Soft-RoCE can't be installed after compiled?
Hi All
I am trying to setup the soft roce on my Ubuntu 16.04/18.04 following the steps mentioned here in
HowTo Configure Soft-RoCE https://community.mellanox.com/s/article/howto-configure-soft-roce
But Its failing at “install user space libary”. when I use command sudo make install to install after compiled, it prompt as follow:
CMake Error at cmake_install.cmake:73 (file):
file INSTALL cannot find
“/home/liao/Downloads/rdma-core/build/lib/librdmacm.so.1.2.27.0”.
Can someone help me in regard to this?
any suggestions are appreciated?
regards
Liaoweizhi​
Try the following:
  • sudo apt-get install cmake
  • sudo make install
  • sudo updatedb
  • locate cmake
  • cmake
and then try to compile
Thanks,
Samer
Thank you, the problem is still not solved. I think there is something wrong with the build system. When I compiled it, librdmacm.so.1.2.27.0 was in the directory, but when I made an installation and got an error, it disappeared.
Looks like issue with the compiling the build system.
did you check the the cmake build ?
Thanks,
Samer
