Hi All,
I would like to clarify regarding the sleep-wake latency of Jetson TX2 NX. I tried to make jetson TX2 NX to sleep mode using the below command,
sudo systemctl suspend
And after sometime I wake up the Jetson TX2 NX by giving a low to high trigger at SLEEP/WAKE# pin of NVIDIA.I noticed that MOD_SLEEP# pin of NVIDIA goes to high state within 32ms after applying low to high trigger at SLEEP/WAKE# pin .Also I made a GPIO pin to high using a script ( script path is :lib/systemd/system-sleep) after wake up of NVIDIA to calculate the latency taken by NVIDIA to wake up from deep sleep.But GPIO is taking 3.3 sec to change to high state. If BT driver is disabled the GPIO will change to high state after 1.3sec . Usually How much time jetson TX2 NX will take to wake up from sleep mode?
If Jetson takes around 3 sec to wake up from SLEEP , can we have any other methods to reduce the wake up time?
Kindly support me .
Thanks in advance
