I’m modelling with subdivision surfaces in Rhino. If I “Send to Omniverse” or “Export” the subd’s aren’t written. Obviously the workaround is to run ToNurbs or convert to a mesh before exporting but it seems like the connector should be able to figure it out in the same way that it converts nurbs - or, ideally, output native USD subdivision surfaces.
jon7spu2
1
subD is currently not supported, you will have to convert to mesh or nurbs
Related topics
| Omniverse Rhino bug export | 0 | 668 | February 23, 2023 | |
| How to export a NURBS curve into Omniverse from Rhino | 1 | 328 | May 4, 2024 | |
| SketchUp and Rhino connector | 9 | 2064 | November 8, 2021 | |
| Textures not connected to shader when exporting USDPreviewSurface from Maya | 6 | 820 | January 24, 2024 | |
| Substrate materials in omniverse? | 3 | 779 | April 12, 2023 | |
| No USDZ export? | 1 | 789 | September 20, 2022 | |
| "Apply Subdiv" always works | 2 | 936 | March 24, 2022 | |
| Exporting curves to Omniverse | 4 | 1052 | July 22, 2022 | |
| Exporting translucency/subsufrace scattering materials from UE5 to usd | 0 | 378 | December 12, 2023 | |
| Not all elements are exporting with USD file (missing textures and Objects) | 6 | 1019 | November 4, 2023 |
