SIPL_LOG_ERR and LOG_INFO not working
Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Hello. When I transitioned from SDK 5.2.6 (Xavier) to SDK 6.0.6 (Orin) I observed that LOG_INFO and SIPL_LOG_ERR functions are not printing in the terminal.
For example, I wrote this code
and the result is the following (using nvsipl_camera with -v 4):
Is there any method to enable those prints?
Thanks in advance.
Valentin
I tracked the function calls and discovered that the main printing module is not working (NvOsDebug).
I think “NvOsDebugPrintStr” is build into libnvos.so library, but this is a closed source lib and I have no idea how to debug it. Is there any environment variable I should set in order to enable the logs?
Valentin
Dear @valentin.costescu
could you check if prints coming up in /var/log/syslog when running application.
Any reason for not using latest release(i.e DRIVE OS 6.0.10)?
