SPI: Use custom CS
I have 2 CS on spi@3210000. They are all on main GPIO controller pin. (H6, Q5). The device-tree and drivers are working on Jetson Xavier.
When I use spidev to test, the MOSI, SCK are ok but the CS is not moving.
sudo ./spidev_test -D /dev/spidev0.0 -b 8 --cpha --cpol -v
I add log in the kernel and they are both gpiod_set_consumer_name in line 2611 of file drivers/spi/spi.c
If I remove cs-gpios from the device tree, I can toggle both gpios with /sys/class/gpio. If I let cs-gpios in the device-tree, I have: bash: echo: write error: Device or resource busy.
I saw in another post that cs-gpios is not the same as old Jetson:
How can I use this property with Orin NX ?
Device tree:
	spi0: spi@3210000 {
		status = "okay";
		spi-max-frequency = <12000000>;
		num-cs = <2>;
		cs-gpios =
			<&tegra_main_gpio TEGRA234_MAIN_GPIO(H, 6) GPIO_ACTIVE_LOW>, /* Sensor 1 */
			<&tegra_main_gpio TEGRA234_MAIN_GPIO(Q, 0) GPIO_ACTIVE_LOW>; /* Sensor 2 */
		spidev0: spidev@0 {
			compatible = "tegra-spidev";
			#gpio-cells = <2>;
			reg = <0>;
			status = "okay";
			spi-cpol;
			spi-cpha;
			spi-max-frequency = <10000000>;
			vdd-supply = <&vdd_1v8>;
		spidev1: spidev@1 {
			#gpio-cells = <2>;
			reg = <1>;
			status = "okay";
			spi-cpol;
			spi-cpha;
Pinmux:
/*This dtsi file was generated by client-sensor.xlsm Revision: 1,01 */
 * SPDX-FileCopyrightText: Copyright (c) 2022 NVIDIA CORPORATION & AFFILIATES. All rights reserved.
 * SPDX-License-Identifier: BSD-3-Clause
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright notice, this
 * list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright notice,
 * this list of conditions and the following disclaimer in the documentation
 * and/or other materials provided with the distribution.
 * 3. Neither the name of the copyright holder nor the names of its
 * contributors may be used to endorse or promote products derived from
 * this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS 'AS IS'
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
 * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
 * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
 * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
 * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
 * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/dts-v1/;
#include "pinctrl-tegra.h"
#include "./Orin-client-sensor-gpio-default.dtsi"
	pinmux@2430000 {
		pinctrl-names = "default", "drive", "unused";
		pinctrl-0 = <&pinmux_default>;
		pinctrl-1 = <&drive_default>;
		pinctrl-2 = <&pinmux_unused_lowpower>;
		pinmux_default: common {
			/* SFIO Pin Configuration */
			shutdown_n {
				nvidia,pins = "shutdown_n";
				nvidia,function = "shutdown";
				nvidia,pull = <TEGRA_PIN_PULL_NONE>;
				nvidia,tristate = <TEGRA_PIN_DISABLE>;
				nvidia,enable-input = <TEGRA_PIN_DISABLE>;
				nvidia,io-high-voltage = <TEGRA_PIN_DISABLE>;
				nvidia,lpdr = <TEGRA_PIN_DISABLE>;
			vcomp_alert_pee1 {
				nvidia,pins = "vcomp_alert_pee1";
				nvidia,function = "soc";
				nvidia,tristate = <TEGRA_PIN_ENABLE>;
				nvidia,enable-input = <TEGRA_PIN_ENABLE>;
			batt_oc_pee3 {
				nvidia,pins = "batt_oc_pee3";
				nvidia,pull = <TEGRA_PIN_PULL_UP>;
			touch_clk_pcc4 {
				nvidia,pins = "touch_clk_pcc4";
				nvidia,function = "gp";
				nvidia,io-high-voltage = <TEGRA_PIN_ENABLE>;
			uart3_tx_pcc5 {
				nvidia,pins = "uart3_tx_pcc5";
				nvidia,function = "uartc";
			uart3_rx_pcc6 {
				nvidia,pins = "uart3_rx_pcc6";
			gen2_i2c_scl_pcc7 {
				nvidia,pins = "gen2_i2c_scl_pcc7";
				nvidia,function = "i2c2";
			gen2_i2c_sda_pdd0 {
				nvidia,pins = "gen2_i2c_sda_pdd0";
			gen8_i2c_scl_pdd1 {
				nvidia,pins = "gen8_i2c_scl_pdd1";
				nvidia,function = "i2c8";
			gen8_i2c_sda_pdd2 {
				nvidia,pins = "gen8_i2c_sda_pdd2";
			soc_gpio50_pbb2 {
				nvidia,pins = "soc_gpio50_pbb2";
				nvidia,function = "tsc_edge_out0";
			gp_pwm3_px3 {
				nvidia,pins = "gp_pwm3_px3";
			uart2_tx_px4 {
				nvidia,pins = "uart2_tx_px4";
				nvidia,function = "uartb";
			uart2_rx_px5 {
				nvidia,pins = "uart2_rx_px5";
			spi3_sck_py0 {
				nvidia,pins = "spi3_sck_py0";
				nvidia,function = "spi3";
			spi3_miso_py1 {
				nvidia,pins = "spi3_miso_py1";
			spi3_mosi_py2 {
				nvidia,pins = "spi3_mosi_py2";
			spi1_sck_pz3 {
				nvidia,pins = "spi1_sck_pz3";
				nvidia,function = "spi1";
			spi1_miso_pz4 {
				nvidia,pins = "spi1_miso_pz4";
			spi1_mosi_pz5 {
				nvidia,pins = "spi1_mosi_pz5";
			soc_gpio24_pp5 {
				nvidia,pins = "soc_gpio24_pp5";
			pwr_i2c_scl_pp7 {
				nvidia,pins = "pwr_i2c_scl_pp7";
				nvidia,function = "i2c5";
			pwr_i2c_sda_pq0 {
				nvidia,pins = "pwr_i2c_sda_pq0";
			uart1_tx_pr2 {
				nvidia,pins = "uart1_tx_pr2";
				nvidia,function = "uarta";
			uart1_rx_pr3 {
				nvidia,pins = "uart1_rx_pr3";
			uart1_rts_pr4 {
				nvidia,pins = "uart1_rts_pr4";
			uart1_cts_pr5 {
				nvidia,pins = "uart1_cts_pr5";
			soc_gpio21_ph0 {
				nvidia,pins = "soc_gpio21_ph0";
			gen1_i2c_scl_pi3 {
				nvidia,pins = "gen1_i2c_scl_pi3";
				nvidia,function = "i2c1";
			gen1_i2c_sda_pi4 {
				nvidia,pins = "gen1_i2c_sda_pi4";
			soc_gpio07_pi6 {
				nvidia,pins = "soc_gpio07_pi6";
			sdmmc1_clk_pj0 {
				nvidia,pins = "sdmmc1_clk_pj0";
				nvidia,function = "sdmmc1";
				nvidia,loopback = <TEGRA_PIN_ENABLE>;
			sdmmc1_cmd_pj1 {
				nvidia,pins = "sdmmc1_cmd_pj1";
			sdmmc1_dat0_pj2 {
				nvidia,pins = "sdmmc1_dat0_pj2";
			sdmmc1_dat1_pj3 {
				nvidia,pins = "sdmmc1_dat1_pj3";
			sdmmc1_dat2_pj4 {
				nvidia,pins = "sdmmc1_dat2_pj4";
			sdmmc1_dat3_pj5 {
				nvidia,pins = "sdmmc1_dat3_pj5";
			qspi0_sck_pc0 {
				nvidia,pins = "qspi0_sck_pc0";
				nvidia,function = "qspi0";
				nvidia,pull = <TEGRA_PIN_PULL_DOWN>;
			qspi0_cs_n_pc1 {
				nvidia,pins = "qspi0_cs_n_pc1";
			qspi0_io0_pc2 {
				nvidia,pins = "qspi0_io0_pc2";
			qspi0_io1_pc3 {
				nvidia,pins = "qspi0_io1_pc3";
			qspi0_io2_pc4 {
				nvidia,pins = "qspi0_io2_pc4";
			qspi0_io3_pc5 {
				nvidia,pins = "qspi0_io3_pc5";
			pex_l1_clkreq_n_pk2 {
				nvidia,pins = "pex_l1_clkreq_n_pk2";
				nvidia,function = "pe1";
			pex_l1_rst_n_pk3 {
				nvidia,pins = "pex_l1_rst_n_pk3";
			pex_l4_clkreq_n_pl0 {
				nvidia,pins = "pex_l4_clkreq_n_pl0";
				nvidia,function = "pe4";
			pex_l4_rst_n_pl1 {
				nvidia,pins = "pex_l4_rst_n_pl1";
			pex_l7_clkreq_n_pag0 {
				nvidia,pins = "pex_l7_clkreq_n_pag0";
				nvidia,function = "pe7";
			pex_l7_rst_n_pag1 {
				nvidia,pins = "pex_l7_rst_n_pag1";
			pex_l8_clkreq_n_pag2 {
				nvidia,pins = "pex_l8_clkreq_n_pag2";
				nvidia,function = "pe8";
			pex_l8_rst_n_pag3 {
				nvidia,pins = "pex_l8_rst_n_pag3";
			pex_l9_clkreq_n_pag4 {
				nvidia,pins = "pex_l9_clkreq_n_pag4";
				nvidia,function = "pe9";
			pex_l9_rst_n_pag5 {
				nvidia,pins = "pex_l9_rst_n_pag5";
			/* GPIO Pin Configuration */
			ao_retention_n_pee2 {
				nvidia,pins = "ao_retention_n_pee2";
				nvidia,function = "rsvd2";
			power_on_pee4 {
				nvidia,pins = "power_on_pee4";
				nvidia,function = "rsvd0";
			hdmi_cec_pgg0 {
				nvidia,pins = "hdmi_cec_pgg0";
				nvidia,function = "rsvd1";
			spi2_sck_pcc0 {
				nvidia,pins = "spi2_sck_pcc0";
			spi2_miso_pcc1 {
				nvidia,pins = "spi2_miso_pcc1";
			spi2_mosi_pcc2 {
				nvidia,pins = "spi2_mosi_pcc2";
			spi2_cs0_pcc3 {
				nvidia,pins = "spi2_cs0_pcc3";
			can0_dout_paa0 {
				nvidia,pins = "can0_dout_paa0";
			can0_din_paa1 {
				nvidia,pins = "can0_din_paa1";
			can0_stb_paa4 {
				nvidia,pins = "can0_stb_paa4";
			can0_en_paa5 {
				nvidia,pins = "can0_en_paa5";
			can1_err_pbb3 {
				nvidia,pins = "can1_err_pbb3";
			soc_gpio08_pb0 {
				nvidia,pins = "soc_gpio08_pb0";
			uart2_rts_px6 {
				nvidia,pins = "uart2_rts_px6";
			uart2_cts_px7 {
				nvidia,pins = "uart2_cts_px7";
			spi3_cs0_py3 {
				nvidia,pins = "spi3_cs0_py3";
			spi3_cs1_py4 {
				nvidia,pins = "spi3_cs1_py4";
			usb_vbus_en0_pz1 {
				nvidia,pins = "usb_vbus_en0_pz1";
			spi1_cs0_pz6 {
				nvidia,pins = "spi1_cs0_pz6";
			spi1_cs1_pz7 {
				nvidia,pins = "spi1_cs1_pz7";
			extperiph1_clk_pp0 {
				nvidia,pins = "extperiph1_clk_pp0";
			extperiph2_clk_pp1 {
				nvidia,pins = "extperiph2_clk_pp1";
			cam_i2c_scl_pp2 {
				nvidia,pins = "cam_i2c_scl_pp2";
				nvidia,function = "i2c3";
			cam_i2c_sda_pp3 {
				nvidia,pins = "cam_i2c_sda_pp3";
			soc_gpio25_pp6 {
				nvidia,pins = "soc_gpio25_pp6";
				nvidia,function = "vi0";
			soc_gpio29_pq2 {
				nvidia,pins = "soc_gpio29_pq2";
			soc_gpio30_pq3 {
				nvidia,pins = "soc_gpio30_pq3";
			soc_gpio32_pq5 {
				nvidia,pins = "soc_gpio32_pq5";
			soc_gpio33_pq6 {
				nvidia,pins = "soc_gpio33_pq6";
			dp_aux_ch0_hpd_pm0 {
				nvidia,pins = "dp_aux_ch0_hpd_pm0";
			soc_gpio39_pn1 {
				nvidia,pins = "soc_gpio39_pn1";
			soc_gpio13_pg0 {
				nvidia,pins = "soc_gpio13_pg0";
			soc_gpio19_pg6 {
				nvidia,pins = "soc_gpio19_pg6";
			soc_gpio20_pg7 {
				nvidia,pins = "soc_gpio20_pg7";
			uart4_cts_ph6 {
				nvidia,pins = "uart4_cts_ph6";
			soc_gpio41_ph7 {
				nvidia,pins = "soc_gpio41_ph7";
			soc_gpio42_pi0 {
				nvidia,pins = "soc_gpio42_pi0";
			soc_gpio43_pi1 {
				nvidia,pins = "soc_gpio43_pi1";
			soc_gpio44_pi2 {
				nvidia,pins = "soc_gpio44_pi2";
			cpu_pwr_req_pi5 {
				nvidia,pins = "cpu_pwr_req_pi5";
			spi5_sck_pac0 {
				nvidia,pins = "spi5_sck_pac0";
				nvidia,function = "rsvd3";
			soc_gpio59_pac6 {
				nvidia,pins = "soc_gpio59_pac6";
			pex_l2_clkreq_n_pk4 {
				nvidia,pins = "pex_l2_clkreq_n_pk4";
			pex_l2_rst_n_pk5 {
				nvidia,pins = "pex_l2_rst_n_pk5";
			pex_wake_n_pl2 {
				nvidia,pins = "pex_wake_n_pl2";
			dap6_sclk_pa0 {
				nvidia,pins = "dap6_sclk_pa0";
			dap4_sclk_pa4 {
				nvidia,pins = "dap4_sclk_pa4";
			dap4_dout_pa5 {
				nvidia,pins = "dap4_dout_pa5";
			dap4_din_pa6 {
				nvidia,pins = "dap4_din_pa6";
			dap4_fs_pa7 {
				nvidia,pins = "dap4_fs_pa7";
		pinmux_unused_lowpower: unused_lowpower {
			sce_error_pee0 {
				nvidia,pins = "sce_error_pee0";
			soc_gpio26_pee5 {
				nvidia,pins = "soc_gpio26_pee5";
			soc_gpio27_pee6 {
				nvidia,pins = "soc_gpio27_pee6";
			bootv_ctl_n_pee7 {
				nvidia,pins = "bootv_ctl_n_pee7";
			can1_dout_paa2 {
				nvidia,pins = "can1_dout_paa2";
			can1_din_paa3 {
				nvidia,pins = "can1_din_paa3";
			soc_gpio49_paa6 {
				nvidia,pins = "soc_gpio49_paa6";
			can0_err_paa7 {
				nvidia,pins = "can0_err_paa7";
			can1_stb_pbb0 {
				nvidia,pins = "can1_stb_pbb0";
			can1_en_pbb1 {
				nvidia,pins = "can1_en_pbb1";
			gpu_pwr_req_px0 {
				nvidia,pins = "gpu_pwr_req_px0";
			cv_pwr_req_px1 {
				nvidia,pins = "cv_pwr_req_px1";
			gp_pwm2_px2 {
				nvidia,pins = "gp_pwm2_px2";
			uart5_tx_py5 {
				nvidia,pins = "uart5_tx_py5";
			uart5_rx_py6 {
				nvidia,pins = "uart5_rx_py6";
			uart5_rts_py7 {
				nvidia,pins = "uart5_rts_py7";
			uart5_cts_pz0 {
				nvidia,pins = "uart5_cts_pz0";
			usb_vbus_en1_pz2 {
				nvidia,pins = "usb_vbus_en1_pz2";
			soc_gpio23_pp4 {
				nvidia,pins = "soc_gpio23_pp4";
			soc_gpio28_pq1 {
				nvidia,pins = "soc_gpio28_pq1";
			soc_gpio31_pq4 {
				nvidia,pins = "soc_gpio31_pq4";
			soc_gpio35_pq7 {
				nvidia,pins = "soc_gpio35_pq7";
			soc_gpio37_pr0 {
				nvidia,pins = "soc_gpio37_pr0";
			soc_gpio56_pr1 {
				nvidia,pins = "soc_gpio56_pr1";
			dp_aux_ch1_p_pn3 {
				nvidia,pins = "dp_aux_ch1_p_pn3";
			dp_aux_ch1_n_pn4 {
				nvidia,pins = "dp_aux_ch1_n_pn4";
			dp_aux_ch1_hpd_pm1 {
				nvidia,pins = "dp_aux_ch1_hpd_pm1";
			dp_aux_ch2_p_pn5 {
				nvidia,pins = "dp_aux_ch2_p_pn5";
			dp_aux_ch2_n_pn6 {
				nvidia,pins = "dp_aux_ch2_n_pn6";
			dp_aux_ch2_hpd_pm2 {
				nvidia,pins = "dp_aux_ch2_hpd_pm2";
			dp_aux_ch3_p_pn7 {
				nvidia,pins = "dp_aux_ch3_p_pn7";
			dp_aux_ch3_n_pn0 {
				nvidia,pins = "dp_aux_ch3_n_pn0";
			dp_aux_ch3_hpd_pm3 {
				nvidia,pins = "dp_aux_ch3_hpd_pm3";
			soc_gpio55_pm4 {
				nvidia,pins = "soc_gpio55_pm4";
			soc_gpio36_pm5 {
				nvidia,pins = "soc_gpio36_pm5";
			soc_gpio53_pm6 {
				nvidia,pins = "soc_gpio53_pm6";
			soc_gpio38_pm7 {
				nvidia,pins = "soc_gpio38_pm7";
			soc_gpio40_pn2 {
				nvidia,pins = "soc_gpio40_pn2";
			soc_gpio14_pg1 {
				nvidia,pins = "soc_gpio14_pg1";
			soc_gpio15_pg2 {
				nvidia,pins = "soc_gpio15_pg2";
			soc_gpio16_pg3 {
				nvidia,pins = "soc_gpio16_pg3";
			soc_gpio17_pg4 {
				nvidia,pins = "soc_gpio17_pg4";
			soc_gpio18_pg5 {
				nvidia,pins = "soc_gpio18_pg5";
			soc_gpio22_ph1 {
				nvidia,pins = "soc_gpio22_ph1";
			soc_gpio06_ph2 {
				nvidia,pins = "soc_gpio06_ph2";
			uart4_tx_ph3 {
				nvidia,pins = "uart4_tx_ph3";
			uart4_rx_ph4 {
				nvidia,pins = "uart4_rx_ph4";
			uart4_rts_ph5 {
				nvidia,pins = "uart4_rts_ph5";
			qspi1_sck_pc6 {
				nvidia,pins = "qspi1_sck_pc6";
			qspi1_cs_n_pc7 {
				nvidia,pins = "qspi1_cs_n_pc7";
			qspi1_io0_pd0 {
				nvidia,pins = "qspi1_io0_pd0";
			qspi1_io1_pd1 {
				nvidia,pins = "qspi1_io1_pd1";
			qspi1_io2_pd2 {
				nvidia,pins = "qspi1_io2_pd2";
			qspi1_io3_pd3 {
				nvidia,pins = "qspi1_io3_pd3";
			eqos_txc_pe0 {
				nvidia,pins = "eqos_txc_pe0";
			eqos_td0_pe1 {
				nvidia,pins = "eqos_td0_pe1";
			eqos_td1_pe2 {
				nvidia,pins = "eqos_td1_pe2";
			eqos_td2_pe3 {
				nvidia,pins = "eqos_td2_pe3";
			eqos_td3_pe4 {
				nvidia,pins = "eqos_td3_pe4";
			eqos_tx_ctl_pe5 {
				nvidia,pins = "eqos_tx_ctl_pe5";
			eqos_rd0_pe6 {
				nvidia,pins = "eqos_rd0_pe6";
			eqos_rd1_pe7 {
				nvidia,pins = "eqos_rd1_pe7";
			eqos_rd2_pf0 {
				nvidia,pins = "eqos_rd2_pf0";
			eqos_rd3_pf1 {
				nvidia,pins = "eqos_rd3_pf1";
			eqos_rx_ctl_pf2 {
				nvidia,pins = "eqos_rx_ctl_pf2";
			eqos_rxc_pf3 {
				nvidia,pins = "eqos_rxc_pf3";
			eqos_sma_mdio_pf4 {
				nvidia,pins = "eqos_sma_mdio_pf4";
			eqos_sma_mdc_pf5 {
				nvidia,pins = "eqos_sma_mdc_pf5";
			spi5_miso_pac1 {
				nvidia,pins = "spi5_miso_pac1";
			spi5_mosi_pac2 {
				nvidia,pins = "spi5_mosi_pac2";
			spi5_cs0_pac3 {
				nvidia,pins = "spi5_cs0_pac3";
			soc_gpio57_pac4 {
				nvidia,pins = "soc_gpio57_pac4";
			soc_gpio58_pac5 {
				nvidia,pins = "soc_gpio58_pac5";
			soc_gpio60_pac7 {
				nvidia,pins = "soc_gpio60_pac7";
			soc_gpio45_pad0 {
				nvidia,pins = "soc_gpio45_pad0";
			soc_gpio46_pad1 {
				nvidia,pins = "soc_gpio46_pad1";
			soc_gpio47_pad2 {
				nvidia,pins = "soc_gpio47_pad2";
			soc_gpio48_pad3 {
				nvidia,pins = "soc_gpio48_pad3";
			ufs0_ref_clk_pae0 {
				nvidia,pins = "ufs0_ref_clk_pae0";
			ufs0_rst_n_pae1 {
				nvidia,pins = "ufs0_rst_n_pae1";
			pex_l0_clkreq_n_pk0 {
				nvidia,pins = "pex_l0_clkreq_n_pk0";
			pex_l0_rst_n_pk1 {
				nvidia,pins = "pex_l0_rst_n_pk1";
			pex_l3_clkreq_n_pk6 {
				nvidia,pins = "pex_l3_clkreq_n_pk6";
			pex_l3_rst_n_pk7 {
				nvidia,pins = "pex_l3_rst_n_pk7";
			soc_gpio34_pl3 {
				nvidia,pins = "soc_gpio34_pl3";
			pex_l10_clkreq_n_pag6 {
				nvidia,pins = "pex_l10_clkreq_n_pag6";
			pex_l10_rst_n_pag7 {
				nvidia,pins = "pex_l10_rst_n_pag7";
			can2_dout_ps0 {
				nvidia,pins = "can2_dout_ps0";
			can2_din_ps1 {
				nvidia,pins = "can2_din_ps1";
			can2_stb_ps2 {
				nvidia,pins = "can2_stb_ps2";
			can2_en_ps3 {
				nvidia,pins = "can2_en_ps3";
			can2_err_ps4 {
				nvidia,pins = "can2_err_ps4";
			can3_dout_ps5 {
				nvidia,pins = "can3_dout_ps5";
			can3_din_ps6 {
				nvidia,pins = "can3_din_ps6";
			can3_stb_ps7 {
				nvidia,pins = "can3_stb_ps7";
			can3_en_pt0 {
				nvidia,pins = "can3_en_pt0";
			can3_err_pt1 {
				nvidia,pins = "can3_err_pt1";
			soc_error_pu0 {
				nvidia,pins = "soc_error_pu0";
			uart7_tx_pu1 {
				nvidia,pins = "uart7_tx_pu1";
			uart7_rx_pu2 {
				nvidia,pins = "uart7_rx_pu2";
			spi7_sck_pu3 {
				nvidia,pins = "spi7_sck_pu3";
			spi7_miso_pu4 {
				nvidia,pins = "spi7_miso_pu4";
			spi7_mosi_pu5 {
				nvidia,pins = "spi7_mosi_pu5";
			spi7_cs0_pu6 {
				nvidia,pins = "spi7_cs0_pu6";
			soc_gpio51_pu7 {
				nvidia,pins = "soc_gpio51_pu7";
			soc_gpio52_pv0 {
				nvidia,pins = "soc_gpio52_pv0";
			soc_gpio61_pw0 {
				nvidia,pins = "soc_gpio61_pw0";
			soc_gpio62_pw1 {
				nvidia,pins = "soc_gpio62_pw1";
			dap6_dout_pa1 {
				nvidia,pins = "dap6_dout_pa1";
			dap6_din_pa2 {
				nvidia,pins = "dap6_din_pa2";
			dap6_fs_pa3 {
				nvidia,pins = "dap6_fs_pa3";
			pex_l5_clkreq_n_paf0 {
				nvidia,pins = "pex_l5_clkreq_n_paf0";
			pex_l5_rst_n_paf1 {
				nvidia,pins = "pex_l5_rst_n_paf1";
			pex_l6_clkreq_n_paf2 {
				nvidia,pins = "pex_l6_clkreq_n_paf2";
			pex_l6_rst_n_paf3 {
				nvidia,pins = "pex_l6_rst_n_paf3";
			emmc_clk {
				nvidia,pins = "emmc_clk";
			emmc_cmd {
				nvidia,pins = "emmc_cmd";
				nvidia,loopback = <TEGRA_PIN_DISABLE>;
			emmc_dat0 {
				nvidia,pins = "emmc_dat0";
			emmc_dat1 {
				nvidia,pins = "emmc_dat1";
			emmc_dat2 {
				nvidia,pins = "emmc_dat2";
			emmc_dat3 {
				nvidia,pins = "emmc_dat3";
			emmc_dat4 {
				nvidia,pins = "emmc_dat4";
			emmc_dat5 {
				nvidia,pins = "emmc_dat5";
			emmc_dat6 {
				nvidia,pins = "emmc_dat6";
			emmc_dat7 {
				nvidia,pins = "emmc_dat7";
			emmc_dqs {
				nvidia,pins = "emmc_dqs";
		drive_default: drive {
Hi jbzp00y,
What’s your carrier board for Orin NX?
Do you mean that SPI loopback test fine with MOSI/MOSI connected?
(i.e. you can receive the data what you sent)
Could you provide the result of the following command?
$sudo busybox devmem 0x0243d040 //SPI1_MOSI - PZ.05
$sudo busybox devmem 0x0243d018 //SPI1_MISO - PZ.04
$sudo busybox devmem 0x0243d028 //SPI1_SCK - PZ.03
$sudo busybox devmem 0x0243d008 //SPI1_CS0 - PZ.06
$sudo busybox devmem 0x0243d038 //SPI1_CS1 - PZ.07
What’s your peripheral device for SPI interface? Is it also TPM?
Could you also help to provide the serial console log for further check?
It’s a custom carrier board. But I can see H.06 toggling with the oscilloscope.
I don’t test this. I connect oscilloscope probe on MOSI/MISO/SCK/CS and I can see MOSI and SCK toggling.
Here are my results:
nvidia@ubuntu:~$ sudo busybox devmem 0x0243d040
0x00000400
nvidia@ubuntu:~$ sudo busybox devmem 0x0243d018
0x00000450
nvidia@ubuntu:~$ sudo busybox devmem 0x0243d028
0x00001400
nvidia@ubuntu:~$ sudo busybox devmem 0x0243d008
0x00000001
nvidia@ubuntu:~$ sudo busybox devmem 0x0243d038
0x00000001
It’s a camera sensor. But the sensor is not connected to isolate problems causes. My problem here is that the CS is not pulled down during transfers.
Console log when spidev:
nvidia@ubuntu:~/spidev$ sudo ./spidev_test -D /dev/spidev0.0 -b 8 --cpha --cpol -v
spi mode: 0x7
bits per word: 8
max speed: 500000 Hz (500 kHz)
TX | FF FF FF FF FF FF 40 00 00 00 00 95 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F0 0D  |......@.........................|
RX | FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  |................................|
The CS pin for spi@3210000 is PZ.06 and PZ.07. Why you say PH.06 and PQ.05 here?
The result is as expected, it means pinmux configuration for SPI1 is fine.
It seems you could not receive the data, your SPI loopback test is failed..
It’s my question, I want to use other GPIO for CS. It was possible on Jetson Xavier, TX2 and Nano.
It’s normal, I don’t connect MOSI to MISO. I do my test with a oscilloscope.
I can’t see any CS usage for PH.06 o PQ.05 in pinmux table.
Could you help to provide the example or usage on either Xavier, TX2 or Nano about using other GPIO for CS usage?
Okay, you could also connect them together and run the command again to verify.
Yes it’s not in the pinmux, I want to use custom GPIO. In the future, I had to use 4 CS for only one SPI. It’s possible according to the reference manual.
spi@7000d400 {
		status = "okay";
		cs-gpios =
			<&gpio TEGRA_GPIO(H, 6) GPIO_ACTIVE_LOW>, /* FPGA */
			<0>,
			<&gpio TEGRA_GPIO(S, 0) GPIO_ACTIVE_LOW>; /* Sensor */
		// The FPGA is not used with this sensor now.
		me2210: me2210@0 {
			compatible = "me,me2210", "tegra-spidev";
			#gpio-cells = <2>;
			reg = <0>;
			spi-cpol;
			spi-cpha;
			gpio-line-names =
				"", "J1p05", "J1p06", "J1p07",
				"J1p08", "J1p09", "J1p10", "J1p11",
				"J1p12", "", "", "",
				"J1p16", "J1p17", "J1p18", "J1p19",
				"J1p20", "", "", "J1p23",
				"J1p24", "J1p25", "J1p26", "J1p27",
				"J1p28", "J1p29", "J1p30", "";
			vdd-supply = <&battery_reg>;
		/delete-node/ prod-settings;
		imx264@2 {
			compatible = "sony,imx250_or_imx530";
			reg = <2>;
			status = "okay";
			pgood-gpios = <&tca9539_76 8 GPIO_ACTIVE_HIGH>; // Added to check if power good is ok before probing the camera
			spi-lsb-first;
			spi-cpol;
			spi-cpha;
			clocks = <&tegra_car TEGRA210_CLK_CLK_OUT_3>;
			clock-names = "clk_out_3";
			mclk = "clk_out_3";
			/*clocks = <&tegra_car TEGRA186_CLK_EXTPERIPH2>, <&tegra_car TEGRA186_CLK_PLLP_OUT0>;
			clock-names = "extperiph2", "pllp_grtba";
			mclk = "extperiph2";*/
			reset-gpios = <&gpio TEGRA_GPIO(S, 5) GPIO_ACTIVE_LOW>;
			vdd-supply = <&cam0_supply>;
			/* END */
			clock-frequency = <24000000>;
			lens = <&cam0_lens>;
			pan-motor = <&cam0_pan>;
			tilt-motor = <&cam0_tilt>;
			controller-data {
				nvidia,tx-clk-tap-delay = <16>;
				nvidia,rx-clk-tap-delay = <0>;
				nvidia,cs-setup-clk-count = <16>;
				nvidia,cs-hold-clk-count = <0>;
			ports {
				#address-cells = <1>;
				#size-cells = <0>;
				port@0 {
					reg = <0>;
					camera0_4_out: endpoint {
						 /* !!! index of the csi input port */
						port-index = <2>;
						bus-width = <4>;
						remote-endpoint = <&csi2_4_in>;
It’s not my problem. My problem is that CS isn’t toggling.
Is this the device tree which has been verified work for CS on another platform?
What is that platform and Jetpack release you verified before?
Yes, it’s working on Jetson Nano with Jetpack 4.6 and L4T R32.6.1
Could you help to provide the result of the following command?
$sudo busybox devmem 0x02430068 //PQ.05
$sudo busybox devmem 0x02434008 //PH.06
Do you mean that you could control this pin(PH.06) successfully and the result from oscilloscope is expected?
The issue is about it can’t be used as CS pin for SPI interface?
nvidia@ubuntu:~$ sudo busybox devmem 0x02430068
0x00000000
nvidia@ubuntu:~$ sudo busybox devmem 0x02434008
0x00000001
Yes with /sys/class/gpio
It’s exactly this.
Please make sure which dtb you are using first.
You may refer to the flash log to know which device tree is using to flash.
And please help to check if the following two lines have been removed in device tree of gpio.
In my case: tegra234-mb1-bct-gpio-p3767-dp-a03.dtsi
-				TEGRA234_MAIN_GPIO(Q, 5)
-				TEGRA234_MAIN_GPIO(H, 6)
I remove the two lines from my gpio default file but it’s still not working.
It’s well our pinmux generated file that is used:
copying pinmux_config(/home/altaneos/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/Orin-client-model-pinmux.dtsi)... done.
GPIO is included in this file.
Hi @DaneLLL ,
What did you want to say with this sentence ?
@jbzp00y
Could you add debug message to the spi-tegra114.c to check if the cs-gpio was configure by the gpio-set-value() function?
Could you help to apply the following patch for CS issue?
SPI TPM module support fail on jetpack 5.0.2/5.1 on jetson xavier agx - #25 by DaneLLL
It’s working.
I had to make another change in file spi-tegra114.c:
- ctrl->use_gpio_descriptors = true;
+ ctrl->use_gpio_descriptors = false;
Thank you
