15:15:47 INFO: CuDNN Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/cudnn-local-tegra-repo-ubuntu2004-8.6.0.166_1.0-1_arm64.deb with correct checksum, skip downloading.
15:16:50 INFO: VPI Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/vpi-lib-2.4.8-aarch64-l4t.deb
15:18:25 INFO: command finished successfully
15:18:25 DEBUG: running command < true >
15:18:25 INFO: exec_command: true
15:18:26 INFO: command finished successfully
15:18:27 SUMMARY: CUDA on Host - host: Install completed successfully.
15:18:27 SUMMARY: CUDA Cross Compile Package on Host - host: Install completed successfully.
15:18:27 SUMMARY: VPI on Host - host: Install completed successfully.
15:18:27 SUMMARY: Nsight Systems - host: Install completed successfully.
15:18:27 INFO: command finished successfully
15:18:27 DEBUG: running command < sudo rm -rf ā/home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETSā >
15:18:27 INFO: exec_command: sudo rm -rf ā/home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETSā
15:18:31 INFO: command finished successfully
15:18:31 INFO: Drivers for Jetson - target_image: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R35.5.0_aarch64.tbz2
15:19:33 INFO: command finished successfully
15:19:33 INFO: Drivers for Jetson - target_image: sudo rm -rf /home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/
15:19:33 INFO: Drivers for Jetson - target_image: **********************
15:19:33 INFO: Drivers for Jetson - target_image: tar xf /home/jk/Downloads/nvidia/sdkm_downloads/Jetson_Linux_R35.5.0_aarch64.tbz2
15:20:28 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/libnvidia-container1_1.10.0-1_arm64.deb
15:20:28 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/libnvidia-container1_1.10.0-1_arm64.deb with correct checksum, skip downloading.
15:20:28 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_1.10.0-1_arm64.deb
15:20:29 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/nvidia-container-toolkit_1.11.0_rc.1-1_arm64.deb with correct checksum, skip downloading.
15:20:38 INFO: TensorRT on Target - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb
15:20:38 INFO: OpenCV Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
15:20:41 INFO: TensorRT Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb with correct checksum, skip downloading.
15:22:04 INFO: File System and OS - target_image: **********************
15:22:04 INFO: File System and OS - target_image: sudo tar xpf /home/jk/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R35.5.0_aarch64.tbz2
15:22:04 INFO: File System and OS - target_image: cd ā¦
15:22:04 INFO: File System and OS - target_image: sudo ./tools/l4t_flash_prerequisites.sh
15:22:04 INFO: File System and OS - target_image: sudo ./apply_binaries.sh
15:27:31 INFO: File System and OS - target_image: Get:2 file:/var/cuda-repo-ubuntu1804-11-4-local InRelease [1,575 B]
15:27:35 INFO: File System and OS - target_image: Hit:6 Index of /ubuntu bionic-backports InRelease
15:27:36 INFO: File System and OS - target_image: Hit:7 Index of /compute/cuda/repos/ubuntu1804/x86_64 InRelease
15:27:42 INFO: File System and OS - target_image: Reading package listsā¦
15:27:42 INFO: File System and OS - target_image: Building dependency treeā¦
15:27:42 INFO: File System and OS - target_image: Reading state informationā¦
15:27:42 INFO: File System and OS - target_image: The following packages were automatically installed and are no longer required:
15:27:42 INFO: File System and OS - target_image: Use āsudo apt autoremoveā to remove them.
15:27:42 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
15:27:43 INFO: File System and OS - target_image: Reading package listsā¦
15:27:43 INFO: File System and OS - target_image: Building dependency treeā¦
15:27:43 INFO: File System and OS - target_image: Reading state informationā¦
15:27:43 INFO: File System and OS - target_image: The following packages were automatically installed and are no longer required:
15:27:43 INFO: File System and OS - target_image: Use āsudo apt autoremoveā to remove them.
15:27:43 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
15:27:43 INFO: File System and OS - target_image: Using rootfs directory of: /home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs
15:27:43 INFO: File System and OS - target_image: Installing extlinux.conf into /boot/extlinux in target rootfs
15:27:43 INFO: File System and OS - target_image: /home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
15:27:43 INFO: File System and OS - target_image: Copying public debian packages to rootfs
15:27:46 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-apt-source_35.5.0-20240219203809_arm64.deb ā¦
15:27:46 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-factory-service_35.5.0-20240219203809_arm64.deb ā¦
15:27:57 INFO: File System and OS - target_image: Start L4T BSP package installation
15:27:57 INFO: File System and OS - target_image: Installing QEMU binary in rootfs
15:27:58 INFO: File System and OS - target_image: ~/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs ~/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra
15:27:58 INFO: File System and OS - target_image: Installing BSP Debian packages in /home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs
15:27:58 ERROR: File System and OS - target_image: chroot: failed to run command ādpkgā: Exec format error
15:27:58 ERROR: File System and OS - target_image: command terminated with error
15:27:58 SUMMARY: Flash Jetson Linux - flash: Depends on failed component
Thanks for answering. I installed qemu-user-static. after sudo apt update, I run sdkmanager and re install. but another error is comingā¦ could you please help me?
17:07:06 INFO: File System and OS - target_image: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/Tegra_Linux_Sample-Root-Filesystem_R35.5.0_aarch64.tbz2
17:07:06 INFO: CUDA Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb
17:07:06 INFO: CuDNN Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/cudnn-local-tegra-repo-ubuntu2004-8.6.0.166_1.0-1_arm64.deb
17:07:06 INFO: TensorRT Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb
17:07:28 INFO: TensorRT Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/nv-tensorrt-local-repo-l4t-8.5.2-cuda-11.4_1.0-1_arm64.deb with correct checksum, skip downloading.
17:07:28 INFO: OpenCV Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb
17:07:28 INFO: OpenCV Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/OpenCV-4.5.4-8-g3e4c170df4-aarch64-libs.deb with correct checksum, skip downloading.
17:07:28 INFO: CuPVA Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/cupva-2.3.0-l4t.deb
17:07:28 INFO: CuPVA Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/cupva-2.3.0-l4t.deb with correct checksum, skip downloading.
17:07:28 INFO: VPI Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/vpi-lib-2.4.8-aarch64-l4t.deb
17:07:28 INFO: VPI Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.4.8-aarch64-l4t.deb
17:07:28 INFO: VPI Runtime - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.4.8-aarch64-l4t.deb
17:07:28 INFO: VPI Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/vpi-python3.8-2.4.8-aarch64-l4t.deb with correct checksum, skip downloading.
17:07:28 INFO: VPI Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/vpi-python3.9-2.4.8-aarch64-l4t.deb with correct checksum, skip downloading.
17:07:34 INFO: VPI Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/vpi-lib-2.4.8-aarch64-l4t.deb with correct checksum, skip downloading.
17:07:34 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/libnvidia-container0_0.11.0+jetpack_arm64.deb
17:07:34 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/libnvidia-container1_1.10.0-1_arm64.deb
17:07:34 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/libnvidia-container-tools_1.10.0-1_arm64.deb
17:07:34 INFO: NVIDIA Container Runtime with Docker integration (Beta) - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/nvidia-container-toolkit_1.11.0_rc.1-1_arm64.deb
17:09:13 INFO: VPI on Target - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/vpi-dev-2.4.8-aarch64-l4t.deb
17:09:13 INFO: VPI on Target - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/vpi-samples-2.4.8-aarch64-l4t.deb
17:09:13 INFO: VPI on Target - target: verifying checksum of /home/jk/Downloads/nvidia/sdkm_downloads/vpi-demos-2.4.8-aarch64-l4t.deb
17:09:15 INFO: VPI on Target - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/vpi-demos-2.4.8-aarch64-l4t.deb with correct checksum, skip downloading.
17:09:22 INFO: CUDA Runtime - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb with correct checksum, skip downloading.
17:09:22 INFO: CUDA Toolkit for L4T - target: Found file /home/jk/Downloads/nvidia/sdkm_downloads/cuda-repo-l4t-11-4-local_11.4.19-1_arm64.deb with correct checksum, skip downloading.
17:09:51 INFO: Reading package listsā¦ 0% Reading package listsā¦ 100% Reading package listsā¦ Done
17:12:35 INFO: /opt/nvidia/sdkmanager/resources/app/output/installUtils/adapter -X dHJ1ZQ== && echo āSDKM_END_CODE_SUCCESSāāaba1f03a-25f6-4cd3-80e5-f268685a5102ā || echo āSDKM_END_CODE_FAILUREāāaba1f03a-25f6-4cd3-80e5-f268685a5102ā_$?
17:19:31 INFO: File System and OS - target_image: Reading package listsā¦
17:19:32 INFO: File System and OS - target_image: Reading state informationā¦
17:19:32 INFO: File System and OS - target_image: binfmt-support is already the newest version (2.1.8-2).
17:19:32 INFO: File System and OS - target_image: device-tree-compiler is already the newest version (1.4.5-3).
17:19:32 INFO: File System and OS - target_image: dosfstools is already the newest version (4.1-1).
17:19:32 INFO: File System and OS - target_image: python3-yaml is already the newest version (3.12-1build2).
17:19:32 INFO: File System and OS - target_image: whois is already the newest version (5.3.0).
17:19:32 INFO: File System and OS - target_image: abootimg is already the newest version (0.6-1build1).
17:19:32 INFO: File System and OS - target_image: lbzip2 is already the newest version (2.5-2).
17:19:32 INFO: File System and OS - target_image: sshpass is already the newest version (1.06-1).
17:19:32 INFO: File System and OS - target_image: binutils is already the newest version (2.30-21ubuntu1~18.04.9).
17:19:32 INFO: File System and OS - target_image: cpio is already the newest version (2.12+dfsg-6ubuntu0.18.04.4).
17:19:32 INFO: File System and OS - target_image: cpp is already the newest version (4:7.4.0-1ubuntu2.3).
17:19:32 INFO: File System and OS - target_image: libxml2-utils is already the newest version (2.9.4+dfsg1-6.1ubuntu1.9).
17:19:32 INFO: File System and OS - target_image: nfs-kernel-server is already the newest version (1:1.3.4-2.1ubuntu5.5).
17:19:32 INFO: File System and OS - target_image: openssl is already the newest version (1.1.1-1ubuntu2.1~18.04.23).
17:19:32 INFO: File System and OS - target_image: rsync is already the newest version (3.1.2-2.1ubuntu1.6).
17:19:32 INFO: File System and OS - target_image: udev is already the newest version (237-3ubuntu10.57).
17:19:32 INFO: File System and OS - target_image: uuid-runtime is already the newest version (2.31.1-0.4ubuntu3.7).
17:19:32 INFO: File System and OS - target_image: qemu-user-static is already the newest version (1:2.11+dfsg-1ubuntu7.42).
17:19:32 INFO: File System and OS - target_image: zstd is already the newest version (1.3.3+dfsg-2ubuntu1.2).
17:19:32 INFO: File System and OS - target_image: Use āsudo apt autoremoveā to remove them.
17:19:33 INFO: File System and OS - target_image: Reading state informationā¦
17:19:33 INFO: File System and OS - target_image: liblz4-tool is already the newest version (0.0~r131-2ubuntu3.1).
17:19:33 INFO: File System and OS - target_image: The following packages were automatically installed and are no longer required:
17:19:33 INFO: File System and OS - target_image: efibootmgr libefiboot1 libefivar1
17:19:33 INFO: File System and OS - target_image: Use āsudo apt autoremoveā to remove them.
17:19:33 INFO: File System and OS - target_image: 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
17:19:33 INFO: File System and OS - target_image: Using rootfs directory of: /home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs
17:19:33 INFO: File System and OS - target_image: Installing extlinux.conf into /boot/extlinux in target rootfs
17:19:33 INFO: File System and OS - target_image: /home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
17:19:33 INFO: File System and OS - target_image: Root file system directory is /home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs
17:19:33 INFO: File System and OS - target_image: Copying public debian packages to rootfs
17:19:39 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-apt-source_35.5.0-20240219203809_arm64.deb ā¦
17:19:39 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-dgpu-config_35.5.0-20240219203809_arm64.deb ā¦
17:19:39 INFO: File System and OS - target_image: Skipping installation of nvidia-l4t-factory-service_35.5.0-20240219203809_arm64.deb ā¦
17:19:52 INFO: File System and OS - target_image: Start L4T BSP package installation
17:19:52 INFO: File System and OS - target_image: QEMU binary is not available, looking for QEMU from host system
17:19:52 INFO: File System and OS - target_image: Found /usr/bin/qemu-aarch64-static
17:19:52 INFO: File System and OS - target_image: Installing QEMU binary in rootfs
17:19:52 ERROR: File System and OS - target_image: mknod: /home/jk/nvidia/nvidia_sdk/JetPack_5.1.3_Linux_JETSON_AGX_ORIN_TARGETS/Linux_for_Tegra/rootfs/dev/random
17:19:52 ERROR: File System and OS - target_image: : File exists
17:19:53 ERROR: File System and OS - target_image: [exec_command]: /bin/bash -c /tmp/tmp_NV_L4T_FILE_SYSTEM_AND_OS_COMP.jk.sh; [error]: : File exists
17:19:53 INFO: File System and OS - target_image: [ Package Install Finished with Error ]
17:19:53 INFO: File System and OS - target_image: [host] [ 796.00 KB released. Disk Avail on Partition /dev/sdc: 922.22 GB ]
17:19:53 INFO: File System and OS - target_image: [ NV_L4T_FILE_SYSTEM_AND_OS_COMP Install took 7m17s ]
17:19:53 ERROR: File System and OS - target_image: command terminated with error
17:19:53 SUMMARY: File System and OS - target_image: First Error: Installation failed.
17:19:53 SUMMARY: NVIDIA Container Runtime with Docker integration (Beta) - target: Depends on failed component
17:19:53 SUMMARY: Multimedia API - target: Depends on failed component
17:19:53 SUMMARY: TensorRT on Target - target: Depends on failed component
17:19:53 SUMMARY: TensorRT Runtime - target: Depends on failed component
17:19:53 SUMMARY: VPI on Target - target: Depends on failed component
17:19:53 SUMMARY: VPI Runtime - target: Depends on failed component
17:19:53 SUMMARY: CuPVA Runtime - target: Depends on failed component
17:19:53 SUMMARY: CUDA Toolkit for L4T - target: Depends on failed component
17:19:53 SUMMARY: CUDA Runtime - target: Depends on failed component
17:19:53 SUMMARY: cuDNN on Target - target: Depends on failed component
17:19:53 SUMMARY: CuDNN Runtime - target: Depends on failed component
17:19:53 SUMMARY: OpenCV - target: Depends on failed component
17:19:53 SUMMARY: OpenCV Runtime - target: Depends on failed component
17:19:53 SUMMARY: DateTime Target Setup - target: Depends on failed component
17:19:53 SUMMARY: Flash Jetson Linux - flash: Depends on failed component
