What is the default value of the LulaKinematics?
Here is docs about LulaKinematics,
and my question is where can I get a default parameters for this library?
for examaple, in the set_max_iterations , what is the default value and where can I check it?
`set_max_iterations` (*max_iterations: int* ) → None
Set the maximum number of iterations that the IK solver will attempt before giving up
Parameters
**max_iterations** (*int*) – maximum number of iterations that the IK solver will attempt before giving up
thanks!
There is also a getter get_max_iterations in the LulaKinematics docs that you can use.
