Shader Hash not available
NVIDIA driver: 531.61
Aftermath version: 2023.1.0.0
Render API: DirectX 12
I’ve tested Aftermath on our engine with an artificial infinite loop and it works. My problem is when I try to diagnose a real crash related to raytracing. Shader hash is not available (and therefore ShaderDebugInfoCallback is not called). I suspect that the crash is related to acceleration structs building, or ray generation recursion (probably the former). Can I extract more info using Aftermath?
Thanks,
Miguel
Thank you for using Nsight Aftermath SDK and I am sorry you ran into this issue. Are you still having this issue? If so, can you send us either a repro or at least an example crash dump? You can send to dwoods@nvidia.com.
Regards,
