I think I have experienced all issues regarding freezing, not booting etc I have read in other threads
What is making the jetson nano so sensitive? I have used the same tool burning many images before for both RPi’s and Odroids without a single problem. Tried both on my mac book with apple pie baker and on windows with USB Image toool
Sometimes it doesn’t boot at all, after re-applying power it may boot
Sometimes it boots but black desktop, nothing
Sometimes it boots fine, I get the desktop but when I click anywhere, it freezes, disconnecting power only way out
When it works it can work some minutes, sometimes some hours. Then suddenly it freezes
Managed to install Hello AI-World (several freezes on during the process). Luckily running some inference tests but suddenly a freeze again, getting frustrated
Most of the times it freezes by itself ---- just by doing nothing
Is it my sd cards? I use 32G San Disk Ultra. Are they not good enough?
Is it my power supply? I’m using a 5V/4A, running in 5W mode
Is it my network? Tried both wired and wifi, no difference, same problems
I think there is something in your firmware or your ubuntu distro
Also note that a reverse protection diode through the barrel connector probably drops the voltage by about 0.2V. Thus the barrel connector might need about 0.2V higher supply to be stable.
Just some feedback; my power supply is a 5V/4A switched unit, I have measured the output (under load when connected to the jetson) and it is then showing 5.20V, should be good enough, but I will anyway purchase a new unit
If I’m lucky, the thing is running anywhere from a few minutes up to half a day. It is very strange. Most of the time it is also very hard to restart, I have to unplug power supply several times, then suddenly it might wake up
Even tried to make a new sd card based on the backup that normally happens to start, but no luck with that one
The nice setup I had is not working anymore. The Hello AI, all python libraries, all work done and the thing doesn’t even boot any longer. Was running fine this morning, stopped by itself sometime today, now only thing is the nvidia logo on the screen
Seriously, this is no fun!!
Tomorrow, last chance, I will buy a new power supply & a “super high quality more expensive” sd card. If it doesn’t help, the jetson will go to the bin, I do not have time playing around with such simple fundamentals that just should work. Great idea but it feels not mature enough and if it is so sensitive to what model of power supply and sd cards, they should be included in the kit, adding a few dollars more is no problem as long as you get things that works when put together
I have some San Disk Ultra 32GB as well as San Disk Extreme Plus 32GB (more expensive). All works without problem in the new unit, currently running since yesterday with Extreme Plus
