I am creating a scenario of pick and place an object using an articulation of UR10 + My Custom Hand.
Could someone explain please the difference between: solver_position_iteration_count and solver_velocity_iteration_count ?
When I try to lift a heavier object and give high values to these solvers, I can lift the object and computationally heavy load my GPU. Usually, I lift light objects of 0.1kg with these default solver values.
Thank you in advance~~~
Hi @ulantemirlan2002,
in which context is this? Are you using Isaac SIM or something else connected to Omniverse?
You might be in the wrong category on this forum.
Oh, my bad. I actually use IsaacLab/Isaac Sim.
No worries, I moved your post for you.
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
