Stuck on Getting Started with Jetson AGX Orin Developer Kit course
I was able to get past step 1 just fine, but I’m stuck at step 2; it says that, to install the JetPack components, I have to run those four commands in the terminal, but whenever I try to run any of them, it asks me to input my password, but nothing happens when I try to type it in. I can’t figure out how to get around this; someone please help!
Hi
Did you make sure your board has internet access?
Do you see any message after typing your password? It should looks like this:
nvidia@ubuntu:~$ sudo apt update
[sudo] password for nvidia:
Hit:1 https://repo.download.nvidia.com/jetson/common r35.4 InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports focal InRelease
Hit:3 https://repo.download.nvidia.com/jetson/t234 r35.4 InRelease
Get:4 http://ports.ubuntu.com/ubuntu-ports focal-updates InRelease [128 kB]
Hit:5 http://ports.ubuntu.com/ubuntu-ports focal-backports InRelease
Get:6 http://ports.ubuntu.com/ubuntu-ports focal-security InRelease [128 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports focal-updates/main arm64 Packages [2 917 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports focal-security/main arm64 Packages [2 611 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports focal-security/universe arm64 Packages [955 kB]
Fetched 6 738 kB in 4s (1 884 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
367 packages can be upgraded. Run 'apt list --upgradable' to see them.
Regards,
Enrique Ramirez
Embedded SW Engineer at RidgeRun
Contact us: support@ridgerun.com
Developers wiki: https://developer.ridgerun.com
Website: www.ridgerun.com
Yes my board does have internet access; when I first booted it up, it had me connect it to WiFi. And when I open a terminal, I first type in a command, at which point it asks for a password, but nothing happens when I try to type; no matter which key I type, nothing happens. I have no idea what I’m doing wrong.
Could you access your device using ssh?
What is SSH?
sudo apt update
[sudo] password for your_userid:
sudo then waits for you type the password, it just doesn’t show your password to you as a security measure.
Type your correct password and press enter.
Then it will say
variable_number packages can be upgraded.
Then you type:
sudo apt upgrade
the apt application will then prompt you to type y or n
type y
hit enter
Then apt will install the upgrades.
Just about every program you can access from the command line will provide brief explanation when you type
program_name --help
So if you were to type, for example:
apt --help
or
ls --help
The program will show you command line options and how to use the command.
