Hi all,
with my Jetson Xavier AGX, I want to use CAN with PLLAON as clock source (i.e. was the default with earlier Jetpack versions).
I tried to follow the instructions in https://docs.nvidia.com/jetson/l4t/index.html#page/Tegra%20Linux%20Driver%20Package%20Development%20Guide/clocks.html#wwpID0E06B0HA, section “To use PLLAON as clock source”. But I don’t manage to get it right; the clock (under /sys/kernel/debug/bpmp/debug/clk/can1/parent) still seems to be set to osc.
Here is what I did:
flash a default Jetpack 4.4.1 using the command line flash.sh tool on the xavier
on my Linux host I use the
dtctool to decompile thetegra194-a02-bpmp-p2888-a04.dtbfile and edit it such that theclockssection for the can devices looks like this:clock@can1 {
allow_fractional_divider = <0x1>;
allowed-parents = <0x121 0x5b 0x13a 0x5e>;
clk-id = <0x9>;
};clock@can2 {
clk-id = <0xb>;
};Then I convert it back to
.dtband store it at the same place as the original .dtb and flash it to the xavier with
sudo ./flash.sh -r -k bpmp-fw-dtb jetson-xavier mmcblk0p1 -
Likewise, I edit the tegra194-p2888-0001-p2822-0000.dtb file to make the
clocks-initsection look like this:clocks-init { compatible = "nvidia,clocks-config"; status = "okay"; disable { clocks = <0x145 0x4>; }; };and the mttcan section
pll_source = “pllaon”;
clocks = <0x4 0x11c 0x4 0xa 0x4 0x9 0x4 0x5e>;
clock-names = “can_core”, “can_host”, “can”, “pllaon”;
then convert it to .dtb and store it under Linux_for_Tegra/kernel/dtb, then flash it with
sudo ./flash.sh -r -k kernel-dtb jetson-xavier mmcblk0p1
on the xavier,
cat /sys/kernel/debug/bpmp/debug/clk/can1/parentstill returnsosc -
checking the device tree on the xavier with
dtc -I fs /sys/firmware/devicetree/base | less, I see my changes in the .dts file -
However I notice in dmesg the following output:
[ 18.216351] CAN device driver interface
[ 18.242706] mttcan c310000.mttcan: unable to set CAN_CLK parent
[ 18.260225] mttcan c310000.mttcan: probe failed
[ 18.261622] mttcan c320000.mttcan: unable to set CAN_CLK parent
[ 18.280971] mttcan c320000.mttcan: probe failed
[ 18.313406] can: controller area network core (rev 20120528 abi 9)
[ 18.313914] NET: Registered protocol family 29
[ 18.321826] can: raw protocol (rev 20120528)
Does somebody know what I do wrong? Or how I could figure out what goes wrong?
