ST60 wifi USB/UART connected to M.2 Key E Slot J505 in AGX Xavier Kit not working
We are using AGX Xavier Dev kit with 5.0.2 jetpack.
We are trying to connect ST60-2230C-U (USB/UART) to M.2 Key E Slot J505
The M.2 Key E slot supports PCIE, USB, UART, etc.
While the driver is loading, it is able to find the firmware file, after this it is a giving an error as usb blk error as -71 (EPROTO) and saying failed to download the firmware.
May be the current UPHY for J505 M.2 E slot is currently in PCIe and needs to changed to USB ?
Do we need to do any change in AGX Xavier DTS files like UPHY, ODMDATA ?
Kindly help
There is no support to change this on Xaiver AGX. Only support PCIE kind of card on the m.2 key E slot.
In the M2 Key E Slot schematic, the 3 (USB_DP) and 5 (USB_DM) pins are matching correctly with the ST60 USB_D+ and USB_D- pins
Hence it looks like this should work ?
ST60 shows it uses 3.3V, may be agx M2 Key E slot USB pins uses 1.8V ?
Or do we need to config in agx to use the USB pins in M2 Key E Slot ?
