 9.170307] systemd[1]: Created slice User and Session Slice.
[ 9.170563] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 9.171007] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 9.171340] systemd[1]: Reached target User and Group Name Lookups.
[ 9.171553] systemd[1]: Reached target Slices.
[ 9.171713] systemd[1]: Reached target Swap.
[ 9.172044] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 9.172336] systemd[1]: Listening on Syslog Socket.
[ 9.172574] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 9.172860] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 9.173318] systemd[1]: Listening on Journal Audit Socket.
[ 9.177410] systemd[1]: Listening on Journal Socket (/dev/log).
[ 9.183513] systemd[1]: Listening on Journal Socket.
[ 9.188507] systemd[1]: Listening on udev Control Socket.
[ 9.193933] systemd[1]: Listening on udev Kernel Socket.
[ 9.200312] systemd[1]: Mounting Huge Pages File System...
[ 9.205786] systemd[1]: Mounting POSIX Message Queue File System...
[ 9.212011] systemd[1]: Mounting RPC Pipe File System...
[ 9.217394] systemd[1]: Mounting Kernel Debug File System...
[ 9.223195] systemd[1]: Mounting Kernel Trace File System...
[ 9.229079] systemd[1]: Starting Journal Service...
[ 9.233957] systemd[1]: Starting Set the console keyboard layout...
[ 9.240105] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 9.247898] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 9.257044] systemd[1]: Started Nameserver information manager.
[ 9.262430] systemd[1]: Reached target Network (Pre).
[ 9.269199] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 9.276406] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 9.288678] systemd[1]: Starting Load Kernel Modules...
[ 9.291456] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 9.297203] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 9.303699] systemd[1]: Starting udev Coldplug all Devices...
[ 9.309791] systemd[1]: Mounted Huge Pages File System.
[ 9.313926] systemd[1]: Started Journal Service.
[ 9.342791] systemd-journald[303]: Received client request to flush runtime journal.
[ 9.354906] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 s0
[ 9.354906]
[ 9.658502] using random self ethernet address
[ 9.658652] using random host ethernet address
[ 9.718735] nvidia: loading out-of-tree module taints kernel.
[ 9.874547] 1 fixed-partitions partitions found on MTD device spi6.0
[ 9.874744] Creating 1 MTD partitions on "spi6.0":
[ 9.874879] 0x000000000000-0x000004000000 : "Whole_flash0"
[ 10.037310] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 10.390949] using random self ethernet address
[ 10.391095] using random host ethernet address
[ 13.822424] Bridge firewalling registered
[ 15.048680] ucsi_ccg 1-0008: failed to reset PPM!
[ 15.048927] ucsi_ccg 1-0008: PPM init failed (-110)
Ubuntu 20.04.4 LTS devkit-orin01 ttyTCU0
devkit-orin01 login:
SDK Manager logs:
SDKM_logs_JetPack_5.0.1_DP_Linux_for_Jetson_AGX_Orin_modules_2022-07-07_08-20-32.zip (198.9 KB)
Here’s the serial console log while trying to flash:
[0873.005] I> MB1 (version: 0.11.0.0-t234-54845784-7fb1fa27)
[0873.010] I> t234-A01-0-Silicon (0x12347) Prod
[0873.015] I> Boot-mode : BPMP Diagnostic
[0873.018] I> Emulation:
[0873.021] I> Entry timestamp: 0x00000000
[0873.024] I> last_boot_error: 0x0
[0873.028] I> BR-BCT: preprod_dev_sign: 0
[0873.031] I> rst_source: 0x0, rst_level: 0x0
[0873.035] I> Task: Clocks enable (0x50011b9d)
[0873.040] I> Task: Crypto init (0x50018df5)
[0873.044] I> Task: Secure debug controls (0x5000c76d)
[0873.049] E> Error: ECID of check failed!!
[0873.053] E> Error: ECID of check failed!!
[0873.057] E> Error: ECID of check failed!!
[0873.060] E> Error: ECID of check failed!!
[0873.064] I> Task: Program NV master stream id (0x5000c725)
[0873.070] I> Task: Verify boot mode (0xd482021)
[0873.078] I> Task: Alias fuses (0x5000ecd5)
[0873.083] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0873.090] I> Task: 0x5000e911
[0873.093] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0873.098] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0873.102] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0873.107] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0873.111] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0873.115] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0873.119] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0873.123] I> FUSE_SKU_INFO_0 = 0xd0
[0873.127] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0873.131] I> FUSE_PACKAGE_INFO_0 = 0x2
[0873.134] I> SKU: Perfect F0
[0873.137] I> Task: Voltage monitor (0x50011ba5)
[0873.141] I> VMON: Vmon re-calibration and fine tuning done
[0873.147] I> Task: Blockdev init (0x500157e1)
[0873.151] I> Task: UPHY init (0x5001b42d)
[0873.155] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0873.161] I> Task: Boot device init (0x5000d6a9)
[0873.165] E> Adding eMMC storage modules
[0873.169] I> Boot-device: RCM (instance: 0)
[0873.173] I> USB configuration success
[0873.681] I> Task: TSC init (0x5001c7e1)
[0873.685] I> Task: Enable WDT 5th expiry (0x5001d27d)
[0873.690] I> Task: Disable WDT globally (0x5001d2b9)
[0873.695] I> Task: I2C register (0x50000a09)
[0873.699] I> Task: Reset FSI (0x50011ba1)
[0873.703] I> Task: Enable clock-mon (0x5001c301)
[0873.718] I> FMON: Fmon re-programmed in mb1
[0873.723] I> Task: MB1 fixed firewalls (0x5001b1bd)
[0873.729] I> Task: Load MB2/Applet/FSKP (0x5001c305)
[0873.734] I> Loading MB2 Applet
[0873.737] I> Scratch RSV109: 0x00000000 active chain: 0
[0873.742] I> Slot: 0
[0873.744] I> Binary[21] block-0 (partition size: 0x50000)
[0873.750] I> get_binary_info: Binary name: MB2-Applet
[0873.755] I> Size of crypto header is 8192
[0873.759] I> BCH load address is : 0x4004e000
[0873.763] I> Size of crypto header is 8192
[0874.314] I> BCH of MB2-Applet read from storage
[0874.318] I> BCH address is : 0x4004e000
[0874.322] I> MB2-Applet header integrity check is success
[0874.328] I> Binary magic in BCH component 0 is MB2A
[0874.332] I> component binary type is 21
[0874.336] I> Size of crypto header is 8192
[0874.346] I> MB2-Applet binary is read from storage
[0874.352] I> MB2-Applet binary integrity check is success
[0874.357] I> Binary MB2-Applet loaded successfully at 0x40000000 (0x41b80)
[0874.364] I> Task: Prepare MB2 params (0x5001c3d5)
[0874.369] I> MB2-params @ 0x40060000
[0874.373] I> BR-BCT Boot Chain Fields
[0874.376] I> u32_non_gpio_select_boot_chain : 0
[0874.381] I> u32_num_boot_chains : 0
[0874.385] I> bf_bl_gpio_select_boot_chain_1b : 0
[0874.390] I> Task: Misc NV security settings (0x5000ca35)
[0874.395] I> NVDEC sticky bits programming done
[0874.400] I> Task: Disable/Reload WDT (0x5001d2e9)
[0874.404] I> Programmed SLCG global override := 0x0
[0874.409] I> MB1: MSS reconfig completed
I> Applet (version: 0.0.0.0-t234-54845784-6c7023cc)
I> Emulation:
I> Entry timestamp: 0xffffffff
I> Task: Pinmux init (0x4000062d)
I> Task: Boot device init (0x400012e5)
I> Applet do storage init
I> Boot_device: QSPI_FLASH instance: 0
I> Qspi clock source : clk_m
I> QSPI-0l initialized successfully
I> qspi flash-0 params source = safe params
I> sdmmc DDR50 mode
I> sdmmc-3 params source = safe params
I> sdmmc bdev is already initialized
E> mb2_config_storage_init_one_device: failed: Unknown device 7
I> Task: Partition Manager Init (0x40002cf5)
I> Found 57 partitions in QSPI_FLASH (instance 0)
W> Cannot find any partition table for 00000003
> PARTITION_MANAGER: Failed to publish partition.
W> Cannot find any partition table for 00010003
I> Task: I2C register (0x400006a5)
I> Task: Register exit handlers (0x400005f5)
I> Task: Enter 3p server (0x400018b5)
I> Populate chip info
I> RAM_CODE 0x4000001
I> Populate eeprom info
I> Populate eeprom info for module cvm
I> dump bct
I> Rebooting : reboot-recovery
E> instance 0 not supported for module 8
Could you use the serial console and check what is the size of DRAM on your device?
Btw, your log is truncated in each line.
Meminfo:
akhripin@devkit-orin01:~$ cat /proc/meminfo
MemTotal: 31357604 kB
MemFree: 29759008 kB
MemAvailable: 30076680 kB
Buffers: 39392 kB
Cached: 590536 kB
SwapCached: 0 kB
Active: 149048 kB
Inactive: 867852 kB
Active(anon): 2568 kB
Inactive(anon): 422420 kB
Active(file): 146480 kB
Inactive(file): 445432 kB
Unevictable: 18372 kB
Mlocked: 0 kB
SwapTotal: 15678768 kB
SwapFree: 15678768 kB
Dirty: 24 kB
Writeback: 0 kB
AnonPages: 381516 kB
Mapped: 224284 kB
Shmem: 20912 kB
KReclaimable: 60308 kB
Slab: 166660 kB
SReclaimable: 60308 kB
SUnreclaim: 106352 kB
KernelStack: 9568 kB
PageTables: 10304 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 31357568 kB
Committed_AS: 2963988 kB
VmallocTotal: 135290159040 kB
VmallocUsed: 95316 kB
VmallocChunk: 0 kB
Percpu: 6624 kB
HardwareCorrupted: 0 kB
AnonHugePages: 61440 kB
ShmemHugePages: 0 kB
ShmemPmdMapped: 0 kB
FileHugePages: 0 kB
FilePmdMapped: 0 kB
CmaTotal: 262144 kB
CmaFree: 127032 kB
HugePages_Total: 0
HugePages_Free: 0
HugePages_Rsvd: 0
HugePages_Surp: 0
Hugepagesize: 2048 kB
Hugetlb: 0 kB
Non-truncated serial log on boot:
[0000.065] I> MB1 (version: 0.11.0.0-t234-54845784-7fb1fa27)
[0000.070] I> t234-A01-0-Silicon (0x12347) Prod
[0000.074] I> Boot-mode : Coldboot
[0000.077] I> Emulation:
[0000.080] I> Entry timestamp: 0x00000000
[0000.083] I> last_boot_error: 0x0
[0000.087] I> BR-BCT: preprod_dev_sign: 0
[0000.090] I> rst_source: 0x0, rst_level: 0x0
[0000.094] I> Task: Clocks enable (0x50011b9d)
[0000.099] I> Task: Crypto init (0x50018df5)
[0000.103] I> Task: Secure debug controls (0x5000c76d)
[0000.108] E> Error: ECID of check failed!!
[0000.112] E> Error: ECID of check failed!!
[0000.116] E> Error: ECID of check failed!!
[0000.119] E> Error: ECID of check failed!!
[0000.123] I> Task: Program NV master stream id (0x5000c725)
[0000.129] I> Task: Verify boot mode (0xd482021)
[0000.137] I> Task: Alias fuses (0x5000ecd5)
[0000.142] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0000.149] I> Task: 0x5000e911
[0000.152] I> FUSE_OPT_CCPLEX_CLUSTER_DISABLE = 0x00000000
[0000.157] I> FUSE_OPT_GPC_DISABLE = 0x00000000
[0000.161] I> FUSE_OPT_DLA_DISABLE = 0x00000000
[0000.165] I> FUSE_OPT_EMC_DISABLE = 0x00000000
[0000.170] I> FUSE_BOOTROM_PATCH_VERSION = 0x7
[0000.174] I> FUSE_PSCROM_PATCH_VERSION = 0x7
[0000.178] I> FUSE_OPT_ADC_CAL_FUSE_REV = 0x2
[0000.182] I> FUSE_SKU_INFO_0 = 0xd0
[0000.185] I> FUSE_OPT_SAMPLE_TYPE_0 = 0x3 PS
[0000.190] I> FUSE_PACKAGE_INFO_0 = 0x2
[0000.193] I> SKU: Perfect F0
[0000.196] I> Task: Voltage monitor (0x50011ba5)
[0000.200] I> VMON: Vmon re-calibration and fine tuning done
[0000.206] I> Task: Blockdev init (0x500157e1)
[0000.210] I> Task: UPHY init (0x5001b42d)
[0000.214] E> UPHY: UPHY lane info table is empty in MB1 BCT.
[0000.219] I> Task: Boot device init (0x5000d6a9)
[0000.224] E> Adding eMMC storage modules
[0000.228] I> Boot-device: QSPI (instance: 0)
[0000.232] I> qspi flash params source = mb1bct
[0000.236] I> Qspi clock source : pllc_out0
[0000.240] I> QSPI-0l initialized successfully
[0000.244] I> Task: TSC init (0x5001c7e1)
[0000.248] I> Task: Enable WDT 5th expiry (0x5001d27d)
[0000.253] I> Task: Disable WDT globally (0x5001d2b9)
[0000.258] I> Task: I2C register (0x50000a09)
[0000.262] I> Task: Reset FSI (0x50011ba1)
[0000.266] I> Task: Pinmux init (0x50010e95)
[0000.271] I> Task: Prod config init (0x50011075)
[0000.275] I> Task: Pad voltage init (0x50010f85)
[0000.279] I> Task: Prod init (0x50011119)
[0000.283] I> Task: Thermal check (0x5001121d)
[0000.288] I> max_chip_limit = 115
[0000.291] I> min_chip_limit = -30
[0000.304] I> max temp read = 36
[0000.307] I> min temp read = 35
[0000.310] I> Task: Common rail init (0x50011695)
[0000.314] W> Thermal config not found in BCT
[0000.318] W> Generic i2c config not found in BCT
[0000.324] > DEVICE_PROD: module = 13, instance = 4 not found in device prod.
[0000.332] W> MEMIO rail config not found in BCT
[0000.337] I> Task: Mem clock src (0x5000f6b9)
[0000.341] I> Task: BR PMIC seq (0x50011711)
[0000.345] I> Task: Misc. board config (0x500116ed)
[0000.349] W> Platform config not found in BCT
[0000.354] I> Task: Load membct (0x5000f5d5)
[0000.358] I> RAM_CODE 0x4000401
[0000.361] I> Loading MEM-BCT to SysRAM
[0000.364] I> Scratch RSV109: 0x00000001 active chain: 0
[0000.370] I> Slot: 0
[0000.372] I> Binary[0] block-0 (partition size: 0x40000)
[0000.377] I> get_binary_info: Binary name: MEM-BCT-0
[0000.382] I> Size of crypto header is 8192
[0000.386] I> BCH load address is : 0x40050000
[0000.390] I> Size of crypto header is 8192
[0000.394] I> BCH of MEM-BCT-0 read from storage
[0000.398] I> BCH address is : 0x40050000
[0000.402] I> MEM-BCT-0 header integrity check is success
[0000.407] I> Binary magic in BCH component 0 is MEM0
[0000.412] I> component binary type is 0
[0000.417] I> MEM-BCT-0 binary is read from storage
[0000.421] I> MEM-BCT-0 binary integrity check is success
[0000.427] I> Binary MEM-BCT-0 loaded successfully at 0x40040000 (0xe580)
[0000.437] I> RAM_CODE 0x4000401
[0000.441] I> Task: Save mem-bct info (0x50011d59)
[0000.445] I> Task: SDRAM params override (0x50010c79)
[0000.450] I> Task: Carveout allocate (0x50011da5)
[0000.455] I> RCM blob carveout will not be allocated
[0000.460] I> ECC region[0]: Start:0x0, End:0x0
[0000.464] I> ECC region[1]: Start:0x0, End:0x0
[0000.468] I> ECC region[2]: Start:0x0, End:0x0
[0000.472] I> ECC region[3]: Start:0x0, End:0x0
[0000.477] I> ECC region[4]: Start:0x0, End:0x0
[0000.481] I> Non-ECC region[0]: Start:0x80000000, End:0x100000000
[0000.487] I> Non-ECC region[1]: Start:0x0, End:0x0
[0000.492] I> Non-ECC region[2]: Start:0x0, End:0x0
[0000.496] I> Non-ECC region[3]: Start:0x0, End:0x0
[0000.501] I> Non-ECC region[4]: Start:0x0, End:0x0
[0000.508] I> allocated(CO:51) base:0x80000000 size:0x8000000 align: 0x200000
[0000.514] I> allocated(CO:44) base:0xd6000000 size:0x2a000000 align: 0x100000
[0000.521] I> allocated(CO:31) base:0xce000000 size:0x8000000 align: 0x100000
[0000.528] I> allocated(CO:39) base:0xc8000000 size:0x6000000 align: 0x200000
[0000.535] I> allocated(CO:20) base:0xc6000000 size:0x2000000 align: 0x2000000
[0000.542] I> allocated(CO:24) base:0xc4000000 size:0x2000000 align: 0x2000000
[0000.549] I> allocated(CO:28) base:0xc2000000 size:0x2000000 align: 0x2000000
[0000.556] I> allocated(CO:29) base:0xc0000000 size:0x2000000 align: 0x2000000
[0000.563] I> allocated(CO:41) base:0xbf000000 size:0x1000000 align: 0x100000
[0000.570] I> allocated(CO:43) base:0xbe000000 size:0x1000000 align: 0x200000
[0000.577] I> allocated(CO:02) base:0xbd800000 size:0x800000 align: 0x800000
[0000.584] I> allocated(CO:03) base:0xbd000000 size:0x800000 align: 0x800000
[0000.591] I> allocated(CO:06) base:0xbc800000 size:0x800000 align: 0x800000
[0000.598] I> allocated(CO:10) base:0xbc000000 size:0x800000 align: 0x800000
[0000.605] I> allocated(CO:56) base:0xbb800000 size:0x800000 align: 0x200000
[0000.611] I> allocated(CO:07) base:0xbb400000 size:0x400000 align: 0x400000
[0000.618] I> allocated(CO:22) base:0xbb000000 size:0x400000 align: 0x400000
[0000.625] I> allocated(CO:33) base:0xbac00000 size:0x400000 align: 0x200000
[0000.632] I> allocated(CO:47) base:0xba800000 size:0x400000 align: 0x200000
[0000.639] I> allocated(CO:01) base:0xba700000 size:0x100000 align: 0x100000
[0000.645] I> allocated(CO:04) base:0xba600000 size:0x100000 align: 0x100000
[0000.652] I> allocated(CO:05) base:0xba500000 size:0x100000 align: 0x100000
[0000.659] I> allocated(CO:08) base:0xba400000 size:0x100000 align: 0x100000
[0000.666] I> allocated(CO:09) base:0xba300000 size:0x100000 align: 0x100000
[0000.673] I> allocated(CO:15) base:0xba200000 size:0x100000 align: 0x100000
[0000.680] I> allocated(CO:17) base:0xba100000 size:0x100000 align: 0x100000
[0000.686] I> allocated(CO:23) base:0xba000000 size:0x100000 align: 0x100000
[0000.693] I> allocated(CO:27) base:0xb9f00000 size:0x100000 align: 0x100000
[0000.700] I> allocated(CO:42) base:0xb9e00000 size:0x100000 align: 0x100000
[0000.707] I> allocated(CO:54) base:0xb9d80000 size:0x80000 align: 0x80000
[0000.714] I> allocated(CO:26) base:0xb9d40000 size:0x40000 align: 0x2000
[0000.720] I> allocated(CO:48) base:0xb9d20000 size:0x20000 align: 0x10000
[0000.727] I> allocated(CO:34) base:0xb9d10000 size:0x10000 align: 0x10000
[0000.733] I> allocated(CO:35) base:0xb9d00000 size:0x10000 align: 0x10000
[0000.740] I> allocated(CO:49) base:0xb9cf0000 size:0x10000 align: 0x10000
[0000.747] I> allocated(CO:50) base:0xb9ce0000 size:0x10000 align: 0x10000
[0000.753] I> allocated(CO:52) base:0xb9cd0000 size:0x10000 align: 0x10000
[0000.760] I> Task: SDRAM init (0x5000f6bd)
[0000.767] I> SDRAM-params @ 0xd485000
[0000.770] I> MSS code-drop: NvBootSdramInit
[0000.774] I> MSS CAR: PLLM/HUB programming for MemoryType: 4 and MemBctRevision: 8
[0000.781] I> MSS CAR: Init PLLM
[0000.785] I> MSS CAR: Init PLLHUB
[0000.795] I> mb1_sdram_init Done !
[0000.798] I> SDRAM Size in Total 800000000
[0000.802] I> SDRAM test pass
[0000.805] I> Task: Dram ecc scrub (0x5000f2c9)
[0000.809] I> Task: DRAM alias check (0x50010c71)
[0001.026] I> Task: Register checker (0x50010c75)
[0001.034] I> Task: Enable clock-mon (0x5001c301)
[0001.051] I> FMON: Fmon re-programmed in mb1
[0001.056] I> Task: Mapper init (0x5001a0d5)
[0001.061] I> Task: SC7 Context Init (0x5001cacd)
[0001.067] I> NV_SC7 Context addr: 0xa0000000
[0001.072] I> Task: CCPLEX IST init (0x5000ce75)
[0001.078] I> Task: CPU WP0 (0x5000c2c9)
[0001.084] I> Loading MCE
[0001.086] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.092] I> Slot: 0
[0001.095] I> Binary[8] block-0 (partition size: 0x80000)
[0001.101] I> get_binary_info: Binary name: MCE
[0001.105] I> Size of crypto header is 8192
[0001.110] I> BCH load address is : 0x4003e000
[0001.115] I> Size of crypto header is 8192
[0001.120] I> BCH of MCE read from storage
[0001.124] I> BCH address is : 0x4003e000
[0001.130] I> MCE header integrity check is success
[0001.135] I> Binary magic in BCH component 0 is MTSM
[0001.140] I> component binary type is 8
[0001.145] I> Size of crypto header is 8192
[0001.151] I> MCE binary is read from storage
[0001.156] I> MCE binary integrity check is success
[0001.162] I> Binary MCE loaded successfully at 0x40000000 (0x29e90)
[0001.169] I> Size of crypto header is 8192
[0001.181] I> Size of crypto header is 8192
[0001.185] I> Sending WP0 mailbox command to PSC
[0001.198] I> Task: MB1 fixed firewalls (0x5001b1bd)
[0001.210] I> Task: Load bpmp-fw (0x5001b311)
[0001.215] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.221] I> Slot: 0
[0001.223] I> Binary[15] block-0 (partition size: 0x100000)
[0001.230] I> get_binary_info: Binary name: BPMP_FW
[0001.235] I> Size of crypto header is 8192
[0001.239] I> BCH load address is : 0x807fe000
[0001.245] I> Size of crypto header is 8192
[0001.250] I> BCH of BPMP_FW read from storage
[0001.254] I> BCH address is : 0x807fe000
[0001.260] I> BPMP_FW header integrity check is success
[0001.265] I> Binary magic in BCH component 0 is BPMF
[0001.271] I> component binary type is 15
[0001.275] I> Size of crypto header is 8192
[0001.290] I> BPMP_FW binary is read from storage
[0001.297] I> BPMP_FW binary integrity check is success
[0001.303] I> Binary BPMP_FW loaded successfully at 0x80000000 (0xf3940)
[0001.311] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.317] I> Slot: 0
[0001.319] I> Binary[16] block-0 (partition size: 0x100000)
[0001.325] I> get_binary_info: Binary name: BPMP_FW_DTB
[0001.331] I> Size of crypto header is 8192
[0001.335] I> BCH load address is : 0x807fc000
[0001.341] I> Size of crypto header is 8192
[0001.346] I> BCH of BPMP_FW_DTB read from storage
[0001.351] I> BCH address is : 0x807fc000
[0001.356] I> BPMP_FW_DTB header integrity check is success
[0001.362] I> Binary magic in BCH component 0 is BPMD
[0001.367] I> component binary type is 16
[0001.372] I> Size of crypto header is 8192
[0001.378] I> BPMP_FW_DTB binary is read from storage
[0001.384] I> BPMP_FW_DTB binary integrity check is success
[0001.390] I> Binary BPMP_FW_DTB loaded successfully at 0x807dbc00 (0x20380)
[0001.398] I> Program IPC carveouts
[0001.404] I> Task: Load psc-fw (0x5001b3b9)
[0001.410] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.415] I> Slot: 0
[0001.418] I> Binary[17] block-0 (partition size: 0x80000)
[0001.424] I> get_binary_info: Binary name: PSC_FW
[0001.429] I> Size of crypto header is 8192
[0001.434] I> BCH load address is : 0x803fe000
[0001.439] I> Size of crypto header is 8192
[0001.444] I> BCH of PSC_FW read from storage
[0001.448] I> BCH address is : 0x803fe000
[0001.454] I> PSC_FW header integrity check is success
[0001.459] I> Binary magic in BCH component 0 is PFWP
[0001.465] I> component binary type is 17
[0001.469] I> Size of crypto header is 8192
[0001.477] I> PSC_FW binary is read from storage
[0001.483] I> PSC_FW binary integrity check is success
[0001.489] I> Binary PSC_FW loaded successfully at 0x80000000 (0x57800)
[0001.497] I> Task: Load nvdec-fw (0x5001c05d)
[0001.503] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.509] I> Slot: 0
[0001.511] I> Binary[7] block-0 (partition size: 0x100000)
[0001.517] I> get_binary_info: Binary name: NVDEC
[0001.522] I> Size of crypto header is 8192
[0001.527] I> BCH load address is : 0x800fe000
[0001.532] I> Size of crypto header is 8192
[0001.537] I> BCH of NVDEC read from storage
[0001.541] I> BCH address is : 0x800fe000
[0001.547] I> NVDEC header integrity check is success
[0001.552] I> Binary magic in BCH component 0 is NDEC
[0001.558] I> component binary type is 7
[0001.562] I> Size of crypto header is 8192
[0001.569] I> NVDEC binary is read from storage
[0001.574] I> NVDEC binary integrity check is success
[0001.580] I> Binary NVDEC loaded successfully at 0x80000000 (0x35000)
[0001.592] I> Task: Load tsec-fw (0x5001c249)
[0001.597] I> TSEC-FW load support not enabled
[0001.602] I> Task: TZDRAM setup (0x50012515)
[0001.607] I> Task: SC7 context save (0x5001cbd1)
[0001.613] I> NV_SC7 Context addr: 0xa0000000
[0001.619] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.625] I> Slot: 0
[0001.627] I> Binary[13] block-0 (partition size: 0x20000)
[0001.633] I> get_binary_info: Binary name: SC7-FW
[0001.638] I> Size of crypto header is 8192
[0001.643] I> Size of crypto header is 8192
[0001.648] I> BCH load address is : 0xa0002000
[0001.653] I> Size of crypto header is 8192
[0001.658] I> BCH of SC7-FW read from storage
[0001.663] I> BCH address is : 0xa0002000
[0001.668] I> SC7-FW header integrity check is success
[0001.674] I> Binary magic in BCH component 0 is WB0B
[0001.679] I> component binary type is 13
[0001.683] I> Size of crypto header is 8192
[0001.688] I> SC7-FW binary is read from storage
[0001.694] I> SC7-FW binary integrity check is success
[0001.699] I> Binary SC7-FW loaded successfully at 0xa0004000 (0xa4e0)
[0001.707] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.713] I> Slot: 0
[0001.715] I> Binary[22] block-0 (partition size: 0x30000)
[0001.721] I> get_binary_info: Binary name: PSC_RF
[0001.727] I> Size of crypto header is 8192
[0001.731] I> Size of crypto header is 8192
[0001.736] I> BCH load address is : 0xa000e4e0
[0001.741] I> Size of crypto header is 8192
[0001.746] I> BCH of PSC_RF read from storage
[0001.751] I> BCH address is : 0xa000e4e0
[0001.756] I> PSC_RF header integrity check is success
[0001.762] I> Binary magic in BCH component 0 is PSCR
[0001.767] I> component binary type is 22
[0001.771] I> Size of crypto header is 8192
[0001.777] I> PSC_RF binary is read from storage
[0001.783] I> PSC_RF binary integrity check is success
[0001.788] I> Binary PSC_RF loaded successfully at 0xa00104e0 (0x1af70)
[0001.807] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.813] I> Slot: 0
[0001.815] I> Binary[14] block-0 (partition size: 0x20000)
[0001.821] I> get_binary_info: Binary name: MB2_RF
[0001.826] I> Size of crypto header is 8192
[0001.831] I> Size of crypto header is 8192
[0001.836] I> BCH load address is : 0xa008c020
[0001.841] I> Size of crypto header is 8192
[0001.846] I> BCH of MB2_RF read from storage
[0001.851] I> BCH address is : 0xa008c020
[0001.856] I> MB2_RF header integrity check is success
[0001.862] I> Binary magic in BCH component 0 is MB2R
[0001.867] I> component binary type is 14
[0001.871] I> Size of crypto header is 8192
[0001.876] I> MB2_RF binary is read from storage
[0001.882] I> MB2_RF binary integrity check is success
[0001.887] I> Binary MB2_RF loaded successfully at 0xa008e020 (0xd360)
[0001.896] E> FUSE_ALIAS: Fuse alias on production fused part is not supported.
[0001.904] I> SC7 context fuse-bypass data is empty
[0001.909] I> SC7 context save done
[0001.913] I> Task: Load MB2/Applet/FSKP (0x5001c305)
[0001.919] I> Loading MB2
[0001.922] I> Scratch RSV109: 0x00000001 active chain: 0
[0001.928] I> Slot: 0
[0001.930] I> Binary[6] block-0 (partition size: 0x70000)
[0001.936] I> get_binary_info: Binary name: MB2
[0001.941] I> Size of crypto header is 8192
[0001.946] I> BCH load address is : 0x8007e000
[0001.951] I> Size of crypto header is 8192
[0001.956] I> BCH of MB2 read from storage
[0001.960] I> BCH address is : 0x8007e000
[0001.966] I> MB2 header integrity check is success
[0001.971] I> Binary magic in BCH component 0 is MB2B
[0001.976] I> component binary type is 6
[0001.980] I> Size of crypto header is 8192
[0001.990] I> MB2 binary is read from storage
[0001.995] I> MB2 binary integrity check is success
[0002.001] I> Binary MB2 loaded successfully at 0x80000000 (0x69940)
[0002.009] I> Task: Prepare MB2 params (0x5001c3d5)
[0002.016] I> MB2-params @ 0x40060000
[0002.023] I> BR-BCT Boot Chain Fields
[0002.027] I> u32_non_gpio_select_boot_chain : 0
[0002.032] I> u32_num_boot_chains : 2
[0002.037] I> bf_bl_gpio_select_boot_chain_1b : 0
[0002.042] I> Task: Dram ecc test (0x5000f379)
[0002.048] I> Task: Misc NV security settings (0x5000ca35)
[0002.054] I> NVDEC sticky bits programming done
[0002.059] I> Task: GPIO interrupt map (0x50011a61)
[0002.066] I> Task: Disable/Reload WDT (0x5001d2e9)
[0002.071] I> Programmed SLCG global override := 0x0
[0002.077] I> MB1: MSS reconfig completed
I> MB2 (version: 0.0.0.0-t234-54845784-e8d12f8b)
I> Emulation:
I> Entry timestamp: 0x002064fb
I> Regular heap: [base:0x40040000, size:0x10000]
I> DMA heap: [base:0xbb800000, size:0x800000]
I> Task: Enable hot-plug capability (0x5001aed8)
I> Task: Set blob address (0x50001c70)
I> Task: PSC mailbox init (0x5000e5e0)
I> Task: Crypto init (0x50005abc)
I> Task: I2C register (0x50001c5c)
I> Task: Boot device init (0x50001d2c)
I> qspi flash-0 params source = MB2 params
I> sdmmc-3 params source = MB2 params
I> Task: Partition Manager Init (0x50001cf8)
I> Found 11 partitions in SDMMC_USER (instance 3)
I> Task: Load and authenticate registered FWs (0x50012818)
I> Task: Load AUXP FWs (0x5001aa7c)
I> Successfully register SPE FW load task with MB2 loader
I> Skipping SCE FW load
I> Successfully register RCE FW load task with MB2 loader
I> Successfully register DCE FW load task with MB2 loader
I> Unpowergating APE
I> Unpowergate done
I> Successfully register APE FW load task with MB2 loader
I> Skipping FSI FW load
I> Successfully register XUSB FW load task with MB2 loader
I> Partition name: A_spe-fw
I> Size of partition: 589824
I> Binary@ device:3/0 block-56320 (partition size: 0x90000), name: A_spe-fw
E> Binary spe is not found in comp table
I> Partition name: A_rce-fw
I> Size of partition: 1048576
I> Binary@ device:3/0 block-57472 (partition size: 0x100000), name: A_rce-fw
E> Binary rce is not found in comp table
I> spe: Authentication Finalize Done
I> Binary spe loaded successfully at 0xba400000
I> Partition name: A_dce-fw
I> Size of partition: 9437184
I> Binary@ device:3/0 block-37888 (partition size: 0x900000), name: A_dce-fw
E> Binary dce is not found in comp table
I> rce: Authentication Finalize Done
I> Binary rce loaded successfully at 0xba100000
I> Partition name: A_adsp-fw
I> Size of partition: 2097152
I> Binary@ device:3/0 block-59520 (partition size: 0x200000), name: A_adsp-fw
E> Binary ape is not found in comp table
I> dce: Authentication Finalize Done
I> Binary dce loaded successfully at 0xc6000000
I> Partition name: A_xusb-fw
I> Size of partition: 262144
I> Binary@ device:3/0 block-10368 (partition size: 0x40000), name: A_xusb-fw
E> Binary xusb is not found in comp table
I> ape: Authentication Finalize Done
I> Binary ape loaded successfully at 0xbb400000
I> xusb: Authentication Finalize Done
I> Binary xusb loaded successfully at 0xba500000
I> Task: Carveout setup (0x50014018)
I> Program remaining OEM carveouts
I> Task: Restore XUSB sec (0x50001c30)
I> Task: OEM firewalls (0x50017ee0)
I> MB2-BCT Firewall data is empty
I> Task: Unhalt AUXPs (0x5001ace4)
I> Unhalting SPE..
I> Enabling combined UART
����spe: early_init
vic initialized
tsc initialized
aon lic initialized
spe: tag is 9f1f07bc2d4b6509c13554672acefaad
spe: SafeRTOS v8.4
spe: init
scheduler initialized
aon hsp initialized
tag initialized
tcu initialized
bpmp ipc initialized
spe: late init
cpu_nic clock initialized
apb clock initialized
pm initialized
bpmp hsp initialized
top1 hsp initialized
ccplex ipc initialized
spe: start scheduler
I> Task: Trigger mailbox for PSC-BL1 exit (0x5000e660)
I> Sending opcode 0x4d420802 to psc
��INFO: Entering psc_monitor_init!
INFO: GSC22 BOM:0xbb000000 SIZE:0x400000 CLIENT_ACCESS1:00180000
INFO: PSCFW BUILD VERSION: a796142-39d6527-7490c54-dev
INFO: mstatus:0xa00000808
INFO: Supervisor entry_point:c108c00
INFO: pllpsc is alrea��I> Received ACK from psc
I> Task: Start secure NOR provision (0x50010b3c)
I> Task: Load FSI keyblob (0x5000ea28)
I> ��
��dy locked.
INFO: MONITOR: user task addr:0xbb022000, blob offset:0x0002000��Skipping FSI key blob copy
I> Task: Enable FSITHERM (0x5000e5b4)
��0
��I> Task: Unhalt AUXPs (0x5001acec)
I> SCE unhalt skipped
I> Unhalting RCE
I> RCE unhalt successful
I> DCE unhalt successful
I> APE unhalt skipped
I> FSI unhalt skipped
I> Task: Load CPUBL (0x5000f7c4)
I> Task: Load TOS (0x5000fe50)
I> ��bpmp: init
bpmp: base binary md5 is f0425a554b39d571b1bbb5291283d946
bpmp: combined binary md5 is 43f75b5aad2b8e1992e4e049bafc8696
bpmp: firmware tag is 43��Task: Load and authenticate registered FWs (0x50012818)
I> Scratch RSV109: 0x��[ 2.441877] Camera-FW on t234-rce-safe started
��INFO: MONITOR: populated��TCU early console enabled.
��00000001 active chain: 0
I> Partition name: A_cpu-bootloader
I> Size of partition: 3670016
I> Binary@ device:3/0 block-17920 (partition size: 0x380000), name: A_cpu-bootloader
��f75b5aad2b8e1992e4-f0425a554b3
initialized vwdt
initialized clk_mach_early
initialized mail_early
initialized fuse
initialized vfrel
initialized hwwdt
initialized adc
fmon_populate_monitors: found 199 monitors
initialized fmon
initialized mc
initialized reset
initialized uphy_early
initialized emc_early
469 clocks registered
initialized clk_cal_early
initialized clk_mach_early_config
initialized io_dpd
initialized thermal
initialized soctherm
initialized regime
initialized i2c
vrmon_dt_init: vrmon node not found
vrmon_chk_boot_state: found 0 rail monitors
initialized vrmon
initialized regulator
initialized avfs_clk_platform
initialized powergate
initialized dvs
initialized clk_mach_config
initialized pm
initialized suspend
initialized strap
initialized emc
��E> Binary cpubl is not found in comp table
��initialized emc_mrq
WARNING @ [platform/drivers/clk/clk-fwk/clk-cal.c]: aon_apb is not configured by BPMP-FW
WARNING @ [platform/drivers/clk/clk-fwk/clk-cal.c]: aon_cpu_nic is not configured��
�� user images:16
INFO: mret to Supervisor!
INFO: psc supervisor init.
INF�� by BPMP-FW
initialized clk_cal
initialized uphy_dt
��O: psc_irq_init...
INFO: enter idle task.
��I> Scratch RSV109: 0x00000001 active chain: 0
I> Partition name: A_secure-os
I> Size of partition: 4194304
�� Binary@ device:3/0 block-25088 (partition size: 0x400000), name: A_secure-os��initialized uphy_mrq
initialized uphy
initialized pg_late
initialized pg_mrq_init
swdtimer_��E> Binary tos is not found in comp table
��init: 0 reg polling start w period 47 ms
initialized swdtimer
initialized hwwdt_late
initialized bwmgr
initialized thermal_host_trip
initialized thermal_mrq
initialized reset_mrq
initialized mail_mrq
initialized fmon_mrq
initialized clk_mrq
��I> MB2-params @ 0x400��initialized avfs_mrq
initialized i2c_mrq
initialized tag_mrq
initialized bwmgr_mrq
initialized console_mrq
initialized mrq
missing prod DT calibration data for 199 fmons
initialized clk_sync_fmon_post
initialized clk_cal_late
ini��60000
I> CPUBL-params @ 0xc2000000
��tialized noc_late
initialized dbells
��[ 2.656780] Camera-FW on t234-rce-safe ready SHA1=ab261c6c (crt 16.427 ms,��initialized dmce
initialized cvc
initialized avfs_clk_mach_post
initialized pm_post
initialized avfs_clk_platform_post
initialized cvc_late
initialized �� total boot 232.384 ms)
��rm
initialized console_late
initialized clk_mach_post
initialized pg_post
initialized regulator_post
initialized profile
initialized fuse_late
initialized extras_post
bpmp: init complete
��DCE: FW Boot Done
��I> cpubl: Authentication Finalize Done
I> Binary cpubl loaded successfully at 0xba800000
I> tos: Authentication Finalize Done
I> Binary tos loaded successfully at 0xbeee7000
I> Task: Prepare TOS params (0x5000fdcc)
I> Task: OEM SC7 context save (0x50010878)
I> oem sc7 context saved
I> Task: Disable MSS perf stats (0x5001ad78)
I> Task: Program display sticky bits (0x5001acf4)
I> Task: Storage device deinit (0x50001ca4)
I> Task: SMMU init (0x5001a738)
I> Task: Program CBB PCIE AMAP regions (0x500031dc)
I> Task: Program GICv3 registers (0x5001ae18)
I> Task: Audit firewall settings (0x5001816c)
I> MB2 finished
��NOTICE: BL31: v2.5(release):ef8af0b99
NOTICE: BL31: Built : 20:58:00, May 16 2022
ERROR: Error initializing runtime service trusty_fast
Jetson UEFI firmware (version r34.1-975eef6 built on 2022-05-16T20:58:45-07:00)
** WARNING: Test Key is used. **
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services and installing virtual address map...
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.10.65-tegra (buildbrain@mobile-u64-5414-d7000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2020.08) 9.3.0, GNU ld (GNU Binutils) 2.33.1) #1 SMP PREEMPT Mon May 16 20:58:07 PDT 2022
[ 0.000000] OF: fdt: memory scan node memory@80000000, reg size 16,
[ 0.000000] OF: fdt: - 80000000 , c0000000
[ 0.000000] Machine model: NVIDIA Orin Jetson-Small Developer Kit
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x8546a7898 SMBIOS=0xbabc0000 SMBIOS 3.0=0x853230000 MEMATTR=0x852ec2018 ESRT=0x853199f18 RNG=0x85435ff18 MEMRESERVE=0x852ec3f18
[ 0.000000] efi: seeding entropy pool
[ 0.000000] esrt: Reserving ESRT space from 0x0000000853199f18 to 0x0000000853199f50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000086b800000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] OF: reserved mem: initialized node fsi-carveout, compatible id nvidia,fsi-carveout
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x000000087fffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x0000000087ffffff]
[ 0.000000] node 0: [mem 0x0000000088000000-0x00000000b9ccffff]
[ 0.000000] node 0: [mem 0x00000000ba800000-0x00000000ba9affff]
[ 0.000000] node 0: [mem 0x00000000babb0000-0x00000000babcffff]
[ 0.000000] node 0: [mem 0x00000000babd0000-0x00000000babfffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000c3ffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000084fffffff]
[ 0.000000] node 0: [mem 0x0000000850000000-0x0000000851faffff]
[ 0.000000] node 0: [mem 0x0000000851fb0000-0x0000000852cf0fff]
[ 0.000000] node 0: [mem 0x0000000852cf1000-0x0000000852e52fff]
[ 0.000000] node 0: [mem 0x0000000852e53000-0x0000000852e8ffff]
[ 0.000000] node 0: [mem 0x0000000852e90000-0x0000000852eaffff]
[ 0.000000] node 0: [mem 0x0000000852eb0000-0x000000085316ffff]
[ 0.000000] node 0: [mem 0x0000000853170000-0x000000085318ffff]
[ 0.000000] node 0: [mem 0x0000000853190000-0x000000085321ffff]
[ 0.000000] node 0: [mem 0x0000000853220000-0x000000085323ffff]
[ 0.000000] node 0: [mem 0x0000000853240000-0x0000000853ceffff]
[ 0.000000] node 0: [mem 0x0000000853cf0000-0x0000000853f1ffff]
[ 0.000000] node 0: [mem 0x0000000853f20000-0x0000000853fdffff]
[ 0.000000] node 0: [mem 0x0000000853fe0000-0x000000085411ffff]
[ 0.000000] node 0: [mem 0x0000000854120000-0x000000085418ffff]
[ 0.000000] node 0: [mem 0x0000000854190000-0x000000085424ffff]
[ 0.000000] node 0: [mem 0x0000000854250000-0x000000085425ffff]
[ 0.000000] node 0: [mem 0x0000000854260000-0x00000008542fffff]
[ 0.000000] node 0: [mem 0x0000000854300000-0x000000085434ffff]
[ 0.000000] node 0: [mem 0x0000000854350000-0x000000085435ffff]
[ 0.000000] node 0: [mem 0x0000000854360000-0x00000008543affff]
[ 0.000000] node 0: [mem 0x00000008543b0000-0x000000085456ffff]
[ 0.000000] node 0: [mem 0x0000000854570000-0x000000085457ffff]
[ 0.000000] node 0: [mem 0x0000000854580000-0x000000085465ffff]
[ 0.000000] node 0: [mem 0x0000000854660000-0x00000008546dffff]
[ 0.000000] node 0: [mem 0x00000008546e0000-0x000000085477ffff]
[ 0.000000] node 0: [mem 0x0000000854780000-0x000000085485ffff]
[ 0.000000] node 0: [mem 0x0000000854860000-0x00000008548affff]
[ 0.000000] node 0: [mem 0x00000008548b0000-0x000000085493ffff]
[ 0.000000] node 0: [mem 0x0000000854940000-0x000000085498ffff]
[ 0.000000] node 0: [mem 0x0000000854990000-0x00000008549affff]
[ 0.000000] node 0: [mem 0x00000008549b0000-0x0000000854a4ffff]
[ 0.000000] node 0: [mem 0x0000000854a50000-0x0000000854aaffff]
[ 0.000000] node 0: [mem 0x0000000854ab0000-0x0000000854b9ffff]
[ 0.000000] node 0: [mem 0x0000000854ba0000-0x000000085537ffff]
[ 0.000000] node 0: [mem 0x0000000855380000-0x000000085555ffff]
[ 0.000000] node 0: [mem 0x0000000855560000-0x000000087b8bffff]
[ 0.000000] node 0: [mem 0x000000087b8c0000-0x000000087b90ffff]
[ 0.000000] node 0: [mem 0x000000087b910000-0x000000087fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x000000087fffffff]
[ 0.000000] On node 0, zone DMA: 304 pages in unavailable ranges
[ 0.000000] On node 0, zone DMA: 80 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 31 pages/cpu s90008 r8192 d28776 u126976
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: kernel page table isolation disabled by kernel configuration
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 7983060
[ 0.000000] Kernel command line: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 mminit_loglevel=4 console=ttyTCU0,115200 console=tty0 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0
[ 0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000a9cd0000-0x00000000b9cd0000] (256MB)
[ 0.000000] Memory: 31083296K/32439104K available (18496K kernel code, 3214K rwdata, 7092K rodata, 3968K init, 1070K bss, 1093664K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=12, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=12.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=12
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] GICv2m: DT overriding V2M MSI_TYPER (base:608, num:70)
[ 0.000000] GICv2m: range[mem 0x0f410000-0x0f41ffff], SPI[608:677]
[ 0.000000] random: get_random_bytes called from start_kernel+0x378/0x4f4 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000002] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000590] Console: colour dummy device 80x25
[ 0.000790] printk: console [tty0] enabled
[ 0.000826] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000836] pid_max: default: 32768 minimum: 301
[ 0.000883] LSM: Security Framework initializing
[ 0.000945] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000990] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.002589] rcu: Hierarchical SRCU implementation.
[ 0.002681] dyndbg: Ignore empty _ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
[ 0.003098] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.003106] DTB Build time: May 16 2022 21:09:35
[ 0.004204] Tegra Revision: A01 SKU: 0xd0 CPU Process: 0 SoC Process: 0
[ 0.004325] Remapping and enabling EFI services.
[ 0.005483] smp: Bringing up secondary CPUs ...
[ 0.005877] Detected PIPT I-cache on CPU1
[ 0.005908] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005938] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.006298] Detected PIPT I-cache on CPU2
[ 0.006309] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.006324] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006635] Detected PIPT I-cache on CPU3
[ 0.006644] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006657] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.008987] Detected PIPT I-cache on CPU4
[ 0.009008] GICv3: CPU4: found redistributor 10000 region 0:0x000000000f4c0000
[ 0.009035] CPU4: Booted secondary processor 0x0000010000 [0x410fd421]
[ 0.009399] Detected PIPT I-cache on CPU5
[ 0.009410] GICv3: CPU5: found redistributor 10100 region 0:0x000000000f4e0000
[ 0.009423] CPU5: Booted secondary processor 0x0000010100 [0x410fd421]
[ 0.009756] Detected PIPT I-cache on CPU6
[ 0.009766] GICv3: CPU6: found redistributor 10200 region 0:0x000000000f500000
[ 0.009780] CPU6: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.010124] Detected PIPT I-cache on CPU7
[ 0.010134] GICv3: CPU7: found redistributor 10300 region 0:0x000000000f520000
[ 0.010147] CPU7: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.012477] Detected PIPT I-cache on CPU8
[ 0.012499] GICv3: CPU8: found redistributor 20000 region 0:0x000000000f540000
[ 0.012526] CPU8: Booted secondary processor 0x0000020000 [0x410fd421]
[ 0.012890] Detected PIPT I-cache on CPU9
[ 0.012900] GICv3: CPU9: found redistributor 20100 region 0:0x000000000f560000
[ 0.012915] CPU9: Booted secondary processor 0x0000020100 [0x410fd421]
[ 0.013256] Detected PIPT I-cache on CPU10
[ 0.013266] GICv3: CPU10: found redistributor 20200 region 0:0x000000000f580000
[ 0.013280] CPU10: Booted secondary processor 0x0000020200 [0x410fd421]
[ 0.013616] Detected PIPT I-cache on CPU11
[ 0.013626] GICv3: CPU11: found redistributor 20300 region 0:0x000000000f5a0000
[ 0.013641] CPU11: Booted secondary processor 0x0000020300 [0x410fd421]
[ 0.013695] smp: Brought up 1 node, 12 CPUs
[ 0.013758] SMP: Total of 12 processors activated.
[ 0.013763] CPU features: detected: Privileged Access Never
[ 0.013766] CPU features: detected: LSE atomic instructions
[ 0.013768] CPU features: detected: User Access Override
[ 0.013771] CPU features: detected: 32-bit EL0 Support
[ 0.013774] CPU features: detected: Common not Private translations
[ 0.013777] CPU features: detected: RAS Extension Support
[ 0.013779] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.013783] CPU features: detected: CRC32 instructions
[ 0.013785] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.047577] CPU: All CPU(s) started at EL2
[ 0.049803] devtmpfs: initialized
[ 0.059016] Registered cp15_barrier emulation handler
[ 0.059030] Registered setend emulation handler
[ 0.059035] KASLR enabled
[ 0.059114] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.059126] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[ 0.060666] pinctrl core: initialized pinctrl subsystem
[ 0.061111] SMBIOS 3.0.0 present.
[ 0.061120] DMI: /, BIOS r34.1-975eef6 05/16/2022
[ 0.061366] NET: Registered protocol family 16
[ 0.062275] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.062485] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.062682] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.062746] audit: initializing netlink subsys (disabled)
[ 0.062887] audit: type=2000 audit(0.060:1): state=initialized audit_enabled=0 res=1
[ 0.063496] printk: console [ramoops-1] enabled
[ 0.063503] pstore: Registered ramoops as persistent store backend
[ 0.063509] ramoops: using 0x200000@0xba9b0000, ecc: 0
[ 0.063663] thermal_sys: Registered thermal governor 'step_wise'
[ 0.063664] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.063670] thermal_sys: Registered thermal governor 'pid_thermal_gov'
[ 0.065076] cpuidle: using governor menu
[ 0.065189] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.065301] ASID allocator initialised with 65536 entries
[ 0.065366] Serial: AMBA PL011 UART driver
[ 0.066644] tegra234_mc_sid_probe(): tegra234 mc-sid probe successful
[ 0.066666] Tegra reboot handler registered.
[ 0.066725] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-5.10/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t23x/concord/kernel-dts/tegra234-p3701-0000-p3737-0000.dts
[ 0.066734] DTB Build time: May 16 2022 21:09:35
[ 0.080649] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c10000
[ 0.080665] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c20000
[ 0.080677] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c30000
[ 0.080687] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c40000
[ 0.080696] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2c50000
[ 0.080704] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2b80000
[ 0.080712] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2b90000
[ 0.080720] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2ba0000
[ 0.080728] mc: mapped MMIO address: 0x(____ptrval____) -> 0x2bb0000
[ 0.080736] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1700000
[ 0.080743] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1710000
[ 0.080752] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1720000
[ 0.080760] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1730000
[ 0.080768] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1740000
[ 0.080776] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1750000
[ 0.080783] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1760000
[ 0.080792] mc: mapped MMIO address: 0x(____ptrval____) -> 0x1770000
[ 0.080802] nv-tegra-mc 2c10000.mc: No mssnvlink node
[ 0.080820] mc-err: mcerr ops are set to t23x
[ 0.081142] tegra23x-cbb 13a00000.cbb-en: secure_irq = 21
[ 0.081200] tegra23x-cbb c600000.aon-en: secure_irq = 22
[ 0.081238] tegra23x-cbb de00000.dce-en: secure_irq = 23
[ 0.081271] tegra23x-cbb be00000.rce-en: secure_irq = 24
[ 0.081306] tegra23x-cbb b600000.sce-en: secure_irq = 25
[ 0.084968] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.084978] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.084984] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.084989] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.086333] ACPI: Interpreter disabled.
[ 0.087463] vdd-av1v1-hub: supplied by vdd-5v-sys
[ 0.087625] vbusA-cvb: supplied by vdd-5v-sys
[ 0.087718] vbusB-cvb: supplied by vdd-5v-sys
[ 0.087830] vdd-usbc1-vbus: supplied by vdd-5v-sys
[ 0.087916] vdd-usbc2-vbus: supplied by vdd-5v-sys
[ 0.088224] iommu: Default domain type: Translated
[ 0.088264] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.088413] SCSI subsystem initialized
[ 0.088475] usbcore: registered new interface driver usbfs
[ 0.088488] usbcore: registered new interface driver hub
[ 0.088503] usbcore: registered new device driver usb
[ 0.088680] mc: Linux media interface: v0.10
[ 0.088691] videodev: Linux video capture interface: v2.00
[ 0.088837] pps_core: LinuxPPS API ver. 1 registered
[ 0.088843] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.088851] PTP clock support registered
[ 0.089056] tegra_wdt_t18x 2190000.watchdog: Tegra WDT init timeout = 120 sec
[ 0.089087] tegra_wdt_t18x 2190000.watchdog: Registered successfully
[ 0.090367] Registered efivars operations
[ 0.090749] FPGA manager framework
[ 0.090851] Advanced Linux Sound Architecture Driver Initialized.
[ 0.091097] Bluetooth: Core ver 2.22
[ 0.091113] NET: Registered protocol family 31
[ 0.091119] Bluetooth: HCI device and connection manager initialized
[ 0.091129] Bluetooth: HCI socket layer initialized
[ 0.091136] Bluetooth: L2CAP socket layer initialized
[ 0.091146] Bluetooth: SCO socket layer initialized
[ 0.091801] camchar: rtcpu character device driver loaded
[ 0.092053] clocksource: Switched to clocksource arch_sys_counter
[ 0.241017] VFS: Disk quotas dquot_6.6.0
[ 0.241063] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.241181] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.241360] pnp: PnP ACPI: disabled
[ 0.241423] tegra-carveouts tegra-carveouts: fsi :dma coherent mem declare 0x00000000bf000000,16777216
[ 0.241437] tegra-carveouts tegra-carveouts: assigned reserved memory node fsi-carveout
[ 0.241453] tegra-carveouts tegra-carveouts: vpr :dma coherent mem declare 0x00000000d6000000,704643072
[ 0.241461] nvmap_page_pool_init: Total RAM pages: 7836360
[ 0.241466] nvmap_page_pool_init: nvmap page pool size: 979545 pages (3826 MB)
[ 0.241511] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.241615] misc nvmap: created heap vpr base 0x00000000d6000000 size (688128KiB)
[ 0.243076] la/ptsa driver initialized.
[ 0.243122] NET: Registered protocol family 2
[ 0.243348] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.245124] misc nvmap: created heap fsi base 0x00000000bf000000 size (16384KiB)
[ 0.245456] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.245499] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.245701] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.246131] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.246203] UDP hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.246259] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes, linear)
[ 0.246384] NET: Registered protocol family 1
[ 0.246620] RPC: Registered named UNIX socket transport module.
[ 0.246631] RPC: Registered udp transport module.
[ 0.246636] RPC: Registered tcp transport module.
[ 0.246641] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.246654] PCI: CLS 0 bytes, default 64
[ 0.246758] Trying to unpack rootfs image as initramfs...
[ 0.355868] Freeing initrd memory: 8196K
[ 0.357681] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.357849] kvm [1]: IPA Size Limit: 48 bits
[ 0.358014] kvm [1]: VHE mode initialized successfully
[ 0.358572] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[ 0.359950] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.360150] NFS: Registering the id_resolver key type
[ 0.360172] Key type id_resolver registered
[ 0.360177] Key type id_legacy registered
[ 0.360204] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.360216] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.360230] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.371808] NET: Registered protocol family 38
[ 0.371832] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 239)
[ 0.371889] io scheduler mq-deadline registered
[ 0.371895] io scheduler kyber registered
[ 0.375289] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 0.375317] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 0.375335] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 0.375350] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 0.377500] tegra_dc_assign_hw_data: no matching compatible node
[ 0.377507] tegradccommon module_init failed
[ 0.377513] tegradc module_init failed
[ 0.377731] EINJ: ACPI disabled.
[ 0.378954] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[ 0.378966] tegra-pmc: ### PMC reset source: SYS_RESET_N
[ 0.378973] tegra-pmc: ### PMC reset level: L0
[ 0.378978] tegra-pmc: ### PMC reset status reg: 0x0
[ 0.380008] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.384091] random: fast init done
[ 0.385138] printk: console [ttyTCU0] enabled
[ 2.199071] arm-smmu 12000000.iommu: probing hardware configuration...
[ 2.204783] arm-smmu 12000000.iommu: SMMUv2 with:
[ 2.209325] arm-smmu 12000000.iommu: stage 1 translation
[ 2.214673] arm-smmu 12000000.iommu: stage 2 translation
[ 2.220176] arm-smmu 12000000.iommu: nested translation
[ 2.225339] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 2.232513] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 2.240809] arm-smmu 12000000.iommu: Supported page sizes: 0x00001000
[ 2.245547] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.252111] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.259264] arm-smmu 10000000.iommu: probing hardware configuration...
[ 2.265149] arm-smmu 10000000.iommu: SMMUv2 with:
[ 2.269871] arm-smmu 10000000.iommu: stage 1 translation
[ 2.275386] arm-smmu 10000000.iommu: stage 2 translation
[ 2.280808] arm-smmu 10000000.iommu: nested translation
[ 2.286235] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 2.293412] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 2.301734] arm-smmu 10000000.iommu: Supported page sizes: 0x00001000
[ 2.306623] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.313183] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.320113] arm-smmu 8000000.iommu: probing hardware configuration...
[ 2.326309] arm-smmu 8000000.iommu: SMMUv2 with:
[ 2.331036] arm-smmu 8000000.iommu: stage 1 translation
[ 2.336546] arm-smmu 8000000.iommu: stage 2 translation
[ 2.341970] arm-smmu 8000000.iommu: nested translation
[ 2.347134] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 2.354309] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 2.362597] arm-smmu 8000000.iommu: Supported page sizes: 0x00001000
[ 2.367524] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 2.374083] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 2.381205] arm-smmu-suspend 12000000.smmu_suspend: arm_smmu_suspend probe successful
[ 2.390060] tegra_profiler: version: 1.146, samples/io: 49/28
[ 2.394281] tegra_profiler: auth: init
[ 2.399120] tegra23x-qspi 3270000.spi: Adding to iommu group 0
[ 2.404657] libphy: Fixed MDIO Bus: probed
[ 2.408033] tun: Universal TUN/TAP device driver, 1.6
[ 2.413625] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.420379] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.425911] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.430698] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.436661] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.442071] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.447918] PPP generic driver version 2.4.2
[ 2.452277] PPP BSD Compression module registered
[ 2.456952] PPP Deflate Compression module registered
[ 2.462213] PPP MPPE Compression module registered
[ 2.467026] usbcore: registered new interface driver r8152
[ 2.472355] usbcore: registered new interface driver asix
[ 2.477782] usbcore: registered new interface driver ax88179_178a
[ 2.483906] usbcore: registered new interface driver cdc_ether
[ 2.489854] usbcore: registered new interface driver net1080
[ 2.495453] usbcore: registered new interface driver cdc_subset
[ 2.501492] usbcore: registered new interface driver zaurus
[ 2.507182] usbcore: registered new interface driver cdc_ncm
[ 2.512867] usbcore: registered new interface driver aqc111
[ 2.518388] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 2.524597] ohci-pci: OHCI PCI platform driver
[ 2.528887] ohci-platform: OHCI generic platform driver
[ 2.534223] tegra-xusb 3610000.xhci: Adding to iommu group 1
[ 2.540078] usbcore: registered new interface driver uas
[ 2.545165] usbcore: registered new interface driver usb-storage
[ 2.551140] tegra-xudc 3550000.xudc: Adding to iommu group 2
[ 2.557022] mousedev: PS/2 mouse device common for all mice
[ 2.562316] usbcore: registered new interface driver xpad
[ 2.569580] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.573078] tegra_rtc c2a0000.rtc: setting system clock to 1970-01-01T00:00:19 UTC (19)
[ 2.580857] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.587085] i2c /dev entries driver
[ 2.590662] tegra-i2c 3160000.i2c: Adding to iommu group 3
[ 2.596231] tegra-i2c c240000.i2c: Adding to iommu group 3
[ 2.601677] tegra-i2c 3180000.i2c: Adding to iommu group 3
[ 2.607054] tegra-i2c 3190000.i2c: Adding to iommu group 3
[ 2.612385] tegra-i2c 31b0000.i2c: Adding to iommu group 3
[ 2.617894] tegra-i2c 31c0000.i2c: Adding to iommu group 3
[ 2.623319] tegra-i2c c250000.i2c: Adding to iommu group 3
[ 2.628658] tegra-i2c 31e0000.i2c: Adding to iommu group 3
[ 2.635784] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.642279] tegra-camrtc-capture-vi tegra-capture-vi: ep of_device is not enabled endpoint.
[ 2.651367] device-mapper: uevent: version 1.0.3
[ 2.655214] device-mapper: ioctl: 4.43.0-ioctl (2020-10-01) initialised: dm-devel@redhat.com
[ 2.664469] sdhci: Secure Digital Host Controller Interface driver
[ 2.669925] sdhci: Copyright(c) Pierre Ossman
[ 2.674387] Synopsys Designware Multimedia Card Interface Driver
[ 2.680496] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.686508] sdhci-tegra 3460000.sdhci: Adding to iommu group 4
[ 2.686580] sdhci-tegra 3400000.sdhci: Adding to iommu group 5
[ 2.686949] pstore: ignoring unexpected backend 'efi'
[ 2.687026] SMCCC: SOC_ID: ID = jep106:036b:0023 Revision = 0x00000401
[ 2.688160] tegra-bpmp bpmp: firmware: 43f75b5aad2b8e1992e4-f0425a554b3
��debugfs initialized
��[ 3.769245] hid: raw HID events driver (C) Jiri Kosina
[ 3.770265] usbcore: registered new interface driver usbhid
[ 3.770443] usbhid: USB HID core driver
[ 3.770839] tegra-dce d800000.dce: Adding to iommu group 6
[ 3.772209] dce: dce_ipc_channel_init:314 Invalid Channel State [0x0] for ch_type [2]
[ 3.773420] dce: dce_wait_boot_complete:100 dce is ready to receive bootstrap commands
[ 3.773556] tegra234-aon c000000.aon: Adding to iommu group 7
[ 3.774128] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x5]
[ 3.774196] random: crng init done
[ 3.774486] dce: dce_admin_send_cmd_ver:424 version : [0x2] err : [0x0]
[ 3.774491] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [0]. Ignored...
[ 3.774791] c000000.aon:hsp: probed
[ 3.774905] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x1]
[ 3.775149] tegra234-aon c000000.aon: init done
[ 3.775320] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [1] ...
[ 3.775322] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [1]. Ignored...
[ 3.775334] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [1]. Ignored...
[ 3.775697] tegra23x-psc e860000.psc: Adding to iommu group 8
[ 3.775726] dce: dce_admin_setup_clients_ipc:456 Get queue info failed for [2]
[ 3.781550] tegra23x-psc e860000.psc: ext_cfg base:000000006649fe1e
[ 3.790018] dce: dce_mailbox_set_full_interrupt:165 Intr bit set multiple times for MB : [0x2]
[ 3.795517] tegra23x-psc e860000.psc: init done
[ 3.802865] dce: dce_admin_setup_clients_ipc:480 Channel Reset Complete for Type [3] ...
[ 3.802873] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [3]. Ignored...
[ 3.802881] dce: dce_admin_ipc_handle_signal:119 Spurious signal on channel: [3]. Ignored...
[ 3.809204] tegra186-cam-rtcpu bc00000.rtcpu: Adding to iommu group 9
[ 3.818281] dce: dce_worker:209 DCE_BOOT_DONE
[ 3.823080] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 3.871402] tegra-ivc-bus bc00000.rtcpu:ivc-bus: region 0: iova=0xbfec0000-0xbfee01ff size=131584
[ 3.876229] tegra-ivc-bus bc00000.rtcpu:ivc-bus:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 3.887318] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@1: dbg: ver=0 grp=1 RX[1x448]=0x1900-0x1b40 TX[1x448]=0x1b40-0x1d80
[ 3.897965] tegra-ivc-bus bc00000.rtcpu:ivc-bus:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d80-0x3e00 TX[1x8192]=0x3e00-0x5e80
[ 3.909009] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e80-0xaf00 TX[64x320]=0xaf00-0xff80
[ 3.920848] tegra-ivc-bus bc00000.rtcpu:ivc-bus:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff80-0x18000 TX[512x64]=0x18000-0x20080
[ 3.933351] tegra-ivc-bus bc00000.rtcpu:ivc-bus:diag@5: diag: ver=0 grp=1 RX[1x64]=0x20080-0x20140 TX[1x64]=0x20140-0x20200
[ 3.945083] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (115)
[ 3.951447] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 3.959732] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=6 sha1=ab261c6cb44ef92b00c3f83a96d5951f9ccd0c06
[ 3.972242] t19x_cache tegra-cache: probed
[ 3.974797] scf-pmu-drv scf-pmu: Registered T23x SCF Uncore PMU
[ 3.992677] nvpmodel: initialized successfully
[ 3.993066] tegra_hv: get_hvd: not initialized yet
[ 3.993206] user_ivc_mempool: hypervisor not present
[ 3.995365] usbcore: registered new interface driver snd-usb-audio
[ 4.001813] u32 classifier
[ 4.004112] input device check on
[ 4.007783] Actions configured
[ 4.011266] Initializing XFRM netlink socket
[ 4.015867] NET: Registered protocol family 10
[ 4.021513] Segment Routing with IPv6
[ 4.023575] NET: Registered protocol family 17
[ 4.027844] NET: Registered protocol family 15
[ 4.032328] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 4.045954] Bluetooth: RFCOMM socket layer initialized
[ 4.050338] Bluetooth: RFCOMM ver 1.11
[ 4.054256] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 4.060118] Bluetooth: HIDP socket layer initialized
[ 4.065867] 9pnet: Installing 9P2000 support
[ 4.069528] Key type dns_resolver registered
[ 4.074591] registered taskstats version 1
[ 4.078307] pstore: Using crash dump compression: deflate
[ 4.083569] tegra194-pcie 14100000.pcie: Adding to iommu group 10
[ 4.094819] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 4.096366] tegra194-pcie 14160000.pcie: Adding to iommu group 11
[ 4.107259] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 4.108844] tegra194-pcie 141a0000.pcie: Adding to iommu group 12
[ 4.119315] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 4.141028] tegra-gpcdma 2600000.gpcdma: Adding to iommu group 3
[ 4.142232] tegra-gpcdma 2600000.gpcdma: GPC DMA driver register 31 channels
[ 4.142631] host1x 13e40000.host1x: Adding to iommu group 13
[ 5.150403] t23x_init_gating_regs: Timed out waiting for syncpt ram init!
[ 5.161000] host1x 13e40000.host1x: initialized
[ 5.161448] iommu_context_dev 13e40000.host1x:niso0_ctx0: Adding to iommu group 14
[ 5.161933] iommu_context_dev 13e40000.host1x:niso0_ctx0: initialized (streamid=53, iommu=smmu.0x0000000012000000)
[ 5.163490] iommu_context_dev 13e40000.host1x:niso0_ctx1: Adding to iommu group 15
[ 5.163897] iommu_context_dev 13e40000.host1x:niso0_ctx1: initialized (streamid=54, iommu=smmu.0x0000000012000000)
[ 5.165455] iommu_context_dev 13e40000.host1x:niso0_ctx2: Adding to iommu group 16
[ 5.165850] iommu_context_dev 13e40000.host1x:niso0_ctx2: initialized (streamid=55, iommu=smmu.0x0000000012000000)
[ 5.167398] iommu_context_dev 13e40000.host1x:niso0_ctx3: Adding to iommu group 17
[ 5.167813] iommu_context_dev 13e40000.host1x:niso0_ctx3: initialized (streamid=56, iommu=smmu.0x0000000012000000)
[ 5.169353] iommu_context_dev 13e40000.host1x:niso0_ctx4: Adding to iommu group 18
[ 5.169790] iommu_context_dev 13e40000.host1x:niso0_ctx4: initialized (streamid=57, iommu=smmu.0x0000000012000000)
[ 5.171336] iommu_context_dev 13e40000.host1x:niso0_ctx5: Adding to iommu group 19
[ 5.171760] iommu_context_dev 13e40000.host1x:niso0_ctx5: initialized (streamid=58, iommu=smmu.0x0000000012000000)
[ 5.183044] iommu_context_dev 13e40000.host1x:niso0_ctx6: Adding to iommu group 20
[ 5.189620] iommu_context_dev 13e40000.host1x:niso0_ctx6: initialized (streamid=59, iommu=smmu.0x0000000012000000)
[ 5.201080] iommu_context_dev 13e40000.host1x:niso0_ctx7: Adding to iommu group 21
[ 5.207629] iommu_context_dev 13e40000.host1x:niso0_ctx7: initialized (streamid=60, iommu=smmu.0x0000000012000000)
[ 5.219109] iommu_context_dev 13e40000.host1x:niso1_ctx0: Adding to iommu group 22
[ 5.225669] iommu_context_dev 13e40000.host1x:niso1_ctx0: initialized (streamid=53, iommu=smmu.0x0000000008000000)
[ 5.237127] iommu_context_dev 13e40000.host1x:niso1_ctx1: Adding to iommu group 23
[ 5.243702] iommu_context_dev 13e40000.host1x:niso1_ctx1: initialized (streamid=54, iommu=smmu.0x0000000008000000)
[ 5.255146] iommu_context_dev 13e40000.host1x:niso1_ctx2: Adding to iommu group 24
[ 5.261693] iommu_context_dev 13e40000.host1x:niso1_ctx2: initialized (streamid=55, iommu=smmu.0x0000000008000000)
[ 5.273179] iommu_context_dev 13e40000.host1x:niso1_ctx3: Adding to iommu group 25
[ 5.279781] iommu_context_dev 13e40000.host1x:niso1_ctx3: initialized (streamid=56, iommu=smmu.0x0000000008000000)
[ 5.291199] iommu_context_dev 13e40000.host1x:niso1_ctx4: Adding to iommu group 26
[ 5.297754] iommu_context_dev 13e40000.host1x:niso1_ctx4: initialized (streamid=57, iommu=smmu.0x0000000008000000)
[ 5.309228] iommu_context_dev 13e40000.host1x:niso1_ctx5: Adding to iommu group 27
[ 5.315785] iommu_context_dev 13e40000.host1x:niso1_ctx5: initialized (streamid=58, iommu=smmu.0x0000000008000000)
[ 5.327270] iommu_context_dev 13e40000.host1x:niso1_ctx6: Adding to iommu group 28
[ 5.333820] iommu_context_dev 13e40000.host1x:niso1_ctx6: initialized (streamid=59, iommu=smmu.0x0000000008000000)
[ 5.345276] iommu_context_dev 13e40000.host1x:niso1_ctx7: Adding to iommu group 29
[ 5.351845] iommu_context_dev 13e40000.host1x:niso1_ctx7: initialized (streamid=60, iommu=smmu.0x0000000008000000)
[ 5.363323] falcon 15340000.vic: Adding to iommu group 30
[ 5.374658] falcon 15340000.vic: initialized
[ 5.375019] falcon 15380000.nvjpg: Adding to iommu group 31
[ 5.382348] falcon 15380000.nvjpg: initialized
[ 5.382569] falcon 15540000.nvjpg1: Adding to iommu group 32
[ 5.392461] falcon 15540000.nvjpg1: initialized
[ 5.392690] falcon 154c0000.nvenc: Adding to iommu group 33
[ 5.405318] falcon 154c0000.nvenc: initialized
[ 5.405539] falcon 15a50000.ofa: Adding to iommu group 34
[ 5.412611] falcon 15a50000.ofa: initialized
[ 5.412836] nvdec 15480000.nvdec: Adding to iommu group 35
[ 5.429095] nvdec 15480000.nvdec: initialized
[ 5.429303] tsec 15500000.tsec: Adding to iommu group 36
[ 5.436589] tsec 15500000.tsec: initialized
[ 5.438870] gic 2a41000.agic-controller: GIC IRQ controller registered
[ 5.445099] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[ 5.451299] gpio-394 (camera-control-output-low): hogged as output/low
[ 5.452083] gpio-397 (camera-control-output-low): hogged as output/low
[ 5.458556] gpio-487 (camera-control-output-low): hogged as output/low
[ 5.464768] gpio-486 (camera-control-output-low): hogged as output/low
[ 5.471903] gpiochip0: registered GPIOs 348 to 511 on tegra234-gpio
[ 5.477932] gpiochip1: registered GPIOs 316 to 347 on tegra234-gpio-aon
[ 5.484316] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[ 5.490465] tegra-pwm 32a0000.pwm: PWM clk can sleep in ops
[ 5.497006] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[ 5.502396] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[ 5.511406] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[ 5.515444] tegra194-isp5 14800000.isp: Adding to iommu group 37
[ 5.524186] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: context isolation disabled due to no IOMMU
[ 5.530384] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: initialized
[ 5.536684] tegra194-vi5 13e40000.host1x:vi0@15c00000: Adding to iommu group 38
[ 5.544388] tegra194-vi5 13e40000.host1x:vi1@14c00000: Adding to iommu group 39
[ 5.551432] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: context isolation disabled due to no IOMMU
[ 5.560463] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: initialized
[ 5.566707] scare-pigeon 13e40000.host1x:vi0-thi@15f00000: grid-of-semaphores not supported
[ 5.574812] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: context isolation disabled due to no IOMMU
[ 5.584519] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: initialized
[ 5.590588] scare-pigeon 13e40000.host1x:vi1-thi@14f00000: grid-of-semaphores not supported
[ 5.599048] scare-pigeon 13e40000.host1x:isp-thi@14b00000: context isolation disabled due to no IOMMU
[ 5.609157] scare-pigeon 13e40000.host1x:isp-thi@14b00000: initialized
[ 5.614920] scare-pigeon 13e40000.host1x:isp-thi@14b00000: grid-of-semaphores not supported
[ 5.623491] pva 16000000.pva0: Adding to iommu group 40
[ 5.648367] pva 16000000.pva0: initialized
[ 5.655218] nvdla 15880000.nvdla0: Adding to iommu group 41
[ 5.663763] nvdla 15880000.nvdla0: initialized
[ 5.665524] nvdla 158c0000.nvdla1: Adding to iommu group 42
[ 5.674175] nvdla 158c0000.nvdla1: initialized
[ 5.675894] tegra-fuse-burn efuse-burn: shutdown limit check disabled
[ 5.676115] tegra-fuse-burn efuse-burn: Fuse burn driver initialized
[ 5.676517] serial-tegra 3100000.serial: Adding to iommu group 3
[ 5.677052] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 13, base_baud = 0) is a TEGRA_UART
[ 5.681147] serial-tegra 3130000.serial: Adding to iommu group 3
[ 5.687165] 3130000.serial: ttyTHS3 at MMIO 0x3130000 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 5.719603] tegra-xusb 3610000.xhci: Firmware timestamp: 2021-12-01 05:27:10 UTC, Version: 80.03 release
[ 5.719916] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.720116] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 5.721174] tegra-xusb 3610000.xhci: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000050810
[ 5.727550] tegra-xusb 3610000.xhci: irq 232, io mem 0x03610000
[ 5.733680] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 5.741785] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.748961] usb usb1: Product: xHCI Host Controller
[ 5.753946] usb usb1: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 5.759984] usb usb1: SerialNumber: 3610000.xhci
[ 5.765074] hub 1-0:1.0: USB hub found
[ 5.768496] hub 1-0:1.0: 4 ports detected
[ 5.772665] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 5.777929] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 5.785542] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 5.792954] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 5.801117] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 5.808375] usb usb2: Product: xHCI Host Controller
[ 5.813359] usb usb2: Manufacturer: Linux 5.10.65-tegra xhci-hcd
[ 5.819307] usb usb2: SerialNumber: 3610000.xhci
[ 5.824715] hub 2-0:1.0: USB hub found
[ 5.827895] hub 2-0:1.0: 4 ports detected
[ 5.833308] bwmgr API not supported
[ 5.833313] tegra-xusb 3610000.xhci: can't register EMC bwmgr (-22)
[ 5.867317] cpufreq: cpufreq_online: CPU0: Running at unlisted initial frequency: 2008000 KHz, changing to: 2035200 KHz
[ 5.870954] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1880000 KHz, changing to: 1881600 KHz
[ 5.874340] cpufreq: cpufreq_online: CPU8: Running at unlisted initial frequency: 2009000 KHz, changing to: 2035200 KHz
[ 5.877145] tegra194-pcie 14100000.pcie: Using GICv2m MSI allocator
[ 5.880164] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 5.881384] tegra194-pcie 14100000.pcie: host bridge /pcie@14100000 ranges:
[ 5.887144] mmc0: CQHCI version 5.10
[ 5.892551] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 5.894318] irq: IRQ290: trimming hierarchy from :pmc@c360000
[ 5.894346] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 290
[ 5.916433] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 5.923574] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit
[ 5.924918] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 6.030456] mmc0: Command Queue Engine enabled
[ 6.030582] mmc0: periodic cache flush enabled
[ 6.030709] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 6.031214] mmcblk0: mmc0:0001 G1M15M 59.3 GiB
[ 6.031513] mmcblk0rpmb: mmc0:0001 G1M15M partition 3 4.00 MiB, chardev (510:0)
[ 6.032049] tegra194-pcie 14100000.pcie: Link up
[ 6.032072] usb 1-3: new full-speed USB device number 2 using tegra-xusb
[ 6.033974] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 6.034176] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 6.034333] pci_bus 0001:00: root bus resource [io 0x0000-0xfffff] (bus address [0x30100000-0x301fffff])
[ 6.034612] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 6.034883] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 6.034916] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 6.035329] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 6.035618] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 6.039878] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 6.042716] pci 0001:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 6.048426] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.056202] pci 0001:01:00.0: supports D1 D2
[ 6.059929] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 6.069913] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 6.074020] pci 0001:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 6.080145] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 6.087909] pci 0001:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 6.093989] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 6.099219] pci 0001:00:00.0: bridge window [io 0x1000-0x1fff]
[ 6.105518] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 6.112876] pci 0001:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 6.121402] pci 0001:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 6.129875] pcieport 0001:00:00.0: Adding to iommu group 10
[ 6.135423] pcieport 0001:00:00.0: PME: Signaling with IRQ 50
[ 6.141308] pcieport 0001:00:00.0: AER: enabled with IRQ 50
[ 6.147413] tegra194-pcie 14160000.pcie: Using GICv2m MSI allocator
[ 6.153717] tegra194-pcie 14160000.pcie: host bridge /pcie@14160000 ranges:
[ 6.159690] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 6.168348] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 6.176830] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 6.184196] usb 1-3: New USB device found, idVendor=13d3, idProduct=3549, bcdDevice= 0.00
[ 6.193547] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 6.200717] usb 1-3: Product: Bluetooth Radio
[ 6.205003] usb 1-3: Manufacturer: Realtek
[ 6.209204] usb 1-3: SerialNumber: 00e04c000001
[ 6.292182] tegra194-pcie 14160000.pcie: Link up
[ 6.292909] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.293098] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.293240] pci_bus 0004:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x36100000-0x361fffff])
[ 6.293493] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 6.293768] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 6.293996] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 6.294234] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 6.297355] pci 0004:01:00.0: [144d:a80a] type 00 class 0x010802
[ 6.297613] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 6.301537] pci 0004:00:00.0: BAR 14: assigned [mem 0x2428000000-0x24280fffff]
[ 6.301722] pci 0004:01:00.0: BAR 0: assigned [mem 0x2428000000-0x2428003fff 64bit]
[ 6.301959] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 6.302743] pci 0004:00:00.0: bridge window [mem 0x2428000000-0x24280fffff]
[ 6.308829] usb 2-3: new SuperSpeedPlus Gen 2 USB device number 2 using tegra-xusb
[ 6.310014] pci 0004:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 6.325963] pci 0004:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 6.334789] pcieport 0004:00:00.0: Adding to iommu group 11
[ 6.340519] pcieport 0004:00:00.0: PME: Signaling with IRQ 52
[ 6.346356] pcieport 0004:00:00.0: AER: enabled with IRQ 52
[ 6.352138] nvme 0004:01:00.0: Adding to iommu group 11
[ 6.354749] usb 2-3: New USB device found, idVendor=0bda, idProduct=0420, bcdDevice= 1.40
[ 6.357421] nvme nvme0: pci function 0004:01:00.0
[ 6.365308] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.365309] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 6.365311] usb 2-3: Manufacturer: Generic
[ 6.376425] hub 2-3:1.0: USB hub found
[ 6.377376] nvme 0004:01:00.0: enabling device (0000 -> 0002)
[ 6.377787] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.377877] vdd-3v3-pcie: supplied by vdd-3v3-sys
[ 6.378031] avdd-cam-2v8: supplied by vdd-3v3-sys
[ 6.378095] vdd-dp: supplied by vdd-3v3-sys
[ 6.378178] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 6.378411] dsi-vdd-1v8-bl-en: supplied by vdd-1v8-sys
[ 6.380018] tegra194-isp5 14800000.isp: initialized
[ 6.384115] hub 2-3:1.0: 4 ports detected
[ 6.386123] tegra194-vi5 13e40000.host1x:vi0@15c00000: initialized
[ 6.386188] (NULL device *): fops function table already registered
[ 6.389945] nvme nvme0: Shutdown timeout set to 10 seconds
[ 6.394970] nvme nvme0: 12/0/0 default/read/poll queues
[ 6.396411] tegra194-vi5 13e40000.host1x:vi1@14c00000: initialized
[ 6.463777] sdhci-tegra 3400000.sdhci: Got CD GPIO
[ 6.463833] tegra194-pcie 141a0000.pcie: Using GICv2m MSI allocator
[ 6.472053] usb 1-4: new high-speed USB device number 3 using tegra-xusb
[ 6.481380] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 290
[ 6.581375] tegra194-pcie 141a0000.pcie: host bridge /pcie@141a0000 ranges:
[ 6.581583] tegra194-pcie 141a0000.pcie: IO 0x003a100000..0x003a1fffff -> 0x003a100000
[ 6.581823] tegra194-pcie 141a0000.pcie: MEM 0x2b28000000..0x2b2fffffff -> 0x0040000000
[ 6.582065] tegra194-pcie 141a0000.pcie: MEM 0x2740000000..0x2b27ffffff -> 0x2740000000
[ 6.656059] usb 1-4: New USB device found, idVendor=0bda, idProduct=5420, bcdDevice= 1.40
[ 6.656299] usb 1-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 6.656500] usb 1-4: Product: 4-Port USB 2.0 Hub
[ 6.656631] usb 1-4: Manufacturer: Generic
[ 6.658568] hub 1-4:1.0: USB hub found
[ 6.659929] hub 1-4:1.0: 4 ports detected
[ 7.528506] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit
[ 7.689386] tegra194-pcie 141a0000.pcie: Phy link never came up
[ 7.689607] tegra194-pcie 141a0000.pcie: PCI host bridge to bus 0005:00
[ 7.689791] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 7.689947] pci_bus 0005:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x3a100000-0x3a1fffff])
[ 7.690221] pci_bus 0005:00: root bus resource [mem 0x2b28000000-0x2b2fffffff] (bus address [0x40000000-0x47ffffff])
[ 7.690514] pci_bus 0005:00: root bus resource [mem 0x2740000000-0x2b27ffffff pref]
[ 7.690760] pci 0005:00:00.0: [10de:229a] type 01 class 0x060400
[ 7.691029] pci 0005:00:00.0: PME# supported from D0 D3hot
[ 7.696878] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 7.697025] pci 0005:00:00.0: Max Payload Size set to 256/ 256 (was 256), Max Read Rq 512
[ 7.697446] pcieport 0005:00:00.0: Adding to iommu group 12
[ 7.697751] pcieport 0005:00:00.0: PME: Signaling with IRQ 54
[ 7.698255] pcieport 0005:00:00.0: AER: enabled with IRQ 54
[ 7.698585] pci_bus 0005:01: busn_res: [bus 01-ff] is released
[ 7.698826] pci 0005:00:00.0: Removing from iommu group 12
[ 7.698996] pci_bus 0005:00: busn_res: [bus 00-ff] is released
[ 7.705488] nvethernet 6810000.ethernet: Adding to iommu group 43
[ 7.710536] nvethernet 6810000.ethernet: failed to read skip mac reset flag, default 0
[ 7.718214] nvethernet 6810000.ethernet: failed to read MDIO address
[ 7.724772] nvethernet 6810000.ethernet: setting to default DMA bit mask
[ 7.731606] nvethernet 6810000.ethernet: failed to read UPHY GBE mode- default to 10G
[ 7.739353] nvethernet 6810000.ethernet: failed to get phy reset gpio error: -2
[ 7.750791] nvethernet 6810000.ethernet: Ethernet MAC address: 48:b0:2d:78:99:9e
[ 7.754192] nvethernet 6810000.ethernet: Macsec not enabled
[ 7.759513] nvethernet 6810000.ethernet: Macsec: Reduced MTU: 1466 Max: 16383
[ 7.769250] nvethernet 6810000.ethernet: eth0 (HW ver: 31) created with 10 DMA channels
[ 7.775178] irq: IRQ305: trimming hierarchy from :pmc@c360000
[ 7.780456] irq: IRQ306: trimming hierarchy from :interrupt-controller@f400000-1
[ 7.787893] irq: IRQ307: trimming hierarchy from :pmc@c360000
[ 7.793503] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 7.801191] tegra-se-nvhost 15810000.se: Adding to iommu group 44
[ 7.806899] tegra-se-nvhost 15810000.se: initialized
[ 7.817856] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 7.818124] tegra-se-nvhost 15820000.se: Adding to iommu group 45
[ 7.824240] tegra-se-nvhost 15820000.se: initialized
[ 7.830420] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 7.834932] tegra-se-nvhost 15840000.se: Adding to iommu group 46
[ 7.841350] tegra-se-nvhost 15840000.se: initialized
[ 7.847044] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 7.852806] tegra_actmon d230000.actmon: in actmon_register()...
[ 7.858341] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 7.864241] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 7.871915] hvc_sysfs: hypervisor is not present
[ 7.908360] ALSA device list:
[ 7.908456] No soundcards found.
[ 7.909147] Freeing unused kernel memory: 3968K
[ 7.909316] Run /init as init process
[ 7.919805] Root device found: mmcblk0p1
[ 7.920400] Found dev node: /dev/mmcblk0p1
[ 8.208741] EXT4-fs (mmcblk0p1): recovery complete
[ 8.209774] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 8.210962] Rootfs mounted over mmcblk0p1
[ 8.220217] Switching from initrd to actual rootfs
[ 8.321104] systemd[1]: System time before build time, advancing clock.
[ 8.350747] systemd[1]: systemd 245.4-4ubuntu3.17 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 8.351797] systemd[1]: Detected architecture arm64.
[ 8.383300] systemd[1]: Set hostname to <devkit-orin01>.
[ 8.558272] systemd[1]: system-modprobe.slice: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 8.558637] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 8.559665] systemd[1]: Created slice system-modprobe.slice.
[ 8.560262] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 8.560744] systemd[1]: Created slice User and Session Slice.
[ 8.560997] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 8.561434] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 8.561765] systemd[1]: Reached target User and Group Name Lookups.
[ 8.561981] systemd[1]: Reached target Slices.
[ 8.562144] systemd[1]: Reached target Swap.
[ 8.562478] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 8.562775] systemd[1]: Listening on Syslog Socket.
[ 8.563022] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 8.563278] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 8.563801] systemd[1]: Listening on Journal Audit Socket.
[ 8.567893] systemd[1]: Listening on Journal Socket (/dev/log).
[ 8.573964] systemd[1]: Listening on Journal Socket.
[ 8.578980] systemd[1]: Listening on udev Control Socket.
[ 8.584396] systemd[1]: Listening on udev Kernel Socket.
[ 8.590781] systemd[1]: Mounting Huge Pages File System...
[ 8.596280] systemd[1]: Mounting POSIX Message Queue File System...
[ 8.602474] systemd[1]: Mounting RPC Pipe File System...
[ 8.607873] systemd[1]: Mounting Kernel Debug File System...
[ 8.613621] systemd[1]: Mounting Kernel Trace File System...
[ 8.619574] systemd[1]: Starting Journal Service...
[ 8.631137] systemd[1]: Starting Set the console keyboard layout...
[ 8.632445] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 8.638368] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
[ 8.647539] systemd[1]: Started Nameserver information manager.
[ 8.652872] systemd[1]: Reached target Network (Pre).
[ 8.659555] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 8.666871] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
[ 8.679166] systemd[1]: Starting Load Kernel Modules...
[ 8.682044] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 8.688036] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 8.688719] systemd[1]: Starting udev Coldplug all Devices...
[ 8.700215] systemd[1]: Started Journal Service.
[ 8.727355] systemd-journald[305]: Received client request to flush runtime journal.
[ 8.739736] nvgpu: 17000000.ga10b nvgpu_nvhost_syncpt_init:135 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 4000000 size 10000
[ 8.739736]
[ 9.043573] using random self ethernet address
[ 9.043714] using random host ethernet address
[ 9.104617] nvidia: loading out-of-tree module taints kernel.
[ 9.319848] 1 fixed-partitions partitions found on MTD device spi6.0
[ 9.320140] Creating 1 MTD partitions on "spi6.0":
[ 9.320284] 0x000000000000-0x000004000000 : "Whole_flash0"
[ 9.439088] OF: graph: no port node found in /i2c@c240000/ucsi_ccg@8/connector@0
[ 9.796875] using random self ethernet address
[ 9.797024] using random host ethernet address
[ 13.250122] Bridge firewalling registered
[ 14.464094] ucsi_ccg 1-0008: failed to reset PPM!
[ 14.464341] ucsi_ccg 1-0008: PPM init failed (-110)
Ubuntu 20.04.4 LTS devkit-orin01 ttyTCU0
devkit-orin01 login:
If this is 32GB module, then you need to wait until next release to flash.
Okay I have the next release now, but it thinks that the board is not in recovery mode, but it definitely is:
sudo ./flash.sh jetson-agx-orin-devkit-maxn mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 0.0
Error: probing the target board failed.
Make sure the target board is connected through
USB port and is in recovery mode.
Was there any log coming from UART when this “board was not in recovery mode” error shows on your host?
And I want to know did you ever see any flash cases that were not showing you “board was not in recovery mode”?
I mean previous log from your uart said “ E> instance 0 not supported for module 8”. Did you ever check what does the host tell when this log is printed from UART? I don’t feel the host would still say the board is not in recovery mode when this log is printed from serial console.
Please be aware that recovery mode only takes effect once. If you put the board into rcm, start flash and it fails, then you need to press the buttons again.
I got the below output the first time I tried to flash with the new installer. Every subsequent time just showed the “board not in recovery mode” output.
# Target Board Information:
# Name: jetson-agx-orin-devkit-maxn, Board Family: t186ref, SoC: Tegra 234,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying emc_fuse_dev_params(/home/BOSDYN/jcharest/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/BOSDYN/jcharest/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/BOSDYN/jcharest/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/BOSDYN/jcharest/Downloads/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3701-0000.dts --misc_config tegra234-mb1-bct-misc-p3701-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0202 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0215 ] File rcm_state open failed
[ 0.0215 ] ERROR: failed to read rcm_state
[ 0.0215 ]
[ 0.0269 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0270 ] Assuming zero filled SBK key
[ 0.0219 ] Pre-processing config: tegra234-mb1-bct-device-p3701-0000.dts
[ 0.0281 ] Pre-processing config: tegra234-mb1-bct-misc-p3701-0000.dts
[ 0.0363 ] Parsing partition layout
[ 0.0376 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0390 ]
[ 0.0396 ] Parsing partition layout
[ 0.0408 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0421 ]
[ 0.0422 ] Creating list of images to be signed
[ 0.0434 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.0447 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0458 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0462 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.0502 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.0508 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0546 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0551 ] adding BCH for mb2_t234_aligned.bin
[ 0.0579 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.0688 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.0693 ] adding BCH for mb2_t234_aligned.bin
[ 0.0824 ]
[ 0.0824 ] Generating signatures
[ 0.0878 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.0880 ] Assuming zero filled SBK key
[ 0.1040 ] Warning: pub_key.key is not found
[ 0.0987 ] Parsing dev params for multi chains
[ 0.1048 ] Generating br-bct
[ 0.1060 ] Updating dev and MSS params in BR BCT
[ 0.1061 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1076 ]
[ 0.1076 ] Updating bl info
[ 0.1088 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1100 ] WARNING: boot chain is not completed. set to 0
[ 0.1115 ]
[ 0.1115 ] Get Signed section of bct
[ 0.1128 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1149 ]
[ 0.1149 ] Signing BCT
[ 0.1203 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1204 ] Assuming zero filled SBK key
[ 0.1241 ] Sha saved in br_bct_BR.sha
[ 0.1245 ] Warning: pub_key.key is not found
[ 0.1192 ] Updating BCT with signature
[ 0.1203 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.1219 ]
[ 0.1220 ] Generating SHA2 Hash
[ 0.1273 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.1275 ] Assuming zero filled SBK key
[ 0.1311 ] Sha saved in br_bct_BR.sha
[ 0.1262 ] Updating BCT with SHA2 Hash
[ 0.1277 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.1290 ] Offset :68 Len :8124
[ 0.1295 ]
[ 0.1296 ] Generating coldboot mb1-bct
[ 0.1308 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1320 ] MB1-BCT version: 0.9
[ 0.1330 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1333 ] Added Platform Config 9 data with size :- 80
[ 0.1333 ]
[ 0.1333 ] Updating mb1-bct with firmware information
[ 0.1344 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1361 ]
[ 0.1375 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1389 ]
[ 0.1401 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.1413 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.1419 ]
[ 0.1479 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[ 0.1480 ] Assuming zero filled SBK key
[ 0.1461 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1477 ]
[ 0.1481 ] Generating recovery mb1-bct
[ 0.1492 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3701-0000_cpp.dtb --device tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1504 ] MB1-BCT version: 0.9
[ 0.1514 ] Parsing config file :tegra234-mb1-bct-device-p3701-0000_cpp.dtb
[ 0.1516 ] Added Platform Config 9 data with size :- 80
[ 0.1516 ]
[ 0.1517 ] Updating mb1-bct with firmware information
[ 0.1528 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.1543 ]
[ 0.1557 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.1569 ]
[ 0.1581 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.1593 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.1600 ]
[ 0.1657 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --sha sha512
[ 0.1658 ] Assuming zero filled SBK key
[ 0.1641 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.1658 ]
[ 0.1662 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.1662 ] Copying signatures
[ 0.1674 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1736 ]
[ 0.1740 ] Boot Rom communication
[ 0.1753 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.1766 ] BR_CID: 0x80012344705DD1438400000016FE0200
[ 0.2041 ] Sending bct_br
[ 5.2596 ]
Error: Return value -9
Command tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
Reading board information failed.
Could you share the file names under your Linux_for_Tegra?
Also, your log indicates your board can enter recovery mode. If subsequent try failed, it means you need to put into rcm again.
Files:
-rwxrwxrwx 1 jcharest domain^users 11475 Jun 28 05:58 apply_binaries.sh
drwxrwxrwx 6 jcharest domain^users 12288 Jul 8 07:54 bootloader
-rwxrwxrwx 1 jcharest domain^users 3326 Jun 28 05:58 build_l4t_bup.sh
lrwxrwxrwx 1 jcharest domain^users 30 Jul 7 10:10 clara-agx-xavier-devkit.conf -> e3900-0000+p2888-0004-b00.conf
-rw-rw-rw- 1 jcharest domain^users 2175 Jun 28 05:58 e3900-0000+p2888-0004-b00.conf
-rwxrwxrwx 1 jcharest domain^users 118908 Jun 28 05:58 flash.sh
lrwxrwxrwx 1 jcharest domain^users 26 Jul 7 10:10 holoscan-devkit.conf -> p3711-0000+p3701-0002.conf
lrwxrwxrwx 1 jcharest domain^users 40 Jul 7 10:10 jetson-agx-orin-devkit-as-jao-40w.conf -> p3737-0000+p3701-0000-as-p3701-0004.conf
lrwxrwxrwx 1 jcharest domain^users 40 Jul 7 10:10 jetson-agx-orin-devkit-as-nx-16gb.conf -> p3737-0000+p3701-0000-as-p3767-0000.conf
lrwxrwxrwx 1 jcharest domain^users 40 Jul 7 10:10 jetson-agx-orin-devkit-as-nx-8gb.conf -> p3737-0000+p3701-0000-as-p3767-0010.conf
lrwxrwxrwx 1 jcharest domain^users 26 Jul 7 10:10 jetson-agx-orin-devkit.conf -> p3737-0000+p3701-0000.conf
lrwxrwxrwx 1 jcharest domain^users 31 Jul 7 10:10 jetson-agx-orin-devkit-maxn.conf -> p3737-0000+p3701-0000-maxn.conf
lrwxrwxrwx 1 jcharest domain^users 26 Jul 7 10:10 jetson-agx-xavier-devkit.conf -> p2822-0000+p2888-0004.conf
lrwxrwxrwx 1 jcharest domain^users 32 Jul 7 10:10 jetson-agx-xavier-ind-noecc.conf -> p2822-0000+p2888-0008-noecc.conf
lrwxrwxrwx 1 jcharest domain^users 26 Jul 7 10:10 jetson-agx-xavier-industrial.conf -> p2822-0000+p2888-0008.conf
lrwxrwxrwx 1 jcharest domain^users 31 Jul 7 10:10 jetson-agx-xavier-industrial-mxn.conf -> p2822-0000+p2888-0008-maxn.conf
lrwxrwxrwx 1 jcharest domain^users 26 Jul 7 10:10 jetson-xavier.conf -> p2822-0000+p2888-0004.conf
lrwxrwxrwx 1 jcharest domain^users 27 Jul 7 10:10 jetson-xavier-maxn.conf -> p2972-0000-devkit-maxn.conf
lrwxrwxrwx 1 jcharest domain^users 34 Jul 7 10:10 jetson-xavier-nx-devkit.conf -> p3509-0000+p3668-0000-qspi-sd.conf
lrwxrwxrwx 1 jcharest domain^users 36 Jul 7 10:10 jetson-xavier-nx-devkit-emmc.conf -> p3509-0000+p3668-0001-qspi-emmc.conf
lrwxrwxrwx 1 jcharest domain^users 31 Jul 7 10:10 jetson-xavier-nx-devkit-qspi.conf -> p3509-0000+p3668-0000-qspi.conf
lrwxrwxrwx 1 jcharest domain^users 30 Jul 7 10:10 jetson-xavier-slvs-ec.conf -> p2972-0000-devkit-slvs-ec.conf
drwxrwxrwx 4 jcharest domain^users 4096 Jun 28 06:10 kernel
-rwxrwxrwx 1 jcharest domain^users 12111 Jun 28 05:58 l4t_generate_soc_bup.sh
-rwxrwxrwx 1 jcharest domain^users 8458 Jun 28 05:58 l4t_sign_image.sh
-rwxrwxrwx 1 jcharest domain^users 14825 Jun 28 05:58 nvautoflash.sh
-rwxrwxrwx 1 jcharest domain^users 30181 Jun 28 05:58 nvmassflashgen.sh
-rwxrwxrwx 1 jcharest domain^users 6046 Jun 28 05:58 nvsdkmanager_flash.sh
drwxrwxrwx 5 jcharest domain^users 4096 Jun 28 05:58 nv_tegra
drwxrwxrwx 3 jcharest domain^users 4096 Jun 28 05:58 nv_tools
lrwxrwxrwx 1 jcharest domain^users 26 Jul 7 10:10 p2822-0000+p2888-0001.conf -> p2822-0000+p2888-0004.conf
-rw-rw-rw- 1 jcharest domain^users 2177 Jun 28 05:58 p2822-0000+p2888-0004.conf
-rw-rw-rw- 1 jcharest domain^users 3443 Jun 28 05:58 p2822-0000+p2888-0008.conf
-rw-rw-rw- 1 jcharest domain^users 3413 Jun 28 05:58 p2822-0000+p2888-0008-maxn.conf
-rw-rw-rw- 1 jcharest domain^users 3124 Jun 28 05:58 p2822-0000+p2888-0008-noecc.conf
-rw-rw-rw- 1 jcharest domain^users 9625 Jun 28 05:58 p2972-0000.conf.common
-rw-rw-rw- 1 jcharest domain^users 2192 Jun 28 05:58 p2972-0000-devkit-maxn.conf
-rw-rw-rw- 1 jcharest domain^users 2013 Jun 28 05:58 p2972-0000-devkit-slvs-ec.conf
lrwxrwxrwx 1 jcharest domain^users 26 Jul 7 10:10 p2972.conf -> p2822-0000+p2888-0004.conf
lrwxrwxrwx 1 jcharest domain^users 34 Jul 7 10:10 p3449-0000+p3668-0000-qspi-sd.conf -> p3509-0000+p3668-0000-qspi-sd.conf
lrwxrwxrwx 1 jcharest domain^users 36 Jul 7 10:10 p3449-0000+p3668-0001-qspi-emmc.conf -> p3509-0000+p3668-0001-qspi-emmc.conf
-rw-rw-rw- 1 jcharest domain^users 1967 Jun 28 05:58 p3509-0000+p3668-0000-qspi.conf
-rw-rw-rw- 1 jcharest domain^users 2497 Jun 28 05:58 p3509-0000+p3668-0000-qspi-sd.conf
-rw-rw-rw- 1 jcharest domain^users 2428 Jun 28 05:58 p3509-0000+p3668-0001-qspi-emmc.conf
-rw-rw-rw- 1 jcharest domain^users 6241 Jun 28 05:58 p3668.conf.common
-rw-rw-rw- 1 jcharest domain^users 9162 Jun 28 05:58 p3701.conf.common
-rw-rw-rw- 1 jcharest domain^users 3693 Jun 28 05:58 p3711-0000+p3701-0002.conf
-rw-rw-rw- 1 jcharest domain^users 2153 Jun 28 05:58 p3737-0000+p3701-0000-as-p3701-0004.conf
-rw-rw-rw- 1 jcharest domain^users 2167 Jun 28 05:58 p3737-0000+p3701-0000-as-p3767-0000.conf
-rw-rw-rw- 1 jcharest domain^users 2203 Jun 28 05:58 p3737-0000+p3701-0000-as-p3767-0010.conf
-rw-rw-rw- 1 jcharest domain^users 3203 Jun 28 05:58 p3737-0000+p3701-0000.conf
-rw-rw-rw- 1 jcharest domain^users 3215 Jun 28 05:58 p3737-0000+p3701-0000-maxn.conf
-rw-rw-rw- 1 jcharest domain^users 3604 Jun 28 05:58 README_Autoflash.txt
-rw-rw-rw- 1 jcharest domain^users 9776 Jun 28 05:58 README_Massflash.txt
drwxrwxrwx 2 jcharest domain^users 4096 Jun 28 05:58 rootfs
drwxrwxrwx 2 jcharest domain^users 4096 Jun 28 05:58 source
-rwxrwxrwx 1 jcharest domain^users 9113 Jun 28 05:58 source_sync.sh
drwxrwxrwx 10 jcharest domain^users 4096 Jun 28 06:16 tools
After waiting a day, I got the “Reading board information failed.” error again, but any subsequent try results in the failed to connect / not in recovery mode error, even after rebooting the board and placing back in recovery mode.
